Projects Northrop F5 Belly Tank Racer
Discussion in 'Traditional Hot Rods' started by Superlite, Feb 1, 2023.
  1. Superlite
    Superlite
    Hey all! I am starting my second major project - A Belly Tank Racer!
    I'm an aircraft mechanic by trade, so this project is the perfect fit for me. After much research, I have determined the Belly Tank to be from an A10 Warthog (Edit - Later discovered to be from the Northrop F5 Tigershark). Attached are pictures of where it sat at the gentleman's house where I purchased the tank from. I have previously completely built and modified a 1991 Honda Shadow VT600C from stock to full custom Hardtail inspired by the Japanese bobber's of the 60's and 70's. Looking forward to this new build as I have many questions and this is my largest project to date. I have a lot of learning to do regarding cl***ic suspension and driveline components as I work my way through this build, but that's the fun part! I have made a little bit of progress so far, so I'll be uploading the rest of the pictures I have in another post or two as I begin immortalizing this build. I'm sure i'll have many questions along the way. 278460552_5280873838637690_818943477336706077_n.jpg 278539819_4964685380251577_9105679667770404221_n.jpg 278654230_4816930225085267_3657943020267496230_n.jpg 278716336_4989560854492712_7980744426539465667_n.jpg 278717347_5087032188054487_7775910368689129380_n.jpg 318245190_5106538162779246_4821852688286797328_n.jpg
  2. Superlite
    Superlite
    Here are some pictures I took the day I picked it up. I had rented a 20 ft Penske truck to pick the tank up and wondered what the cops would think if they pulled me over and gave me an inspection. Managed to get the tank home safe and sound. Didn't budge an inch on the way home. The tank itself is in perfect condition without a single dent that I can find. For now, the motorcycle lift is the perfect platform to get started. 323427266_864738088064604_4109301395413541192_n.jpg 323783073_2072216923169170_5438674292433696000_n.jpg 323638291_438318658390364_93803255425211300_n.jpg 323698090_568100111414987_8098498928363259734_n.jpg 323860369_559409829096104_4069281015530843559_n.jpg
    Lil'Alb, Jet96, JalopyJimbo and 11 others like this.
  3. Congrats on the nice belly tank.
    Dang, that is one EMPTY work shop. (This is coming from an old hoarder.) :cool:
    Lil'Alb, VF-1, Okie Pete and 7 others like this.
  4. Mike VV
    Mike VV
    from SoCal
    Super -
    Damn, your Harley would be a perfect fit for me with a "springer" front suspension !!
    Been looking for a similar built bike like yours for a while. No real luck. A couple close, but...not close enough to what I want.
    Don't have the time to build one.
    Oh yeah, nice start on your Bonneville car too.
    Keep the photos coming.
    Mike
  5. Superlite
    Superlite
    Thanks Mike, the bike is a 1991 Honda Shadow VT600C that I fully built over 9 months, with around 95% of the bike being built within the first 3 months. Life got in the way so I had to put off finishing it. I was originally going to run a springer front end but I decided to keep it more cost friendly and just rebuild the front forks. The bike is a lot of fun and is my first motorcycle. I never rode it while it was stock due to the left fork leaking into the brake caliper, and an engine oil leak. As it sits now fully customized it is my first motorcycle riding experience - Hard-tailed with a car tire!
    Okie Pete, chryslerfan55 and Ned Ludd like this.
  6. alanp561
    alanp561
    I love the tank idea and welcome to the HAMB from East Tennessee. The only suggestion I could make is that you remove the picture of the OT vehicle sitting next to your bike before one of the Moderators deletes your thread. That's a big time no-no here.
  7. Superlite
    Superlite
    Thank you. Removed, thanks for the heads up!
  8. Love Belly Tanks so i'm in. JW
    Superlite likes this.
  9. Superlite
    Superlite
    I had recently just purchased this home, and I found these wooden blocks just sitting in the shop. Wouldn't you know it, these wooden blocks are shaped PERFECTLY to the contours of the belly tank. They act as the perfect chocks for me to keep the tank stable as I deconstruct the tank to get it gutted out and split in half. It's almost like this build was meant to be!
    The right side of the tank was easy to position my cut line to get it chopped in half as there was already a welding seam from when the tank was constructed originally. The left side however did not have that welding seam. I opted for some blue painters tape and the eye-ball method. The stabilization fins on the rear are located right on center which helped me get a great starting point for laying my tape. I attempted to use some penetrating oil on the left side inspection cover on what appeared to be your standard phillips head screw... Well, they aren't your standard phillips head screw. They require a special bit to remove. You are able to get a good bite in a tightening direction however in a loosening direction the bits just slip right off due to the angle inside the screw head. I wasn't about to source a bit i'll never find in an attempt to remove screws that probably wouldn't come off anyway so I just decided to slice it instead. 324871469_574221467506243_6001366636474399311_n.jpg 325643582_1242650909681553_1037349240241865411_n.jpg 325999534_906732977009034_4919637587361942842_n.jpg 325610528_1243933262872373_6858362207007432846_n.jpg
    VF-1, JalopyJimbo, DBruce and 6 others like this.
  10. Superlite
    Superlite
    First Cuts!
    It took me six full 4" cutting wheels on an angle grinder to slice through this 14 foot long tank. My cuts on the horizontal plane weren't 100% straight but it's difficult to keep a cut straight for over 12 feet. i'll straighten and smooth them out at a later date. The inspection cover was decently difficult to cut through, as well as all the unknown baffles and weld seams and structural supports underneath. Even after slicing the horizontal center lines the top of this tank would not budge AT ALL. Looking through the fuel filler cap was the only visible point of entry for me to see what I was up against and I was able to see the rear baffle before I cut, but I couldn't see much more than that. I did know there would be baffles inside being that this tank came from a high speed aircraft and the baffles would be necessary to help minimize fuel surge as the Warthog increased and decreased in al***ude. Once I had the tank cut at the half way point I was able to use a flat tip screwdriver to pry open the skin a little bit and use a flashlight to peek inside and from there determined where I needed to make further cuts to the tank. After that I was in with a sizeable window to really see what I was up against and WOW! The engineering that went into the creation of this tank is crazy. The support structure for the hangars are beefy. I found a date inside that was labeled for January 5th, 1970, so this tank is at a minimum 53 years old. The interior of the tank has zero rust and is in near perfect condition which is incredible. This made me very happy to see... I scored a tank with no external damage or dents and a perfect inside. There are 2 surge prevention baffles, 2 fuel transfer pumps, quite a few tubes, grounding straps, etc. which all have to be removed in order for me to split the tank. I have to work from the inside out. 326163882_1569477053504009_8783928473249274140_n.jpg 326462582_643442620869167_7554844374049498929_n.jpg 326019873_1575952669516204_8173109504087937327_n.jpg 326079570_3258829521036050_8860424174480799655_n.jpg 325924520_2069847056537275_7140304665859438094_n.jpg 325946864_862522558294251_7768767842618267935_n.jpg 325985762_730689265233253_8534141048612873104_n.jpg 325926853_888848229233107_5175486392773175627_n.jpg
    48fordnut, Jet96, JalopyJimbo and 8 others like this.
  11. Superlite
    Superlite
    Powerplant
    I managed to source a 1950 Mercury / Ford Flathead V8 and a 3 on the tree transmission from a gentleman about an hour south of my workplace. The engine was just recently pulled from a 1950 Mercury Custom and i'm told it isn't 100% stock. Per the seller it runs, and the trans should shift through the gears without issue. There looks to be a potential oil leak on the trans i'll need to take care of but i'll get to that when I get to that. I know absolutely nothing about flatheads or this trans so this will be a big learning curve for me. I just about laughed when I saw the trans for the first time. I wasn't expecting it to be so small. This is all new territory (Corvette guy here). The engine came with two sets of carbs; a new set with breather filters that I was told were choking out the motor, and an old vintage set with the Ford logo on the side. It has the motor mounts, and some other miscellaneous bits and pieces. For starters I'll need to source a radiator, as well and put together my own wiring harness but that's pretty far down the road. 326964602_745082010340595_8278147667106934956_n.jpg 327006723_582290943277994_8727989723158111287_n.jpg 326978019_5907975552628615_1763281721127523830_n.jpg 326993977_648854010329227_3695984330108199210_n.jpg 326717162_895500581762105_7214941309423305010_n.jpg 326763914_5845969022138674_8757901300514888427_n.jpg 326950606_694685322112453_14557294219429815_n.jpg 326961121_531419175683926_7751783079257418210_n.jpg 327024601_3316342668639383_489455275600707931_n.jpg 327074320_873491477092941_5303938492597541730_n.jpg 327084673_1173431579984004_1819293336520959668_n.jpg
    ydopen, VF-1, hfh and 8 others like this.
  12. Superlite
    Superlite
    The rear half is separated and gutted out! Starting to make some good progress on the tank itself. The Sawzall was my friend here. I still need to work my way through the front of the tank so to get it separated with efficiency I'm probably just going to take a longer Sawzall blade and chop through the baffles and support structure. I'm really not worried about preserving the internals since I'll never be able to use this stuff. The goal is to just get this thing split! I had a crazy thought. The goal is to try and make this lakester street legal, so I may try and re-purpose the transfer pumps into either a singular head and tail light, or two tail lights or two headlights... they are already red so probably two tail lights. I'm also rebuilding the front end of a 2006 Pontiac Vibe for a family member at the same time due to a deer strike so the lakester is going to sit for a bit until I can continue. I've also got no heat in this 1500 sq. ft. garage (yet) so I only make my way to the garage on nicer days when I'm not working.
    If anyone has the scoop on a good rear end that will be relatively easy to mate to this 1950 mercury flathead and 3 on the tree trans, I'm all ears. I'm sitting inside on the computer for hours at this point researching my options because there really is no instruction manual for one of these. I'd like to run either a Ford 9" rear end or a Banjo rear (frankly anything that would work really), and my currently dilemma is figuring out what can attach to what. The goal is to be able to street the lakester and even drive it to work every now and then so I may even opt for new parts to save myself some headache down the road. I'm pretty sure i'll be welding the rear end to the frame. The torque tube needs to be shortened if I can find one, or it will need an open driveshaft conversion as well as a custom length driveshaft made. If anyone has any info methods to make the trans work with either of those rear ends I'd greatly appreciate your input! 328281616_607291161218226_6601136491922991464_n.jpg 326912476_498849332184440_7867169366643730979_n.jpg 326917601_453939706830140_5121234844393644714_n.jpg 328259100_1829297080786711_3556462453518204290_n.jpg 328128206_931898418222009_3568682422643830271_n.jpg 327455604_5851073408280220_1943977650409145689_n.jpg 328487190_3351909551739447_951918015125913719_n.jpg 328629679_573344524701700_7557372874266130803_n.jpg 328440213_895325551510550_4710233964187315937_n.jpg 326823023_1559938354472358_5333195322905044268_n.jpg 328023209_1592712371245458_6667844883166032984_n.jpg 327048349_1329769744481910_2564220605996475814_n.jpg 327048551_3479759765680543_3423400907196485918_n.jpg 327055652_910365800146888_6450622680596433109_n.jpg 326952277_698531441773392_1966540295447105500_n.jpg 328346774_845684193188268_250504100544106355_n.jpg 327720944_1615191345575593_272843892504816120_n.jpg 327653260_725374325875514_7913388126732199166_n.jpg 326721102_1644493379338250_6178456729352584044_n.jpg
    Toms Dogs, Jet96, VF-1 and 12 others like this.
  13. Just Gary
    Just Gary
    Awesome project!
    What's the tank's inside diameter at it's widest point?
    Superlite and chevy57dude like this.
  14. Since you are using the running gear you have you should check out ''Belly Tank Build, UK. Even my build ''Belly Tank Build NZ. They are all different in there approach. JW
    winduptoy and chevy57dude like this.
  15. mohr hp
    mohr hp
    from Georgia
    Wow! You're jumping in the deep end! This is ambitious. Do you have plans for this as a land speed racer, or just a street legal cruise night thingy? Do you plan to sit down in it, shoulder-wise, or with your torso more hanging out of it? Where are you located? I'm not going to pretend to know everything about A10's, but once upon a time, I was an engine mechanic on them in the Air National Guard. The weird screws are called Torq-Set, yes, they take a dedicated driver tip. That 1970 date code is extremely early, the first ones went in service in '72, so maybe prototype/test mule, or produced before the first release. All that stuff inside, not surprising to me, the plane spends a lot of time at high G's. Perhaps some of it will come in handy as you progress, so maybe hang on to some of it. Have you been to Bonneville? lots of innovative solutions to what you will face. Packaging is everything, so your motorcycle experience should be helpful. Good luck, and welcome to the HAMB!
    Toms Dogs, JalopyJimbo, WC145 and 4 others like this.
  16. brady1929
    brady1929
    Good luck. Looks great.
  17. topher5150
    topher5150
    Come on that's no fun. I would have had that thing strapped to the top of a station wagon or something just to freak people out
  18. alanp561
    alanp561
    Here's a couple of thoughts. It's an awesome journey you're starting on. You say you have no flathead experience and, it appears no experience in what's feasible with a belly tank. Maybe you should post your general location, not your home address, and you might find some HAMBsters in that area close enough to help you out with good advice on your powerplant and driveline. You might even find some knowledgeable Bonneville types close to you. Just saying.
    chryslerfan55 and 26 T Ford RPU like this.
  19. GTS225
    GTS225
    To my eye, the size says headlight(s). But....if, in your state, you can run a single h/l on a 4-wheel vehicle, great. Now, if you have to make a single front steer wheel (trike) and license it as a motorcycle, well.....then a single headlight would work.
    As a sidebar.....are you going to keep the horizontal stabilizer out back? If so, that seems to be an excellent mounting base for "navigation" lights, utilized as tail/brake/turn signals. Know where you can get A-10 nav lights? (wink)
    I'd tell you to get yourself a Mopar 8-3/4, but I'm a Mopar guy. Besides, that's an open drive axle, and would require you to convert your trans to an open shaft..
    Then you're going to want a suspension system, even if it's only about 4" of travel. That thing is going to beat your backside up on the street without suspension.
    NO! You have a problem with whatever axle you opt for, and you'll be kicking your own **** all the way to the end of the block. Even if you don't build a suspension system, make the third member bolt in. Build whatever stout brackets you have to, but make it removable for service.
    So you don't have a torque tube to work with. At this point, I'd be inclined to convert the trans to open drive shaft. It'll be easier, (I think), in the long run for your build.
    Just my opinion.....Roger
  20. 51504bat
    51504bat
    You had me at Warthog:cool:. When it comes to engine mounts you might want to consider using truck water pumps with the side tabs to make things easier. Or not. Problem with using truck pumps is that they are wide belt and the Merc you have is narrow belt. You can change the crank pulley and generator pulleys to wide belt ones. Or, if you can find them, a set of earlier Merc pumps which are narrow belt but have the mounting tabs similar to truck pumps. Note, the mounting tab heights are different on the Merc pumps as opposed to truck pumps but that shouldn't be an issue since you have to fabricate how they attach to the frame. @alanp561 makes a good suggestion about adding your location to your profile. Looking forward to more updates.
  21. squirrel
    I think this is the only tank I've ever seen on the street. B'ville 2009
    Jeff34, VF-1, Jet96 and 13 others like this.
  22. Mike VV
    Mike VV
    from SoCal
    Wow...really missed that one, didn't I ?
    In my defence, the engine detail is difficult to see in the shadows.
    But yeah, great work in any case. Looks very good.
    Many years back, I had one of those Suzuki Intruders. The engine is painted silver from the factory. I painted mine flat black, not to fool anyone, didn't even think of that, but just because I didn't like all of that silver. The tank and fenders were a dark blue. All of a sudden, Harley guys started waving !! I wondered, what the hell. Then remembered, that from 20ft away, it's just a tall V-Twin, and you really can't tell what engine it is !!
    The damn thing was...it had NO power. Even for an 1100cc engine, it was huffing and puffing to make it to 100mph !
    Mike
    Superlite and chryslerfan55 like this.
  23. chevy57dude
    chevy57dude
    Please keep the stabilizer fins whatever you do.
    Jet96, WC145, Superlite and 1 other person like this.
  24. Bearing Burner
    Bearing Burner
    from W. MA
    I understand these tanks were used for cross country or cross ocean flights. The record holding lakester at Bonneville in F/BGL uses one of these tanks.
  25. This was at the Nugget show in 2019. JW
    VF-1, hfh, 48fordnut and 8 others like this.
  26. My build as it looks now. JW
    PINEAPPLE, VF-1, hfh and 11 others like this.
  27. Truckedup
    Truckedup
    Remember I one built awhile back...full suspension....Drove it on the street as you see it....well, not too much,lol.... 15091669491_549274beec_c 2.jpg 14349798620_f6afa3bac0_c.jpg
    VF-1, Jet96, tractorguy and 5 others like this.
  28. Blues4U
    Blues4U
    from So Cal
    Here's a different take on the usual belly tanker, this guy placed the engine up front.
    51 mercules, VF-1, hfh and 10 others like this.
  29. mohr hp
    mohr hp
    from Georgia
    I'm with GTS225, You gotta have suspension if you want to drive on the street. The thing will bounce uncontrollably in washboard turns and generally beat you to death. Same with welding the rear end to the ch***is, how will you fix anything that may go wrong? Might consider an IRS, then you can eliminate a driveshaft altogether, thereby shortening the whole package at least a foot.
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Subscribed - as soon as I read your intro and description.
    I'm on my second Honda 600 Shadow - superb little bikes they are. I owned one for a year before I realized it had two spark plugs per cylinder.
    That raises another philosophical question regarding OT postings (sorta tongue-in-cheek LOL):
    If the belly tank came from a 1970 aircraft does that make it Off Topic???
    rbrewer, Superlite and 26 T Ford RPU like this.
