Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Marty Strode
    Marty Strode
    My friend Brent McMullin, who has handled all of my body work for over 30 years, came today to undercoat the '40 pickup cab and fenders. I love it when everything goes as planned. IMG_9927.JPG IMG_9931.JPG IMG_9933.JPG IMG_9934.JPG IMG_9945.JPG
    swade41, brEad, tractorguy and 21 others like this.
  2. Bandit Billy
    Bandit Billy
    I used that Raptor liner on the bottom of my cab as well as the seat riser. That stuff goes on nice!
    Stogy likes this.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Don't you guys know it's Winter?
    Stogy likes this.
  4. Marty Strode
    Marty Strode
    Bruce, it’s going to be in the teens this weekend.
    Stogy and Hotrodmyk like this.
  5. dwollam
    dwollam
    And below that in Central Oregon in a few days, maybe 0 at night! That's just a couple days after the predicted 55 degrees tomorrow.
    Dave
    Stogy likes this.
  6. Marty Strode
    Marty Strode
    Put the cab on by myself tonight. IMG_9948.JPG IMG_9950.JPG IMG_9951.JPG IMG_9953.JPG
    swade41, brEad, tractorguy and 27 others like this.
  7. Marty Strode
    Marty Strode
    IMG_9979.JPG Back on the '29, one of my all time pet peeves is the painted white letters on drag slicks. The paint they use can be a struggle to get cleaned off without damaging the rubber. I used some wax and grease remover and maroon Scotch bright, to get them clean. I haven't had the truck on the floor for sometime, and after I dropped it down, I decided to cap off the shortened windshield posts, and check that off the list. IMG_9961.JPG IMG_9965.JPG IMG_9966.JPG IMG_9969.JPG IMG_9975.JPG IMG_9977.JPG IMG_9978.JPG IMG_9979.JPG
    swade41, brEad, bchctybob and 20 others like this.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, getting the white lettering off is a big improvement. Like the simplicity of the post caps, too.
    Stogy likes this.
  9. Marty Strode
    Marty Strode
    Sorry for the duplicate pictures, I just checked my internet speed, the download is 0.14 mps. One of the joys of living in the country.
  10. AmishMike
    AmishMike
    Will u attach chute to rear or frame? Will u run with floor in pickup bed? Will u put tonneau over ****pit & or bed? Run with gl*** in windshield? Old drag racer curious how u get that beauty humming, only ever ran late model door cars. Love all your builds
    Just Gary and Stogy like this.
  11. Marty Strode
    Marty Strode
    Mike, the Shroud line will attach to the rear axle. Tonneau on the bed only, and the windshield is Lexan. Thanks for your interest.
    bchctybob, Stogy, bymanr and 3 others like this.
  12. DDDenny
    Really looking good Marty!
    Stogy likes this.
  13. Marty Strode
    Marty Strode
    Doug, you need to come over and see it sometime, there is a good burger joint nearby.
    Stogy likes this.
  14. Marty Strode
    Marty Strode
    Laid out the hood pattern last night, going to transfer it to some .063, 3003 aluminum today. IMG_9983.JPG IMG_9986.JPG IMG_9985.JPG IMG_9987.JPG IMG_9990.JPG IMG_9991.JPG IMG_9993.JPG IMG_9994.JPG
    charleyw, brEad, bchctybob and 17 others like this.
  15. Marty Strode
    Marty Strode
    OK, it's 2 hours later, and this is what I got accomplished. After getting the lines transferred, I started by t******* the line across the back and then the front. After filing and sanding the edge on the rear, it was time to run it through the rolls, concentrating on the rear center profile. Then back and forth to the rolls until it lays down pretty good. I need to get a cowl lacing before I can go any farther. At that time I will tune up the entire fit and trim the front, before folding the sides under, for a 1/2" flange on both sides, the mounting will be Dzus fasteners. I am contemplating a scoop or a bubble in the center for air intake, as the stacks are pretty close the the hood. Good Day ! IMG_9997.JPG IMG_9999.JPG IMG_0002.JPG IMG_0005.JPG IMG_0006.JPG IMG_0007.JPG IMG_0009.JPG IMG_0010.JPG IMG_0013.JPG IMG_0014.JPG IMG_0017.JPG IMG_0019.JPG
    Stogy, swade41, brEad and 24 others like this.
  16. Marty Strode
    Marty Strode
    I got a cowl lacing kit, now I need to figure out the best way to install it. I believe all 28-29 body styles that used the same tank (not including Murray Bodies) require the same procedure. Any input would be great.
    Stogy likes this.
  17. alchemy
    alchemy
    Don’t they originally have a wire that fits down the center of the groove and holds the welt in?
  18. Marty Strode
    Marty Strode
    Jeff, I think there is hook to draw the center down tight.
    Stogy likes this.
  19. alchemy
    alchemy
    I mean the wire runs the whole width of the gas tank. The hook in the middle holds the wire and welt down for clearance of the center hinge. But I might be imagining things.
    Stogy likes this.
  20. Marty Strode
    Marty Strode
    That’s right.
    Stogy likes this.
  21. LOOKS GREAT!
    Stogy likes this.
  22. A Boner
    A Boner
    I understand rolling it to fit the Cowl, but how does one achieve the tighter radius at the front (grill shell)?
    Cool build Marty, make that cool builds…when will the Track T get some more love?
    Stogy likes this.
  23. Marty Strode
    Marty Strode
    If you notice the first picture the roll is parallel to the centerline, and the next time it is at an angle to the centerline. That allows for the taper over the distance front to rear. With 3 rollers, two are stacked, and the the back one adjusts up at an angle, allowing to roll one end tighter than the other for a different radius on each end. What I couldn't show in the pictures, is how I clamp the piece in the brake, to hold it, while I hand form each end to fit the shape of the vehicle. As far as the Track Roadster, it will have to wait until I get the '29 ready to race, and the COE completed to haul it. BTW, I am thinking of the name I will paint on the hood sides, when it is in compe***ion livery. It will contain the word "Bone", as that was the man's last name on the ***le, when I bought it. It is truly an "A-Bone". IMG_0023.JPG
  24. spanners
    spanners
    What about 'Bare to the Bone'?
    Stogy likes this.
  25. Larry Anderson
    Larry Anderson
    You had me at burger, I think I know the place…
    Stogy likes this.
  26. DDDenny
    Roger that!
    Stogy likes this.
  27. Marty Strode
    Marty Strode
    I started on the hood scoop tonight, got it roughed in. It needs more shaping at the rear, before shortening in height and length. C3A03E4E-7B42-49AD-82FB-2ECA04C70BA7.jpeg 5C469195-E3D9-41A3-A424-154173F12CAC.jpeg 5C469195-E3D9-41A3-A424-154173F12CAC.jpeg 174ED5EA-50C6-43B4-847C-9E6FA8DA17E6.jpeg 54673954-06A5-4874-99A5-8AD485DF6BCE.jpeg
    Stogy, bymanr, Shadow Creek and 18 others like this.
  28. Larry Anderson
    Larry Anderson
    Stogy and rod1 like this.
  29. 05snopro440
    05snopro440
    Looks great!
    Stogy likes this.
  30. A Boner
    A Boner
