Technical Drum brakes - lack of stopping power
Discussion in 'The Hokey Ass Message Board' started by Driver50x, Jan 18, 2023.
  1. @Driver50x ...just checking in to see if the backing plates and wheel cylinders solved your issue?
    gimpyshotrods likes this.
  2. Driver50x
    Driver50x
    And………the results are in!
    I replaced the backing plates and replaced the 3/4” wheel cylinders with 7/8” ones. It now works exactly as I had hoped. On dirt, if I really stand on the brakes, it will lock up the rear tires. But the fronts still lock up long before the rears, so that’s good. I haven’t had it up to freeway speeds yet, but I did a couple pretty hard stops from about 35 MPH on dry pavement. It definitely stops quicker, straighter, and with less pedal pressure than before. The next time I get caught in the rain I’ll be able to test it on wet pavement.
    Thank you very much @squirrel @Moriarity and @gimpyshotrods for sending me in the right direction, as well as everyone else who tried to help.
    Also, I measured the old backing plates. They are about .050” thick. The new Dorman ones are about .075” thick, and they are noticeably heavier and stiffer. So that’s a good thing.
    Now I just gotta figure out what to do with my parking brake, to get some more leverage or something.
    523C205D-4860-46DE-9370-99F569441569.jpeg 633281B1-191F-4BD7-9C25-AEEC3CEE1B0D.jpeg 5B613B2D-4E83-4D81-97FF-63B12EB2ACDD.jpeg 98050BAD-9DD3-47E0-BA3F-E9912D67E400.jpeg
    dwollam, 2Blue2, Moriarity and 4 others like this.
  3. gimpyshotrods
    gimpyshotrods
    What parking brake lever are you using?
  4. Driver50x
    Driver50x
