Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. impala4speed
    impala4speed
    I like it! Looked good before but looks more like a bad *** hot rod now IMHO.
    mad mikey, loudbang and hd1084 like this.
  2. bymanr
    bymanr
    Thermometer hit 50 today! Just had to take the modified For a rip to the river and back!
  3. TA DAD
    TA DAD
    from NC
    IMG_0852.JPG I have the hood bolted on to the factory hinges which were all folded up. You just have to be creative when your old and worn out. It still has a ways to go ! IMG_0851.JPG
  4. surestar
    surestar
    from canada
    5F18694C-4A8B-4511-8D6E-795C84939EFA.jpeg F45B6694-1997-4E4C-88C5-5975D244DFAD.jpeg What did I do with my car today?
    Nothin...absolutely nothin..... it’s -25C here today
    But I did look out the window at it and make vroom vroom noises.
    Brought this project home last fall and just got started on it before the weather turned.
    More seriously, I can’t wait for spring, so much to do
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I finished up replacing the seat foams in the Ron Hing 56 chevy custom 56.jpg 56cal.jpg seata.JPG seate.JPG seatf.JPG seatg.jpg seath.JPG
    mad mikey, VF-1, hrm2k and 18 others like this.
  6. TigerFan
    TigerFan
    from Athens, GA
    A1936C7D-C3CA-4657-A24F-31E0D6D8E03B.jpeg 6F988AE5-7835-47E0-AF85-FDD920A1A910.jpeg B81AD3E9-A9F9-4312-A645-6ED8767A0701.jpeg
    I got one of my Steadfast subrails ready to mount by adding a “Z” to it.
    akoutlaw, mad mikey, VF-1 and 12 others like this.
  7. guthriesmith
    guthriesmith
    Other than driving my Buick to go pick up my daughter from work Friday night, the only thing I accomplished was rearranging the shop some starting with getting the boat out. Trying to get organized so I can get some work done.
  8. RICH B
    RICH B
    Made it out to the shop Friday and tacked together some tailpipe offsets, going to bring them home and finish weld them. Need to shorten the pencil tips; but they no longer try to occupy the same space as the bumper guards. Started fitting some tack strips into the A pillars.
  9. swade41
    swade41
    from Buffalo,NY
    Making patterns and a test piece to make sure the bend and angle are right for this bulkhead, still not 100% how I'm going about it but I have an idea lol
    20230123_195122.jpg 20230126_164519.jpg 20230126_164541.jpg 20230128_155341.jpg
    belzebub, mad mikey, hrm2k and 8 others like this.
  10. TA DAD
    TA DAD
    from NC
    I got the hinges and the hood installed and adjusted. When I started this build I framed the firewall with some square tubing eliminating the factory hinge mounting holes. So I had to redrill those thru the tubing. ( I have a couple dash/steering column support bars bolted to the backside of the tubing ) You can see in the one photo I always drill a small locating hole in the hinge to the body for future reference when having to R & R a hinge. Now on to the hood, I have two to choose from I am going to use the worst as the it is original to the truck and the paint matches. The down side being it has several cracks that need to be repaired. IMG_0868.JPG IMG_0869.JPG
  11. charleyw
    charleyw
    Worked on ergonomics, trying to fit everything for a 75 year old man (me). I figure the seats will just about match my bladder range.
  12. 32 hudson
    32 hudson
    10-4 on the bladder range. 73 yr old here
    mad mikey, X-cpe and charleyw like this.
  13. junkyardjeff
    junkyardjeff
    I got new seats for my Mercury,the front seats have many broken springs so it was going to need a parts seat and found someone parting out one that was power so I grabbed it. I also noticed the rear seat had a center arm rest so it also came home with me,the new seats are cloth and the rears could be installed as they are but the front has a cheap cover so who knows how it is. Most likely will be turned into a reupholstery project very soon. IMG_20230204_170748209.jpg IMG_20230204_170748209.jpg
    mad mikey, LAROKE, TA DAD and 3 others like this.
  14. While my current project is not hot rod related ( per se) the 49 Lincoln I’ve been sitting on for 20 years sold for $1k yesterday. I am happy.
    mad mikey, Chucky, rod1 and 1 other person like this.
  15. jimmy six
    jimmy six
    Drove to the NHRA Museum for the 200 MPH meeting. 75 miles round trip. Open freeway for the 9:00 am start. 70-75 mph. Car performed flawlessly. Thinking of venturing out farther and enjoying the weekends more.
  16. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Went for a therapy drive in rural Missouri. 71A6B743-91F9-4878-B863-C8A34F7D46FB.jpeg EA411675-7BE9-4297-BFE3-C520F2CF59DA.jpeg
  17. Mike Miller
    Mike Miller
    It seems that the parts I needed to fix the heater in my beater 56 wagon are ungettable so I bought a cheap hot rod heater from speedway and installed it, Surprisingly it works quite well if all a fella wants is to be warm.
  18. jimmy six
    jimmy six
    Wish would have known. I boxed my original up when I added AC/heat. I needed to keep the controller for the right side air. You should have asked for one on the HAMB social page for 52-59 Fords.
  19. Yesterday I figured out that I did not have wheels with tires on them that would clear the brakes on an old chebby I got on a trailer. I finally figured out that I can put 14s on it backward. I hope to roll it off the trailer today.
    The wheels on backward make it look like an old stock car. LOL
    mad mikey, j hansen and X-cpe like this.
  20. 210superair
    210superair
    from Michigan
    Yeah man, I dunno about there, but today is the first warm up in Michigan. Supposed to be almost 50 Tuesday. Gonna swing by my barn today and check in on the hot rod and boats. As soon as it warms a tiny bit and the salt is gone, out comes the shoebox. Can't wait....
    guthriesmith likes this.
  21. JD69
    JD69
    from Hockinson
    I started fitting the trunk floor. Front piece ready to tack. Working on the mid section now. I never get as much done on the weekend as I figure I should.
  22. TA DAD
    TA DAD
    from NC
    The hood I am using needs a little TLC. After scrubbing/grinding the first layer of rust off I added a couple reinforcement patches and hammered out a hat channel to add to the center where it has some rust issues. I have to go back and cut out the hand holds in the front patches where I will use hood pins to hold it down. IMG_0874.JPG IMG_0875.JPG IMG_0877.JPG
  23. Illustrious Hector
    Illustrious Hector
    After it hit the road almost 10 years ago, I decided to make a badge for the grill shell 20230204_101052.jpg 20230204_101525.jpg [
    simplestone, TA DAD, charleyw and 3 others like this.
  24. hrm2k
    hrm2k
    Stopped at the machine shop to pay on my bill. I was invited into the shop to see this…..my 283 for my roadster pickup B9263D71-4485-47A4-A569-53D7B9E23A6F.jpeg
    TA DAD, Hamtown Al, charleyw and 8 others like this.
  25. Bad Bob
    Bad Bob
    from O.C. Baby
    Drove the Coupe to work again today. Wife had to take my car, cause she had a flat....
    mad mikey, Lil 32 and hrm2k like this.
  26. Bad Bob
    Bad Bob
    from O.C. Baby
    Is it just me, or do you seem to get to work faster in a car with a stick? hahaha
    RICH B, hrm2k and Moriarity like this.
  27. milwscruffy
    milwscruffy
    Altering the rear wheel wells to compensate for the 2" channel and moving the body forward to clear the frame, it's always something. IMG_1008.JPG IMG_1013.JPG IMG_1020.JPG
  28. jeepster
    jeepster
    from wisconsin
    Gettin' ready to try doin' some seat upholstery.
    MO_JUNK, osage orange, RICH B and 7 others like this.
  29. mad mikey
    mad mikey
    Installed new u-joints in the drive shaft. Lowered the rear end a bit (back were it was) , re-set pinion and trans angel and installed the drive shaft. The old dragster scoop is painted and done. I will get some pictures later, I'm tired.
    TA DAD, RICH B, j hansen and 3 others like this.
  30. Orn
    Orn
    Installed a p***ing eye mirror on my 40 Olds.
