Customs Any such thing as wedge shaped washers or shims?
Discussion in 'The Hokey Ass Message Board' started by atikovi, Jan 24, 2023.
  1. atikovi
    atikovi
    That I could use under this bolt head that rests at an angle to evenly distribute the clamping force?
    dana barlow likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. Happydaze
    Happydaze
    Heavy wall tube cut to suit?
    Is the floor flat/ parallel to the top of the frame, or have you got the same issue underneath? If so its easy to cut the waste tube to match.
    Chris
    Lil 32 likes this.
  4. eaglebeak
    eaglebeak
    On construction .. elevators, etc we called them "askew" washers. The large ones were cast iron. But I can't find anything under that name.
    Just.dale likes this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    How about a wavy washer? HRP
  6. RAT "T"
    RAT "T"
  7. eaglebeak
    eaglebeak
    RAT "T" ... that's the ones I was looking for.
    Bob Lowry likes this.
  8. DDDenny
  9. The few that I've ever needed tended to be custom angles so I just ground them down by hand on a belt sander or such.
    I really like the post #2 suggestion. Those are the cat-s***. :p
    Though they could sometimes look a little weird if they're prominently in your face. But that's true of some of the other suggestions, too.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Square beveled washers are available in stainless steel also.
  11. atikovi
    atikovi
    What industry uses those square beveled washers? Just need one and if I can't find locally, I might as well grind something to fit.
    Cosmo49 likes this.
  12. RICH B
    RICH B
    We used them on the inside of structural channel when bolting thru the flange.
    alanp561, jimmy six, LWEL9226 and 4 others like this.
  13. gimpyshotrods
    gimpyshotrods
    https://www.mcmaster.com/wedge-washers/
    rbrewer, Cosmo49 and jimmy six like this.
  14. Yes find a place that sells dimensional washers and seek beveled or adjusting washers.
    They are popular to land a late model small block chevy intake on pre 86 heads, a**** other things.
    reagen, Algoma56 and Atwater Mike like this.
  15. lostone
    lostone
    from kansas
    Check local steel building contractors. Alot of perlings are angled and have square wedge washers bolting them together.
    porknbeaner likes this.
  16. DDDenny
    I have some odds/ends, I will take a look.
  17. DDDenny
    I have two sizes, two of each.
    The large one is 1&1/2" square with a 5/8" hole, tapers 3/8" to 1/8".
    The small one is 1&1/4" square with a 3/8" hole, tapers 1/4" to 1/16".
    Algoma56 likes this.
  18. 3quarter32
    3quarter32
    Always used to call them "Hillside " washers.
    tiredford, Cosmo49, alanp561 and 2 others like this.
  19. DDDenny
    You know, you could swing a dead cat and hit a hardware store that stocks these!
  20. Harv
    Harv
    from Sydney
    Sigh. Why are we giving Atikovi solutions that just mask the problem?
    He clearly has the wrong fastener. He needs one of these:
    Once it has been installed in the hole, tighten it up until it snaps then back it off half a turn.
    Cheers,
    Harv
  21. Just.dale
    Just.dale
    Bless you!! Lol
    Atwater Mike and anthony myrick like this.
  22. swade41
    swade41
    from Buffalo,NY
    If you Google beveled washers all kinds pop up with all kinds of suppliers, I've ground some down with a belt sander but they are slippery little devils.
  23. blue 49
    blue 49
    from Iowa
    Cosmo49 and '28phonebooth like this.
  24. hotrodjack33
    hotrodjack33
    LOL;). Usually takes 3 or 4 tries...never seem to find the ones that shot a crossed the garage:(
    Special Ed likes this.
  25. Atwater Mike
    Atwater Mike
    Good thread. Found something I would have asked about! 'Hillside washers?' Whoda thunk???
    Cosmo49 likes this.
  26. nochop
    nochop
    from norcal
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I find the little FAT book is “the right stuff” compared to the on-line look up.
    Special Ed, Mr48chev and nochop like this.
  28. nochop
    nochop
    from norcal
    They still have a paper catalog?
    Johnny Gee likes this.
  29. deathrowdave
    deathrowdave
    from NKy
    Hillside washers ! I was thinkin there was only one true hillbilly in the crowd ! ME , but lookin like there are a couple hiding out . Hey , my friends !
