Hot Rods 1932 Ford coupe exhaust help please
Discussion in 'The Hokey Ass Message Board' started by brady1929, Jan 23, 2023.
  1. brady1929
    brady1929
    Hello all,
    I am working on my 32 ford 5 window coupe project. Money is tight so I need to do this myself. I have never done it before. I have a 327 and an exhaust manifold. 20170211_124954.jpg
    I know I want Porter or Smitty mufflers. Plus it will be a 2 inch system.
    Can you all please help me with:
    1. Pics of a 32 ford frame & exhaust system.
    2. Recommend exhaust hangars.
    3. How far apart do exhaust hangars need to be.
    4. Basically any information that could help someone who has never done this before.
    I will be buying an exhaust kit from Amazon and have a welder. Thank you.
    Joe Blow and lothiandon1940 like this.
  2. Rex_A_Lott
    Rex_A_Lott
    Have you got a lift? A TUBING bender? If you're planning on using that pipe bender that HF sells, just dont.
    Save your money and pay a professional, you'll be time, money and frustration ahead. Exhaust work is just hard to learn on the fly. Good Luck.
    3quarter32 likes this.
  3. alchemy
    alchemy
  4. jaracer
    jaracer
    I make/install most of the parts for my hot rods. However, you will be money and time ahead to go to an exhaust shop and let them make the pipes.
    I have Porters on my Nailhead and really like them (28 Model A).
  5. 19Eddy30
    19Eddy30
    from VA
    It depends on how you plain on running the exhausts,
    Exit Out side before rear fenders/tire? ,
    Over axle
    Or under ?
    Slip or weld ?
    stay with good Ga like walker , I believe
    16 .035-.050 Thick
    The tubing sold @ AutoZone /Avance is thin & wast of $
    Doing Cheap made /Quality, you will be doing it again,
    If not tucking ,it can be done for less then
    $200 minus mufflers , out the side or straight under axle , with 1 elbow bends @ each manifold but it will hang !
    Nice free-flowing radiuses tubing will
    Be in $350 ish to ??
    Each elbow will be $30-50
    Or can use J tubing $20-30 each
    Fabrication donuts mild steel $40ish each ( for tight radius)
    10 ft stick $70ish
    Summit tubing / exhaust pieces are nice
    There is universal kits in a box
    Exhaust tools will be needed
    On a lift is preferred like mentioned above
    Just Gary likes this.
  6. DDDenny
  7. 31Apickup
    31Apickup
    I bought an exhaust kit thru Amazon also came with all the bends, cut, fit and weld up, no big deal. Speedway has premade head pipes which simply that part. You don’t need a bender. I’d put hangers at the mufflers and another set on the tail pipes. I only started fanning mine on 32 ch***is so don’t have photos yet.
  8. chop&drop
    chop&drop
    Here’s what I did on my ‘32. 1A31C866-9DF0-4B1B-BE99-3FBD5EA111C1.jpeg I ordered mandrel bent pieces online and built it myself. I built my own hangars too.
  9. Rocky
    Rocky
    Classified Editor
    34exhaust.jpg 34mufflerhangerpainted.JPG I bought a 2.25" Speedway kit.
  10. catdad49
    catdad49
    The 2 1/4" kit from Speedway worked for me. The first side will take the most time (be patient and tack only at first), then do the other side (a mirror image, if nothing is in the way). Yes, it will take time. Yes, you may get frustrated. Yes, you did it Yourself!!
    bchctybob and lothiandon1940 like this.
  11. krylon32
    krylon32
    from Nebraska
    On my 5 window we used a 16 gauge 2 inch kit with bends and straights that I bought on E-Bay. I got the flanges at the local muffler shop and the 12 inch Flow Master mufflers from Speedway. We've done several this way and am planning on doing the same thing on my latest roadster. 2.5 inch looks cool but I use 2 inch because it's easier to run and it's adequate for a SBC. I keep everything inside the frame nothing below.
  12. grdra1
    grdra1
    Search Youtube as well
  13. Duke
    Duke
    bchctybob likes this.
  14. 31aford
    31aford
    from az
  15. krylon32
    krylon32
    from Nebraska
    31aford That is the same bend kit we use also bought on E-Bay.
  16. Joe Blow
    Joe Blow
  17. 19Eddy30
    19Eddy30
    from VA
    The ebay kit posted ,in description does not say the Ga of the exhaust tubing .
    If 16-14 ga thats a good price ,
  18. krylon32
    krylon32
    from Nebraska
    I did some research before I bought the E-Bay kit and they claimed it was 16 gauge. I have not opened the box yet.
  19. 2deuces64
    2deuces64
    2 inch stainless Ebay 90's IMG_20210227_182952415.jpg IMG_20210227_182846989.jpg IMG_20210227_182907898.jpg
  20. brady1929
    brady1929
    Thank you all for the pictures and information.
    1. How much clearance between the exhaust and any other object is needed?
    2. Please post a picture of a good exhaust hangar.
    3. And everything has to be soft mounted?
    lothiandon1940 likes this.
  21. Just Gary
    Just Gary
    I'd never done it before either and it wasn't hard, but on mine, the body was off the rolling ch***is.
    **MOST IMPORTANT: I mocked up the routing using cardboard paper towel rolls, Christmas wrapping rolls, etc.**
    Then:
    I bought Patriot brand 16 gauge J-bends from Summit.
    2.5" tubing, true duals (no X- or H-pipe)
    24" Thrush gl***packs.
    Three simple auto-parts store rubber hangers on each side (6 total)
    -one right after the header flange.
    -one right before each muffler.
    -one near the rear bumper
    Make sure *ALL* your cuts are perpendicular to the tubing direction so the ends are perfectly round. I borrowed a friend's band saw & belt sander to help with this.
    All MIG-welded with my trusty Lincoln 140C.:cool:
    bchctybob, Joe Blow and 19Eddy30 like this.
  22. DDDenny
    bchctybob and Just Gary like this.
  23. Bandit Billy
    Bandit Billy
    Mine are 70 years old but do the job. :cool:
  24. '29 Gizmo
    '29 Gizmo
    from UK
    I bought a stack of stainless bends and welded them together to get the shape i needed
  25. clem
    clem
    now where is the fun in that…….?
    or learning experience……………?
  26. clem
    clem
    Mine from 30 years ago, - from when I didn’t know what I was doing, - bought some mandrel bends on the advice of good friend @Gofannon and learned to gas weld.
    Really pleased with it, although looks pretty mediocre to what others can do……
    had to route it around brake booster and battery box, used 20mm x 3mm flat steel for hangers and old exhaust rubbers from a wrecked car. Then painted it white……
    Gofannon and Just Gary like this.
  27. RockyMtnWay
    RockyMtnWay
    I’m just playing around with exhaust on a 32 ch***is for my roadster project now so here’s a couple pics of what I’m doing. Still debating the over/under rear axle routing, but the pics may still help. Used these exhaust bobbins on the last 32 5W and really liked how they worked, so using the idea again on this exhaust. Just going to cut and attach the crudely drawn hangers today.
    PS: just remember the closer you go to the floorboard under your feet and seat, the toastier your feet and seat are going to get.
    23BFD7EF-E1A4-4240-8EF6-89BE51B8FBD9.jpeg CBB32E12-D21F-4EFA-914B-0275CB685189.jpeg
  28. RockyMtnWay
    RockyMtnWay
    And when picking pipe size, here’s a couple cheat sheets I use. Lots of places on the web where you can calc optimal pipe size too.
    68670050-66C4-4DB9-8E5D-19DEB5A39055.jpeg A49718E3-FB7A-477D-B138-B95A7C79F08B.jpeg
