Technical Blower & carb
Discussion in 'Traditional Hot Rods' started by Shoovel, Feb 4, 2023.
  1. Shoovel
    Shoovel
    Folks,
    I have a “new to me” 30 Model A Hot Rod. Unfortunately the previous owner did not have a build sheet on the car, so I have to be kinda detective. It has a Flathead, Navarro Heads with a 4-71 blower and 2 Holly 94 carbs with non-progressive linkage. I have to rebuild the carbs due to gaskets leaking. Carbs are not dis***embled yet. I’m just wondering what jet sizes to run and should keep a power valve in them.
    Thanks for any ***istance and/or suggestions.
  2. 26Troadster
    26Troadster
    welcome to the hamb, nice looking flatty.
    Shoovel likes this.
  3. oj
    oj
    I wouldn't be changing PV or jetting until you've driven it when it gets warm out. Keep in mind that 'leakage' may not be a gasket thing, when you shut the engine off the last few dribbles that come out of the boosters fall on closed throttle blades and some raw fuel will follow the shafts out the carb and look like leakage. Over time it'll look like **** but its a fairly normal thing depending on how loose the bores for the throttle shafts are.
    That looks like a great little setup.
  4. solidaxle
    solidaxle
    from Upstate,NY
    I would suggest Joe Abbin's book "Blown Flathead".
  5. big duece
    big duece
    from kansas
    Maybe look into a temporary wide band sensor to check existing A/F ratio, look at plugs before major jet changes. I can't remember if the 94s need to be (or can) set up for boost. If you need more cfm, check out the Stromberg BIG 97s, and don't have to worry about power valves blowing out.
    Shoovel likes this.
  6. 1930 turbo
    1930 turbo
    from pa.
    I like your blown flathead, know your going to enjoy it. We have a turbocharged flathead, and after a lot of trial and error ended up with no. 57 jets, and 5 in.Hg. powervalves, and 1 3/8 float setting . Be sure to run a fuel pressure regulator set at 3 lbs. We run two 94 carbs with a stock choke in the rear carb only. Have fun with your new project!
    Shoovel likes this.
  7. Hollywood-East
    Hollywood-East
    Damn.... That's a $weet set-up!
    Whoever put that together, I ***ure You, Knew how to jet it.
    Got any pics of the car..?
    Shoovel likes this.
  8. WB69
    WB69
    from Kansas
    Agree with oj and big deuce. Most likely the previous owner has it at the least close. Drive it/run it before making any drastic changes. Sensor is a good thought. Cool looking setup! Good luck with it.
    Shoovel likes this.
  9. If it was a running motor I would not change the jets or the power valve (if it even has power valves).
    Remember this simple truth, a wheel only works if it is round. No reason to reinvent it.
    Cool project BTW. I am not Mr Flathead but blown flatties are cool, I don't care what anyone says.
  10. Shoovel
    Shoovel
    282doorUK, 26Troadster, WB69 and 3 others like this.
  11. Hollywood-East
    Hollywood-East
    Shoovel likes this.
  12. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Your model a is one of the best looking A’s I have ever seen. Nice big fat Ascot looking tires on a widened set of spokes. Flatmotor with a blower makes it look “all business”—— pretty decent look for the headers——all adding up to a very cool A model. Flatheads Forever!!! 7B7676B7-A4DC-4834-B069-22D601412BE1.jpeg 2F99D788-ABD1-4B6F-BE75-00BECEEDE512.jpeg
    Shoovel and 26Troadster like this.
  13. BamaMav
    BamaMav
    from Berry, AL
    Sharp car!
    Shoovel likes this.
