Projects jumping right in here
Discussion in 'Traditional Hot Rods' started by Leadbeater, Feb 20, 2020.
  1. Atwater Mike
    Atwater Mike
    When we moved here, there were F100s in fields... '46-'48s sitting, much to choose from! I bought 2 '27s, a tub and a roadster pickup, $550.
    Place is full of idiots, nobody building. Yep. Idiots one day seemed to all gang up and JUNK everything!
    Woe is me... Lucky I got those '27s!
    Okie Pete, Outback and winduptoy like this.
  2. Leadbeater
    Leadbeater
    blew it apart yesterday and spent the whole afternoon welding up cracks and holes and tweeking. 1/4s back on for good. tomorow fit up the back panel and decide on some tail lights. then fit trunklid . im sure thinking about going real redneck hillbilly style and useing barn door hinges on the trunk lid. what yall think about that?
    winduptoy likes this.
  3. Dick Stevens
    Dick Stevens
    I think that would be a terrible mistake, that would be right in place on a rat rod but not on a hotrod!
  4. Leadbeater
    Leadbeater
    well shes gona be prity ratty allready. who has any good wierd ideas for tail lights? ive got a ton of stuff to choose from leaning towards a set of 1958 chev station wagon tail lights at the moment.
    chryslerfan55, winduptoy and Stogy like this.
  5. Leadbeater
    Leadbeater
    took me a long long time to get this far. these poor 1/4s been bent and twisted every which way x 10. wow it was a fight. still far from perfect. trunk lid has a tweek in it still have to get that sorted. progress is progress tho i made my choice on tail lights anyways
  6. This thread fell in my lap this morning, cooler than a prairie snowfall. Nice work, you need to post some of this over on the Canadian bacon thread. I am going to subscribe cause it might help move along with some of my piles. 5FB23FE2-01E2-4C4D-AAD7-D64F56A16491.jpeg
  7. SS327
    SS327
    May I say you picked a perfect set of tail lights!
  8. Leadbeater
    Leadbeater
    i wanted something old, but not something everyone has or does. not sure if i hit the mark or not. they were not easy to find, and i have had them on the shelf a while. next is a trunk lid hold down. have to figure something as factory one isnt gona work
    chryslerfan55, Outback and Stogy like this.
  9. To mount your trunk lid, the 46 to 48 ford use this for a hinge, nice and simple, but still looks like something. You likely could find something similar on an old fridge or ice chest. Original ones would not be so shiny. 26F9DC8D-A3A5-47CC-89C9-4F64ABCDB7C3.jpeg
    chryslerfan55, SS327, Outback and 2 others like this.
  10. Leadbeater
    Leadbeater
    Yes i see those to. Gona look for a set
    Okie Pete likes this.
  11. Leadbeater
    Leadbeater
    found time for a bit more work today. built a brace to go under the cross piece thay the trunk lid runs into. no press so did it the old fashioned way cut bend weld. compound curves are fun. going to bolt in a brace and an X to the sub frame and tie it together, use that as a header to separate the p*** section from the trunk
  12. Leadbeater
    Leadbeater
    fueltank box built and inplace. used a 12 -15 gallon boat tank. started building the header to separate the trunk area from p***enger section. got a bunch more tin fabbing and braceing to do at the back yet but comeing along
  13. atch
    atch
    I like the boat fuel cell inside the steel box idea.
    Stogy likes this.
  14. Leadbeater
    Leadbeater
    this is the second time ive used the idea.
    Stogy likes this.
  15. Leadbeater
    Leadbeater
    well a bit more got done today. havent had to much time to work on things. some gauges in , ignition and starter ****on all wired in and tested. actually flashed it up today and made some boom. made me feel good anyways. next is to fab up something for the top of the 1/4s to strengthen it and bring it up to the height of the doors . any ideas?
  16. 2Blue2
    2Blue2
    Starting to really look like something.
    Keep hauling home old iron.
    Daniel Dudley likes this.
  17. Leadbeater
    Leadbeater
    trunk lid hinges on today and hole drilled for prop rod . some might not like the barn door hinges but i think they fit the job prity good
  18. Okie Pete
    Okie Pete
    Thank You for posting Your build and Your cool rides . Keep building and saving out iron
  19. Nailhead A-V8
    Nailhead A-V8
    If I lived in an area where I could stroll out into virtually any field or gully and s****e together enough vintage tin to build hot rods I'd be busier than a one legged man at an ***kicking contest!!
    There is usually a wooden combing from factory around that area...semi round on the backside flat on top...which is what they nailed the top skins to for Dr.'s/Business coupes
    Can't wait to see what you do with the Pontiac roadster next month! Lol
  20. Leadbeater
    Leadbeater
    yes im going to bend some 2-1/2" tubeing i think to go around the top and weld it in. the top of the 1/4s were not cut uniformly so there will be lotsa trial and error. i did cut off the tops of the B pillars today and remove my squareing frame. startin to look more like a car every days. i havent decided if im going to knotch the window frame and tilt it or leave it. kinda likein this look as is
  21. Outback
    Outback
    from NE Vic, Oz
    I have a set of quarters that we're ute'd thanks for the inspiration & for keeping us in the loop
    Stogy and Nailhead A-V8 like this.
  22. Nailhead A-V8
    Nailhead A-V8
    Looks awesome! I see it with the visor on, about a 4" top chop, new chopped door tops and I gotta say I've always liked the idea of a full folding roof on one of these...like a 3 window convertable
  23. Leadbeater
    Leadbeater
    today was final fit up on trunk lid and add a handle. havent figured out a latch yet. it looks prity good compared to what it looked like to begin with. far from perfect but im happy enough. gotta weld shut the rumble seat latch hole yet to, but think ill leave the bullet holes haha. built the plywood header for the divider between the trunk and p*** cabin. t******* and screwing it inplace tomorow
    Okie Pete, Outback and chryslerfan55 like this.
  24. Tim
    Tim
    from KCMO
    Just found this this morning. I killer speedster and now what looks like a sport coupe?
    Adding this to the list of threads to catch up on!
  25. Leadbeater
    Leadbeater
    not much done this last few days. wireing strung for tail lights. divider panel finished. built a vent line for the fuel tank. few small things. next week we tackle the tops of the 1/4s to the B pillars. gotta fab up something in there. then maybe even some seats !
  26. Leadbeater
    Leadbeater
    well a bit more fabing and building. built the braceing for the B pillers to strengthen them up. more cut cut cut bending. turned out good and strong so im happy. i didnt bother grindin off the welds and that will all get hidden. now to fancy up the tops with something. not sure what ill use there.
    seat fitting tomorow!!
    Okie Pete, Nailhead A-V8 and Outback like this.
  27. Outback
    Outback
    from NE Vic, Oz
    Looking good!
  28. Leadbeater
    Leadbeater
    late 60s ford econoline van seats. need to trim down the original mounts but they look the part
  29. jonboy1
    jonboy1
    Nice Speedster!
