Technical 471 gaskets?
Discussion in 'The Hokey Ass Message Board' started by choppedtudor, Feb 6, 2023.
  1. choppedtudor
    choppedtudor
    simple question, I just swapped out the rear bearing caps on my 471 GMC blower and realized there are NO gaskets under the bearing covers. Is this normal? I know I have seen flat gaskets and also 0-ring grooves in some caps...mine has neither. Are they really needed? 100_2399.JPG
  2. 24riverview
    24riverview
    I just use a little silicone on mine.
    choppedtudor likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Loc***e makes a specific product to eliminate a gasket.
    SEAAIRE354 and Desoto291Hemi like this.
  4. choppedtudor
    choppedtudor
    yes, I know all about the liquid gasket alternatives, but is it really needed?
  5. Jmountainjr
    Jmountainjr
    Does your blower have sealed bearings on the rear?
  6. gimpyshotrods
    gimpyshotrods
    Maybe.
    So long as the mating surfaces are all milled perfectly smooth, you can probably do without.
    The rear bearings should be double-sealed (both sides), so that will prevent most leakage, so long as you are not running extreme boost, and the covers take care of the rest.
    Gaskets, if you really want them, can be had from most blower parts vendors.
    I would use Loc***e 510, id I did not have caps with o-rings.
  7. choppedtudor
    choppedtudor
    yes, the bearings are sealed but still weep a tiny bit of red grease. I guess if the caps leak I will clean them up and silicone them with a little 510. The surfaces are clean and flat. I don't want to 'glue' them on and damage the magnesium later trying to remove them. I also see that Loc***e recommends a primer when 510 is used on mag parts....that would SURELY glue them together and make it difficult to remove.
  8. Jmountainjr
    Jmountainjr
    If the cover weeps get paper gaskets, either from the local Detroit Diesel shop or your favorite blower shop, and install them with a light coat of grease. Should seal and be easily removable.
    Desoto291Hemi and mad mikey like this.
  9. choppedtudor
    choppedtudor
    yes, I think paper will be the BEST way to go.
  10. DDDenny
    Sure, we all like a clean engine but there's nothing wrong with a "rough around the edges" engine with a blower!
  11. choppedtudor
    choppedtudor
    who said I like it clean? LOL My carbs leak, my oil pan drips, my beer spilled...
    mad mikey and winduptoy like this.
  12. hemihotrod66
    hemihotrod66
    If your sealed bearings weep a little make some paper gaskets out of an old brown paper grocery bag if you can find one and be done with it....Otherwise no gaskets are needed...
  13. mad mikey
    mad mikey
    Use the paper type gaskets from a blower shop of your choice. I have them on mine , they never seep and I run quite a lot of boost.
