Hot Rods How Difficult & Expensive to Replace Valve Guides at Home? Do a Valve Job?
Discussion in 'The Hokey Ass Message Board' started by bulletpruf, Jan 24, 2023.
  1. bulletpruf
    bulletpruf
    I chucked up one of the galled valves in a drill and used 400 grit paper. I managed to polish the galling and grooves out. Need to mic it to see how much material I lost, but I think this is a viable route. EDIT: Looks like I took off about .001" of OD.
    As for enlarging the guides to the correct size, they're currently at .3885" or so, depending on the guide. I'd like to get them to .3895" or so on the intake (.0025" clearance) and about .3900" on the exhaust (.0030" clearance).
    Would I do this with a reamer or with a hone? Reamer makes me a bit nervous about having it perfectly centered.
    Thanks
    tractorguy likes this.
  2. jimmy six
    jimmy six
    Guides are best handled by a shop. Positive seals can be done at home with the purchase of the proper tool and pretty easy to do if you know valve lift. Remember to lap the valves in before installing the seals.
    Truckdoctor Andy likes this.
  3. saltflats
    saltflats
    from Missouri
    Keep an eye out for a seat and guide machine, they pop up here every now and then for decent price.
  4. TA DAD
    TA DAD
    from NC
    How does someone learn anything if they pay someone else to do it ? Taking your stuff to a shop is no guarantee it will done correctly. This place is amazing.
  5. Truckedup
    Truckedup
    exactly true......good valve work is a precision job.. getting the guide concentric with the valve to aviod excessive seat grinding that kills performance...You can do it at home, all depends on what you consider acceptable....
    tractorguy and Truckdoctor Andy like this.
  6. AccurateMike
    AccurateMike
    I would use a reamer. They are piloted. I think it would be likely to get more out of kinder with a hone. You'll be doing a valve job either way. Mike
    bulletpruf likes this.
  7. bulletpruf
    bulletpruf
    My point exactly!!! Thanks for the comment!
    ken1949car, 19Eddy30 and AccurateMike like this.
  8. bulletpruf
    bulletpruf
    Mike - thanks. I figured I would be doing a valve job, too, but why is that? Because even the slightest deviation in the angle of the guide will throw off the valve job? Thanks
  9. AccurateMike
    AccurateMike
    Yes, both angle and concentricity of the new guide. A little ink/blue on the seat and spin the valve, will tell you how much. Mike
  10. atikovi
    atikovi
    I can imagine them saying, Due to insurance regulations, we cannot allow customers in the shop. I mean, would you want people starring at YOU while you work?
  11. SEAAIRE354
    SEAAIRE354
    I just read through this kinda quickly but it looks like you only need to take a couple thou out. As mentioned the reamer is the better choice. A small flex hone will never get you there and the ridged valve guide hone setup is really expensive. And as also mentioned valve guid reams are piloted to keep you straight. Going back to the bronze guid liners. The Goodson setup looks like it changed. I have to older system and the cutter it uses is piloted and using it on a guid that’s already.015 over gets tricky as there’s a lot of slop for the pilot to manage. The newer system may work better but wanted to throw it out there.
    bulletpruf and Budget36 like this.
  12. Blues4U
    Blues4U
    from So Cal
    I seem to remember there being a process of repairing worn valve guides that involved a process similar to installing thread repair inserts. The guide is drilled out with the proper size bit, then it is treaded with the tap provided in the kit and bronze wire insert is threaded into the guide and then reamed to size. This was decades ago and my memory is fuzzy, I never did the job myself and have no firsthand experience with it, but I do recall hearing and reading of this being done. One of those innovative repairs that people did when they didn't have the time or money to do the job correctly. It worked for a temporary repair.
  13. Valve job requires a valve grind machine to cut the seats.
    As for guides, we have been doing bronze guides for years with hand tools. You do not remove the old guide, you drill it out p*** a knurl through it and install a bronze sleeve in it. Pretty common performance mod.
    You can get a kit from your favorite automotive catalog speed shop. I prefer a place in ohio but you can choose whatever one floats your boat.
  14. lostone
    lostone
    from kansas
    I've never built a motor (+10) that I didn't have the machine shop install bronze guides.
    I one of those people that when it comes to building an engine that I plan on driving it a long time and totally h***le free. I hate putting good money into something just to have to take it apart several yrs latter.
    Truckedup likes this.
  15. bulletpruf
    bulletpruf
    Ok, the reamers that I'm looking at (someone posted a link earlier) are "Piloted for self-centering action." The only issue is the size. I was hoping for .389", but they have .388" and .390". The .390" should be perfect for the exhaust (leaving me with .003" clearance) but I didn't want to go to .003" on the intake. Anyway, I think I'll order the 3.90" and use it on the exhaust guides. On the intake I may just be able to hit them with a hone and call it good. BTW - the heads came off a turbo engine and it's getting a turbo again, but with a bit more fuel and about the same boost. That's why I want to make sure the guides aren't tight again on the exhaust.
    Thanks
    ekimneirbo and AccurateMike like this.
  16. bulletpruf
    bulletpruf
    Yeah the Sunnen valve guide hone setup is about $2,000 new. Budget can't handle that right now.
  17. bulletpruf
    bulletpruf
    Valve jobs can be done at home without a specialized valve grind machine. I'm not there yet, but that will be my next step.
    Thanks
  18. bulletpruf
    bulletpruf
    In the past, I have been a bit of a perfectionist when it comes to building motors. I'm trying to get away from that and at the same time, I'm trying to do more of the work myself. If that results in me pulling an engine to fix something that was jacked up, I have no one to blame but myself. I'm ok with that.
  19. seb fontana
    seb fontana
    from ct
  20. bulletpruf
    bulletpruf
    Yeah, that's the next purchase, I think. With the $800 I saved from not buying the bronze liner installation kit, I can pick up a valve seat cutter setup.
    Thanks
  21. bulletpruf
    bulletpruf
    I ordered the .390" piloted reamer.
    Need to order a valve guide hone; the 3/8" will be too small since I'm at 3/8" + .015" on the guides. Next size up is 10mm. That should work.
    ekimneirbo likes this.
  22. Budget36
    Budget36
    You know what your next purchase will be right? A head resurface machine, well, 2nd in line after you get a precision straight edge;).
    I admire your DIY at***ude, I can still do a lot of things, but now take a lot of things into shops that do it daily.
  23. bulletpruf
    bulletpruf
    Already have the straight edge; check out the video link I posted above to see it in action!
    I may end up using a "redneck resurface machine" -- sandpaper glued to some thick plate gl***. One of my cylinder heads has just shy of .002" warp; still within spec, but I'd feel better if it was less than .001"...
    Budget36 and Blues4U like this.
  24. bulletpruf
    bulletpruf
    Got a few silicon carbide flex hones ordered in 10mm/.394" - one in 120 grit for intake guides that are a bit tight (I do realize that this is not likely to remove much material), and then 240 grit for a finish hone on all guides. Other option was 320 grit for finish hone but apparently diesel engines like a slightly co****r surface to better retain oil.
  25. sunbeam
    sunbeam
    Budget36 and bulletpruf like this.
  26. 1971BB427
    1971BB427
    from Oregon
    Of course most of us love to learn something by doing it ourselves. But the lesson learned shouldn't be what to do to ruin parts, and waste time and money. If I had a junk head and plenty of time to play with it, I still wouldn't try to hand ream or fit guides to it. If the head had press in guides already I'd consider playing around with pressing in a new guide just to see if I could. But I certainly don't want to learn what not to do if it results in screwing up a pair of heads that could have been repaired correctly.
  27. 1971BB427
    1971BB427
    from Oregon
    I've cleaned up the mating surface on heads using a large aluminum block wrapped with emery paper and some WD40 or kerosene to wet sand the surface. But the heads were true and straight before I started, so I wasn't truing the surface, just making it very smooth before installing new head gaskets.
  28. MCjim
    MCjim
    from soCal
    Right, man's gotta know his limitations
    1971BB427 and Truckdoctor Andy like this.
  29. bulletpruf
    bulletpruf
    Good point on gl*** tables. Will have to figure out what grit sandpaper to use and where to source a large enough sheet of it.
    The website for the flex hones was actually quite informative. That's why I chose the size that I did.
    I actually ordered a quart of honing fluid because it wasn't that expensive. I'll use it when I use a ball hone on my cylinders as well.
    Thanks
  30. bulletpruf
    bulletpruf
    As mentioned earlier, I prefer to do things myself and I enjoy the learning process. Yes, it's more challenging and time-consuming (and sometimes more expensive), but it's a lot more fun - at least for me - than writing a check.
    SEAAIRE354 likes this.
