Projects Curtiss Aero V8 powered Fiat 503 project.
Discussion in 'Traditional Hot Rods' started by edwardlloyd, May 11, 2019.
  1. onetrickpony
    onetrickpony
    from Texas
    My dad had 1918 Velie touring car when I was a kid in the early 60s. It was sold to a restorer at some point, maybe in the Houston area.
    Stogy likes this.
  2. jimpopper
    jimpopper
    That's a project that Jay Leno or his crew could advise you on. He's been around some wild old creations.
    Stogy likes this.
  3. lippy
    lippy
    from Ks
    Velie also made aircraft engines. Early Monocoupes used them, My Dad learned to fly in one. On a Waco 9 you had to watch out for water leaks out of the radiator witch was mounted above the fuselage and would drip water on the magneto. Instant forced landing. Waterpump packing around the shaft would leak also like any early engine. Be sure to safety wire the plug wires also. :)
    Stogy, Outback and 41 GMC K-18 like this.
  4. Outback
    Outback
    from NE Vic
    Stogy and 41 GMC K-18 like this.
  5. alchemy
    alchemy
    Guys, Edward closed his shop a few years ago and isn’t a HAMB regular anymore.
  6. 41 GMC K-18
    41 GMC K-18
    Thanks for the heads up @alchemy.
    What a bummer that he closed his shop, and isn't on the HAMB any longer. I will delete my post as it appears that none of it was seen by Ed.
    Thanks from Dennis.
  7. Outback
    Outback
    from NE Vic
    Thanks @alchemy I wonder if the project progressed.
    41 GMC K-18 likes this.
  8. uncle buck
    uncle buck
    Essentially yes. On the Velie that I posted there was a custom adapter made to attach a modified flywheel.
