Technical Speedometer ID?
Discussion in 'The Hokey Ass Message Board' started by Malcolm Elvy, Jan 26, 2023.
  1. Malcolm Elvy
    Malcolm Elvy
    Can anyone tell me the application for this speedometer? It appears that the drive cable drives a little generator(?) which in turn creates voltage to turn the speedometer? Thanks for any help....Malcolm DSCF3119 (1).JPG DSCF3120 (1).JPG DSCF3121 (1).JPG DSCF3122 (1).JPG DSCF3123 (1).JPG
    41 GMC K-18 likes this.
  2. squirrel
    show us the back of the speedometer?
  3. Malcolm Elvy
    Malcolm Elvy
    See attached
  4. I’ve seen old tachometers like that that attach to the crank snout .
    I just can’t picture anything from that era that would need a 7 grand tach .
    Oh , and I bet it’s off a dodge :D
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pictures. please select full image when posting pics, especially when you are looking for ID help
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Pioneer made aviation stuff. could explain why there is no odometer...
  7. squirrel
    it sure has that aircraft look to it with all the safety wire holes and the mil spec type connectors. Also the 4 tab mounting would be right...if only it were turned 45 degrees!
  8. Malcolm Elvy
    Malcolm Elvy
    It is a speedometer....not a tachometer...I've seen another face that had the speed you could go in each gear...see attached......Thanks
    VANDENPLAS and 41 GMC K-18 like this.
  9. squirrel
    I expect the big truck or whatever equipment it came from is not really a hot rod or custom? :)
