Technical Homemade air cleaner.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Jan 24, 2023.
  1. theHIGHLANDER
    theHIGHLANDER
    I only have 1 filter fact to share. The white "bleached" coffee filters ****. I use the brown naturals, no more Clorox coffee. But those filters you made? I keep staring at em. Fk'n kool. I'd still do 2 or 3 layers of copper wool, and you can wash and oil that stuff too, just oil the inside layers and the outside stays clean. Did I say how kool those are? I meant to...:rolleyes:
    NoelC, Adriatic Machine and Algoma56 like this.
  2. FishFry
    FishFry
    As far as I understand it, it's not turbulence per se, it's the pulses of an engine, that a shop vac with a steady stream can't provide.
    Frank
    down-the-road and Algoma56 like this.
  3. theHIGHLANDER
    theHIGHLANDER
    I would say K&N filters ****, but then again they're supposed to.
    I would think the best test of a filter media is, oh I dunno, maybe a 4" piece. See how much it traps and how small, add to that it's resistance to flow. I run just regular paper filters, I live on a dirt road. None of my intake tubes are ever dusty inside.
    Aesthetics? Not sure about my brethren here but a pink gauze filter on an old build looks confused to me. I hope a future HAMB topic won't be "What are the best coil packs for my flathead V8." Yeah yeah, fk off. I know that's extreme, just making a point. Carry on. Oh yeah, those filter bodies? Oh yeah...:cool:
    jimgoetz and Blues4U like this.
  4. Joe H
    Joe H
    I was at the dragstrip and watched my friend make a couple p***es with his BBC wagon with a paper filter for air cleaner. He pulled a brand new K&N out of the box, installed it and made two p***es. The car slowed down 2 tenths and 2 1/2 mph. The paper went back in, car sped back up, K&N went in the trash can! Both were same diameter and hight.
    AHotRod and theHIGHLANDER like this.
  5. Adriatic Machine
    Adriatic Machine
    Very cool filter housings, I like them a lot. I’ve used that technique to make odd holes in sheet metal many times while I was in the Air Force.
    I vote for gloss black and copper wool. Stay away from aluminum wool. Aluminum oxide is one of the hardest, most abrasive substances around.
  6. Greenblade
    Greenblade
    I agree with @ekimneirbo .
    This is really all that needs to be said on the topic of air filters IMO.
  7. jimgoetz
    jimgoetz
    RSCN1693.JPG I got a 47 flathead with 2 97s and these G and C housings. I like them but wanted a little more filtering than just the screen. I cut up a couple of fine Scotch Bright pads and they seem to be using the job pretty well. Also thinking about copper plating too.
  8. Blues4U
    Blues4U
    from So Cal
    Says the dude that can't figure out why only 1 or 2 cam lobes fail on a cam... A dude that thinks reading a magazine article makes him an expert.
    Dooley and theHIGHLANDER like this.
  9. rusty rocket
    rusty rocket
    O.k. Enough with the filter bull ****! I found a Wix paper filter that fits inside and that’s what I’m running. I post this thread to show what can be done with some imagination and the right donor parts. I don’t care what people think on what color they should be or what mesh should be used, I have a plan and that’s what’s going to go down.
  10. brett4christ
    brett4christ
    The OP has spoken!!! Long live the OP!!!
  11. rusty rocket
    rusty rocket
    That’s right Damn it! Hahaha! Sometimes threads gets so off topic
    31 B'ville, 54delray, FishFry and 4 others like this.
  12. 1952henry
    1952henry
    Creative mind, execution perfect...my hat is off to you.
    jimgoetz and Greenblade like this.
  13. theHIGHLANDER
    theHIGHLANDER
    Dayuum, what took ya so long:D:D:D
    LOST ANGEL likes this.
  14. rusty rocket
    rusty rocket
    I have all three roughed out. Waiting on two more filters so I can finish the inside and add mesh. DE51B295-A9EE-43C1-8862-99A93D3036C9.jpeg 77382A33-1394-47B1-83E9-46A0338D9D67.jpeg 149BD554-631E-4DF2-9C69-EE1C41A5AC15.jpeg
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, rr;
    What're you planning for the hold-down nuts? I see an acorn, but wingnuts, dog-bone, mini-tri-knockoff, T-nut, other?
    I still like them... I'm thinking you just caused the price of old byp*** filter containers to at least quadruple... ;( . The new highly-sought-after "gold"... :) .
    Marcus...
    alanp561 and Greenblade like this.
  16. rusty rocket
    rusty rocket
    I will drill and tap for set screw on the base. I built a flat plate that holds the filter on the top it is held in place with set screws. On top of the plate is an elevator bolt that holds the lid on. Now that I have one built I should get pictures of all the pieces.
    54delray likes this.
  17. mitch 36
    mitch 36
    PRETTY PLEASE :):)
  18. FishFry
    FishFry
    I really love that "lantern" look of those. I have a thing for custom made air filter housings.
    So far I played with hub caps, a vintage vacuum cleaner, that looked like a jet engine, motor cycle side lids, an art deco tea pot andwhatnot. It's a great and creative way to add an personal touch and a "cherry on top".
  19. I like the Skillet Lid look.
  20. sunbeam
    sunbeam
  21. FishFry
    FishFry
    If you are - like me - into such quirky stuff, 1930s outboard motors also have quite some custom air cleaner potential.
    image_2023-01-28_150404690.png image_2023-01-28_150443693.png image_2023-01-28_150631404.png image_2023-01-28_150719324.png image_2023-01-28_150802560.png
  22. nickel plating is much more affordable and can be done at home, would be a cool project to try sometime.
    it is less of a bright shine that chrome has though.
  23. 51504bat
    51504bat
    IIRC Model A's grill shells were nickel plated not chrome.
    The_Cat_Of_Ages likes this.
  24. Blues4U
    Blues4U
    from So Cal
    Polished stainless steel
  25. 51504bat
    51504bat
    Thanks. Thought it wasn't chrome but never considered SS
  26. Many luxury 1920s cars used nickel instead of stainless or chrome iirc.
    Chrome especially because it was still a "fringe" coating.
    FishFry and 51504bat like this.
