Technical Chevy 327 parts fit on a 305 engine
Discussion in 'Traditional Hot Rods' started by 1955 F-100 guy, Feb 3, 2023.
  1. joel
    joel
    ^^^^ We finally get to the important part of this parts swapping. I did the math for a 305 bore and stroke. IF in reality the displacement is 305, the bore is near 3.734". With sbc traditional valve spacing, that limits intake dia. to around 1 7/8". In bygone days ,after the 327 was offered, people wanted to use these on 283s. You could get domed pistons to allow for the larger combustion chambers; most people bored the 3.875 dia to at least 3.937 to clear the 1.94 dia. intakes in the 327 heads.
    My point: accessory mounting bolt holes is the least important consideration.
  2. 34Phil
    34Phil
    you will lose a point in compression going from 53 cc to 62 cc
  3. DDDenny
    Yep, last year for the true camel hump heads, these are NOS "291" heads on my 327.
    Nothing will kill the buzz for a true "traditional" looking small block Chevy engine than accessory bolt heads!
    427 sleeper likes this.
  4. 6sally6
    6sally6
    Can you "relieve" the bore where the intake valve won't hit the cylinder walls? (my lose CR but that can be made up with milling/pistons!)
    Jusr a WAG....
    indyjps likes this.
  5. gimpyshotrods
    gimpyshotrods
    There is nothing, unless something is damaged, wrong with your current heads. They will work fine.
    What is it you would hope to get out of a different set of heads?
    If this is for a street-going vehicle, and the intent is to use it on a regular basis, gaining 10, 20, or even 40-horsepower just equates into using more fuel.
    You might not notice the 0.6-second decrease in 0-60 time, or the 0.75-second reduction in quarter-mile time, but you will notice the number of times you are at the gas station.
    Will the return justify the initial and ongoing expenses?
  6. joel
    joel
    Yes, I agree ; I should have said that sacrificing a traditional engine or cylinder heads for accessory mounting is sub- optimal. One of the traditional build concepts was and I think should remain, is performance. Of course, there are different categories of performance .
  7. DDDenny
    Before the last of the earlier heads were being cast, GM had substantially better flowing heads on the drawing table.
    Long live the 327!
  8. 55chevr
    55chevr
    I had an 82 Camaro Z28 4 speed car. 305 cu engine was terrible. I wouldn't recommend anyone putting any time or money into one. Start with a better block.
  9. SS327
    SS327
    Nobody is listening to this poor guy except Mad Mikey. World products makes a decent iron head. Just choose runner volume, chamber volume, valve size and Jegs or Summit ships them right to your door cheaper than rebuilding an old set of heads. Been running them for years. Great heads!
    Budget36 likes this.
  10. Budget36
    Budget36
    I think the discussion has turned into something that the OP doesn’t really need anymore, the 305 is off the table for him, then he was going to go with the 350, but wait time was too long. So now (as I recall) he was asking about 64CC heads that had accessory bolt holes.
    This isn’t directed at your helpful reply, just to those that don’t actually read others replies;)
    SS327 likes this.
  11. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Thanks for all your advice discussion is done got my answers -- Thanks again
    SS327 likes this.
