Projects Homemade Bodies using Stock Model A Cowls"....
Discussion in 'Traditional Hot Rods' started by 1941g506, Jan 24, 2023.
  1. 1941g506
    1941g506
    Let's see those builds you scratch built off of a model a firewall
    oliver westlund likes this.
  2. Just Gary
    Just Gary
    I retained my stock '28 Tudor's firewall but deleted some of the "warts" and widened the stock recess.
    What *was* the stock recess can now accomodate a big Hemi V8, but it still retains the stock steering column opening and cowl legs.:cool:
    FrWal-01.JPG FrWal-02.jpg FrWal-03.JPG FrWal-04.JPG FrWal-05.JPG FrWal-06.JPG FrWal-07.JPG FrWal-08.JPG FrWal-09.JPG FrWal-10.JPG
    Tman, nochop, The37Kid and 5 others like this.
  3. hotrodA
    hotrodA
    If you want something smooth with no bumps, here’s my old 31 roadster, “ hotrodA”
    I cut back the stock firewall even with the lip that retains the hood lace.
    I cut a piece of 16 ga. exactly matching the outline of the lip edge and carefully welded it to the edge.
    I cut out where the recess for the distributor needed to go and cut off one end of a Detroit Diesel valve cover that fit in to the cutout. This gave me a neat lip to define the opening and a compound curved recess.
    Stan Back, MMM1693 and Just Gary like this.
  4. 1941g506
    1941g506
    All nice cars guys! I'm looking to really see homeade bodies built from just the A cowl! Thanks
  5. brett4christ
    brett4christ
    @1941g506 Might want to edit the ***le. I was getting ready to show my firewall as well.
    Maybe "Homemade Bodies using Stock Model A Cowls"....
    Just Gary likes this.
  6. saltflats
    saltflats
    from Missouri
    There was a thread on years years ago, something like "So You Started With A Cowl" or something like that.
    I have tried a few times to find it but with no luck.
    Joe Blow likes this.
  7. Joe Blow
    Joe Blow
    Tman and saltflats like this.
  8. The37Kid
    The37Kid
    I like that, think I'll put an old late '31 firewall on the cl***ifieds. Bob [​IMG]
    Just Gary and -Brent- like this.
  9. 1941g506
    1941g506
    Your right thanks! Still all great work thanks guys!
  10. Reddog sawmill
    Reddog sawmill
    Here's one I started a few years ago. 30/31 cabriolet cowl and a 30/31 sedan back section with unknown 30's doors to finish the body. That's as far as I got for now but hopefully I'll get back on it soon. Itll never be pretty but i think the stubby little sedan made out of junk will be cool. 20190922_152430.jpg
    Xman, RMR&C, 1941g506 and 2 others like this.
  11. Oldtmtech
    Oldtmtech
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My HOT TUB.
    Model A cowl
    1916 Maxwell doors
    '46 deck lid for a rear wraparound
  13. tombstone
    tombstone
    from sk.canada
    0D81B749-2E47-4900-91A4-22387D44DB79.jpeg Maybe not quite what you’re looking for , but I built this starting with the remains of a 32 cowl.
  14. rudestude
    rudestude
    I started this cowl using a 30? Briggs or Murry model A cowl ,no fire wall, for a single seater T build.
    Just removed the fire wall and gas tank then sliced it down the center then over lap the two pieces, clamped it to the frame rails and loosely clamped the center then just started sliding the two halves together until I got the width and arch that I wanted and tacked it together....the side panels were just card board in this stage of mock up. IMG_20161113_102738.jpg 20160427_170823.jpg 20160511_171920.jpg 20160511_202303.jpg
