Technical 1939 GM door lock tumbler removal?
Discussion in 'Traditional Hot Rods' started by AGELE55, Dec 2, 2022.
  1. squirrel
    I don't know how it works. Huh.
  2. ClayMart
    ClayMart
    I wonder if this might be some kind of a non-OEM lock cylinder that came pre-***embled, coded and with new working keys? A cheaper alternative to having new GM cylinders recoded? Something that a used car dealer might have favored? Maybe it only uses 2 or 3 tumblers in the positions where those plugs are.
    o_O
  3. AGELE55
    AGELE55
    Ahah! I got my keys in the mail, which I had made using the key code stamped on both the handle shaft and cylinder shaft. They work perfectly. Once I inserted the new key, the tumbler ***embly easily slipped out of the cylinder housing. Now I can see the bottom of six springs holding in the tumblers/ “discs”.
    Now I’m trying to talk myself into tearing it down further….lol. I only ordered one set of keys ($9.50 to the door). Now that I know the key is the key to dis***embling, I’ll order another set for the other handle. Why I didn’t just get off the 9.50 in the first place will be a matter of discussion for generations to come. E6EC1107-EEC8-4219-A793-B2D5800A4047.jpeg 0507434E-7B29-4263-A9E1-216EECCB3010.jpeg
    squirrel likes this.
  4. squirrel
    thanks for the follow up!
    you ordered code cut keys, right? Instead of cutting them yourself from blanks? :)
  5. AGELE55
    AGELE55
    Yes. I got them from a guy on eBay. Great deal. 4A3FE9D6-1CEB-4D11-BCC6-9E85B1CE5A8F.png
  6. AGELE55
    AGELE55
  7. squirrel
    yeah, it's one of those things you have to hold in your and and play with, to be able to understand it.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    $9.50!, man the last time I had a key cut using the numbers was in the mid 80’s for my 56 at that price. Today, if you can find a lock smith in the Los Angeles Ca. area that knows what your asking for wants $60.00 for just the first key.
    AGELE55 likes this.
  9. AGELE55
    AGELE55
    I had called a couple local locksmiths about getting keys before I figured out the key code thing. They were saying $80-150 "IF" they could figure out how to do it. Thanks to replies from HAMB'ers, we're looking good.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I failed to say that quote was some 5 years ago when I thought I had lost my key. Another detail about the key made in 80’s was done with a key cutter that the lock smith dials into it. The high dollar key quote was to take apart the lock cylinder to make the key per the pins.
  11. AGELE55
    AGELE55
    As a follow up to my key code adventures..
    I keep finding this same GM key code chart, but this is only the first page, which ends at 8284. Per the header up top, the chart should show all codes from 8000- 9499.
    Anybody ever seen the rest of the codes?
    Somewhere in this cluster of a shop are some old 55 key cylinders from which maybe I can rob some wafers. 28D07F3A-D83E-43DE-8D6F-C1C848AF532A.gif
  12. squirrel
  13. 1971BB427
    1971BB427
    from Oregon
    That guy is totally wrong on his description of early GM door locks. His description is for later 50's where the lock was in the door, not for those where the locks were in the handle that he says are 36-49. Not sure I'd trust his info if he doesn't even know where the tumblers located in those years.
    AGELE55 likes this.
  14. AGELE55
    AGELE55
