Projects Northrop F5 Belly Tank Racer
Discussion in 'Traditional Hot Rods' started by Superlite, Feb 1, 2023.
  1. Truckedup
    Truckedup
    Yes, some sort of suspension....This is what I did, it works well enough for the occasion ride.....and a driveshaft with a slip joint made from 47 Jeep parts...and a home made open drive oil seal conversion... 13134503124_59e0d5b9a1_c.jpg 12372302504_f4442e9dbe_c.jpg
  2. Paging @Mart to the front desk. @Mart to the front desk.
  3. Superlite
    Superlite
    Thanks. That's actually something i haven't done yet as I have just managed to make my way inside the tank. I'll get back to you with that answer when I can.
  4. Superlite
    Superlite
    I live out in Maryland so no land speed racing here. The plan is to have it street legal and be able to take it to car shows and events in the local area. At the moment, I'm planning on a full canopy that will be easily removable as to have the option to choose how I want to ride in it. Top on or top off. Thanks for the tip on the Torq-set driver bit. They are all over the tank and I'll probably source one of these in the near future. I haven't been to Bonneville but I'd love to. This is an ambitious project for sure, but I enjoy the problem solving that goes with it and overall, really enjoying the process so far and looking forward to all the learning I'll be doing along the way.
  5. Superlite
    Superlite
    Thanks for the thoughts Alan, I've only seen two of these lakesters in person so my experience with what's feasible with these is next to none, but I'm sure it will all get figured out no problem!
  6. 282doorUK
    282doorUK
    Subscribed, great project with so many challenges to solve, and those tail fins are so cool!
    Superlite likes this.
  7. Superlite
    Superlite
    For the headlight area I was thinking about trying to recess the headlights and turn signals into the tank to stay true to the contours of the tank. The more I think about it, the more I want to go this route. The horizontal stabilizers are here to stay! I can't get rid of the big tell tale signs this tank is from the legendary Warthog.
    An open shaft conversion is on the radar for sure unless I can find a torque tube that would work with the 3 speed. I have found a shop that sells the open drive shaft conversion for a banjo rear end, so if I can find an open drive conversion for the 3 speed, i'll get a custom shorty driveshaft made.
    I don't even know why I said weld the rear axle to the frame, my intention was to weld brackets to the rear axle and bolt those brackets to the frame to allow for removal of the hardtail. I'm used to riding the hardtail motorcycle, so this shouldn't be too different. I'll just air down the tires and get a cushy seat. It's not like it's going to be a daily driver anyway, just a fun vehicle to take me back and forth to shows and whatnot. There will of course be front suspension.
    At this point, I don't have a torque tube or the rear end, so coming up with a plan before I buy anything and trying to see what would work together. Appreciate all the insight!
    chryslerfan55 and Just Gary like this.
  8. Superlite
    Superlite
    I'll look into the water pump suggestion further. Whatever I do, I'm going to try and make it so the engine is as serviceable as possible. Before I weld anything together I'm going to do my best to make things as accessible as possible without removing the engine in it's entirety. I don't want to screw myself over if at all possible lol. The engine supposedly runs well as it sits so I might not be making any changes.
  9. Superlite
    Superlite
    Love that this is a two seater! Great tank
  10. Superlite
    Superlite
    Wasn't a big fan of the silver and chrome either. Had to go darkside with the bike. I love all the "motorcycle wave" all the bikers do to eachother. Riding is a blast. My 600cc is pretty much an around-town bar hopper but can do highway speeds around 65-70 fairly well. I changed the rear tooth sprocket to ***ist in highway speeds but the bike is still SCREAMING at that speed. Definitely an experience.
  11. Superlite
    Superlite
    Stabilizer fins are here to stay... they won't even see a tool.
    Toms Dogs, WC145 and chevy57dude like this.
  12. JMHO but if you've got your mind set on a rigid rear end, why complicate things by trying to use a banjo? The center section will be inside the tank, so just use a rear end that will fit and mate it to the open driveline Merc trans.
    chryslerfan55, alanp561 and Superlite like this.
  13. Superlite
    Superlite
    Looks great! Nice work! What engine / rear end combo did you end up going with?
    JalopyJimbo and chryslerfan55 like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    Willys Jeep 4 cyl. with English Zephyr rear, 3.55:1. JW
  15. Superlite
    Superlite
    Not sure why I said weld the rear to the frame. My intention was to weld brackets to the rear end and bolt the brackets to the frame. Would be hard-tailed, but removable. My motorcycle is a hardtail so it shouldn't be too different. I'll just do what I always do and keep the tires aired down a bit. There would be front suspension, but then again I can't imagine this getting driven too much. Really to shows and on nice days, the occasional ride to work and weekends. I'll just make sure to get a comfy seat cushion. Not like it will be a daily driver! An independent rear suspension is something I haven't actually thought so I'll be sure to do some research into this. Rear suspension would be a nice luxury.
  16. Superlite
    Superlite
    It's a great bike, and has been an awesome first bike to learn to ride on. Pretty cool to say my first ever motorcycle was one I built myself... I've never even rode on a motorcycle with a proper motorcycle rear tire. I'd have to say this build is perfectly on-topic with the spirit of HAMB with regards to creating and modifying hot rods and cl***ics. This build fits right in lol... Cheers mate! Looking forward to sharing my progress with everyone here.
  17. mohr hp
    mohr hp
    from Georgia
    It would be a haul, but there's land speed trials in Loring Maine. But then you'd need a ton of safety stuff....
  18. mohr hp
    mohr hp
    from Georgia
    An alternative suspension would be a swing arm/engine cradle set-up, like Little Red Wagon or Kent Fuller's Magicar FED. The engine/trans/diff all swing together on a pivot. Lots of unsprung weight, but better than no suspension at all. In Gaithersburg, there was Bob Rizzoli, of RCD. He built a more sophisticated version of this as a drag car. (Mercedes!) If Bob is still around he could be a great resource, but I don't know him.
    Superlite and chryslerfan55 like this.
  19. GTS225
    GTS225
    Coolness. And I really like the direction you're (mentally) headed with frenching the lights. Like the pic posted by Squirrel above, it is sooooo reminescient of the P-38 ****pit pod. The fact that you're keeping that iconic rear stab will really make this an eye-catching build.
    Well, if you're going to solid-mount the rear, it's conceivable that you could make it without driveshaft. Convert the trans for a u-joint that matches whatever rear you use, and slip them together on a single u-joint, or even just a slip yoke of some type, as long as you don't have an angular mismatch between the trans output and the pinion. (The U-joint connection would help in that regard.) Make the engine mounts so they'll slide a few inches, in order to dis-engage the yoke/u-joint, and you shorten the package while keeping some reasonable method of removal for service to the major components. ('Course, that only works if you rear-mount the engine..)
    I wondered if you had made a slip-of-the-tongue, so to speak. I also wonder if you couldn't incorporate some kind of bushing into your mounting. Either rubber or poly. That would give you a tiny bit of suspension and working room for any mounting mis-alignment.
    Just my thoughts.....Roger
  20. 282doorUK
    282doorUK
    Two belly tankers racing on Bridlington beach hit a cross rut that developed in the sand side by side, solid rear ends launched them way up in the air, I bet that hurt!
    My racer has around 3" of rear suspension and I faired a lot better although I was off the seat for a bit.
    Just something to think about if on the street, joints in the surface and such.
    I clipped this still of another run over the rut from a video and he's on the way down here!
    That's me in my racer beside the truck top right :D
  21. Bearing Burner
    Bearing Burner
    from W. MA
    Maryland is not that far from LSR at Loring ME. People have come to race from Florida .The world's fastest sit on motorcycle record was set at Loring by a man from Florida at 311 MPH.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    After about 90 minutes on the back of ours my wife says she's come down with a case of "buzzy ****".
    caseywheels likes this.
  23. jaracer
    jaracer
    A non sprung rear axle on this vehicle is a lot different than a hard tail cycle. The difference is un-sprung weight. In this vehicle your un-sprung weight way, way more than on a cycle.
  24. Truckedup
    Truckedup
    If your vehicle stays below 130 you need just a Snell rated helmet in a non convertible.....I do not know if this 130 cl*** is valid for a vintage car... Loring Timing ***ociation rules can be seen on their website...
    I race there and still have current speed records on a vintage Triumph bike..The constant changing often gusty winds and weather can present challanges...
    I would like see a few street driven traditional hot rods running there...
    tractorguy and 26 T Ford RPU like this.
  25. Superlite
    Superlite
    Got home from work this morning and decided it was time to get this tank split in two. Tool of choice? Sawzall. I laid out a couple towels to protect myself from some sharp edges and hopped in the tank and laid down belly first. Was barely able to squeeze my arms in through the center under the main support structure where the tank would hang from the Warthog's bomb racks. I was able to (very uncomfortably I might add) stretch and reach far enough forward inside the tank to get the forward baffle sliced through horizontally. I first started the cuts from the outside before hopping in the tank to cut from the inside out. It was very loud in there lol. For all those pesky Torq-set screws, I've been taking the cutting wheel to them and giving them the flat-tip conversion. Now that the tank is finally split in two, I'll finish gutting out the tank next time I can make my way out into the garage. I have to say that I cut the tank in the perfect locations for separation with regards to the front nose cone and the rear end before the horizontal stabilizers. Almost time to get started on the frame. Good times ahead! I was able to take a proper measurement of the tank and the outside diameter is right at 22 inches. I didn't take a measurement of the wall thickness of the tank, but the inside diameter looked to sit right between 21 - 5/8" to 21 - 7/8". The 1950 Mercury Flathead should JUST fit inside with around an inch or so of room to spare but that will depend on how I can get the frame situated inside the tank.
    I'll be picture heavy in this build. One thing that bugs me in a lot of build blogs is lack of pictures to tell the whole story so I hope you all don't mind. I love do***entation when it comes to stuff like this so there will be pictures aplenty. It's almost frame time! 327649559_501852145427056_6471687846334451175_n.jpg 327827588_1160580447930123_7597018467270182574_n.jpg 327910794_1251988502061312_6689752508558995164_n.jpg 327916981_509984454573531_2356328219693443050_n.jpg 328138717_1849632755391597_4522169785980810132_n.jpg 328161629_568204702022251_8713973491182246314_n.jpg 328328580_1203420920546457_2896756035138060921_n.jpg 328405436_3512298799006472_4681061396369201199_n.jpg 328583192_754598672941815_8854393122862759911_n.jpg 328630657_6486259988055072_3997319522859708354_n.jpg 328634709_1343900756399354_6481985405074716933_n.jpg 328654946_710357544094940_5695341409595132887_n.jpg 328707360_701119251502020_6261742711424000054_n.jpg 328773685_2218472184991879_2763101265621779666_n.jpg 328844955_706332530960343_7567823066515573609_n.jpg 328883864_541327094726860_9133261086380137785_n.jpg 328924376_3403366729992956_2262587245683218264_n.jpg 329005432_848611149557814_6200865063437236161_n.jpg 329073431_877582486899519_7877215510357952519_n.jpg 329104358_885002992616393_7937089918608588052_n.jpg 329121180_553248583424238_6595669397349840908_n.jpg 329149622_1171270686910671_5186726341243474960_n.jpg 329161525_584781856839746_5112164298849123067_n.jpg 329173158_723420102708389_2278206731255407801_n.jpg 329187059_972582230769125_450528945897848753_n.jpg 329211118_3460470380890071_2181975298070123000_n.jpg 329214759_3432875750367669_8609439106519983057_n.jpg 329224011_1637436546679797_678126957106068648_n.jpg 329292149_560872372640659_5721329962661794459_n.jpg
  26. Superlite
    Superlite
    Was able to take a proper measurement this morning. The outside diameter of the tank comes in right at 22 inches at it's widest. I didn't take a measurement of the tanks wall thickness, but the inside diameter looked to be around 21 - 5/8" to 21 - 7/8' thick. The 1950 Mercury Flathead I picked up should JUST fit inside with maybe an inch to spare. We'll see how it lines up after I get the frame pieced together.
    Toms Dogs and Just Gary like this.
  27. 26 T Ford RPU
    26 T Ford RPU
    What type of ch***is are you going to make? That may make or break it as you will run out of room fast. You will need to work out how much room you need first, mine is 36'' at the widest point...still tight. JW
  28. Superlite
    Superlite
    Planning on 2x3 1/8" steel channel stock at this point. With my welding skill level it will be easier to weld rectangles and square shapes as opposed to a round tube ch***is. I'm not a big fan of welding round objects. I'll also be able to use the garage floor and the flat shape of the 2x3 rectangles to help me keep a rectangular ch***is straight and level as I put it together... I also think the ch***is I create will be of higher quality and I can make sure it is as symmetrical as I can. Since I've only got 22 inches of space, less than that for the ch***is since it will be located lower, I'll be sure to take plenty of measurements. The tank is 14 feet long, so the wheel-base should come in somewhere around 11-12 feet in length.
    26 T Ford RPU likes this.
  29. Magfiend
    Magfiend
    That definitely needs a Halibrand V8 quickie...
  30. Marty Strode
    Marty Strode
    I did this P-38 with similar power train as you are planning. It took 2 sets of T rails for the frame. Packaging of the necessities to make it complete, takes some juggling. Good luck with your project. IMG_7560.JPG IMG_0941.JPG IMG_0944.JPG
    Marcia, bymanr, Toms Dogs and 9 others like this.
