Hot Rods need help with 1963 Corvette fuel injection setup...
Discussion in 'The Hokey Ass Message Board' started by tred, Feb 3, 2023.
  1. tred
    tred
    I have a '63 Corvette with a Rochester fuel injection setup. Came to me not running. Good ignition system throughout, good compression on all cylinders. Fresh fuel. The Fuel injection ***embly has been cleaned and rebuilt, including the gear pump and drive cable. The current status is a crank / no start condition. Will run on starting fluid, but is not delivering fuel. Verified that the drive cable is being turned by the distributor. Looking for any ideas on the next direction to get this car going.
  2. bill gruendeman
    bill gruendeman
    I don’t know anything about Rochester f/I, but do you get fuel pressure? Pull a fuel line off and crank the motor.
  3. Flatrod17
    Flatrod17
    When mine didn't start it ended up being the cranking signal valve. I believe they were 63 only. But I could be wrong, that was 47 years ago. Something about vac not being enough.
    jimmy six likes this.
  4. miker98038
    miker98038
    elgringo71 and BJR like this.
  5. tred
    tred
    thank you everybody, mine doesn't have a crank signal valve, and yes, good fuel pressure to the Rochester.
  6. Dennis D
    Dennis D
    Jack Podell in Ok. would be the guy to contact. He has been restoring the units for a long time and could point you in the right direction. I don't have his contact info anymore, maybe a google search would work?
  7. jaracer
    jaracer
    Unless you rebuilt the unit, I'd be talking to the guy who did.
  8. patterg2003
    patterg2003
  9. Dan Timberlake
    Dan Timberlake
    .From the rochester manual in post 4. specs go to 1962.
    elgringo71 likes this.
  10. Do not run it on ethanol fuel! If it was in the past, the metering system might be ****ped up with disintegrated "rubber" parts. That happened to my Rochester FI a few years ago. I had to completely dis***emble and clean everything. I now use AVGAS without issues. If you have access to non-E fuel, use that.......we have 90 octane non-E here, but my 327/375 HP engine (12.5:1 CR) needs higher octane. You might get way with 90 if you drive it sanely.
    If you need new gaskets, etc., as noted above, Podell should be able to fix you up. I have not seen any Ethanol-proof parts though.
  11. tred
    tred
    That's the first thing I did.
  12. miker98038
    miker98038
    Missed that, sorry. The one I bought years ago had the late model info attached. I didn’t look far enough. Apparently you still have to pay for the 63-65 unit manuals.
