Technical Exhaust deflector
Discussion in 'Traditional Hot Rods' started by Shake n Bake, Feb 5, 2023.
  1. Shake n Bake
    Shake n Bake
    from TN
    Finally got my 34 on the road. The exhaust comes all the way back and under the center section of the independent rear then up and out the back. Looks like the exhaust is going to blow straight on to the rear spreader bar/back bumper.
    I was thinking of adding the flat and wide tips/deflectors.
    Any experience with them? How they look? If they do much deflecting?
    Do they change the sound much?
    I mainly want not to soot the spreader bar without adding turn downs.
    Already getting busy down there.
  2. i.rant
    i.rant
    How about a photo?
  3. Shake n Bake
    Shake n Bake
    from TN
  4. Shake n Bake
    Shake n Bake
    from TN
    the plate is moved up between the tail lights and the exhaust comes out about where the tag is.
  5. 6sally6
    6sally6
    Like ya car !! Nice
    6sally6
    Shake n Bake and Packrat like this.
  6. miker98038
    miker98038
    My buddy has a set on the back of a 56 Nomad. I don’t see that they do much. But the back of any wagon is kind of a suction chamber, so might be different for you.
    Nice ride.
    Shake n Bake likes this.
  7. '29 Gizmo
    '29 Gizmo
    from UK
    Wont do anything to prevent soot on your spreader, there is too much turbulent air under there at speed. May work when you are stationary.
  8. 26 T Ford RPU
    26 T Ford RPU
    I have them on my RPU and have never had exhaust residue on my nudge bar or tail gate.
    Question, why are the tail pipes aiming at the spreader bar? JW
  9. Mr48chev
    When it is all together with the spreader bar in place wouldn't it be simpler to have the muffler shop bend some tips that directed the exhaust Down past the spreader bar? It looks like you have a few things to take care of back there including the spreader bar and then figure out the last few inches of the exhaust.
  10. PhilA
    PhilA
    If you want the look of it but don't want the soot, cut your pipe to have a hole in underneath and a 45° blocking plate at the rear of the hole. Paint the inside of the pipe matt black. Hidden turn-down.
    Any tip you put on will never get dirty...
    Just Gary and Shake n Bake like this.
  11. Shake n Bake
    Shake n Bake
    from TN
    Thanks guys appreciate the feed back
    26 T Ford RPU likes this.
  12. gimpyshotrods
    gimpyshotrods
    I hate to bring this up, but maybe buy or borrow a wideband oxygen sensor.
    If you are pushing that much soot, you are running too rich.
    Hillbilly Werewolf and '29 Gizmo like this.
  13. Shake n Bake
    Shake n Bake
    from TN
    Funny you should say, just pulled the plugs, very rich.
    Working on fuel delivery now.
    I haven’t been having a noticeable soot issue, only run 175 miles so far.
    I just didn’t want the spreader to get hot and nasty.
    I’m going to make the spreader and run it for a while and see what happens.
  14. Dirk35
    Dirk35
    Two of my cars have the exhaust turned down and one has the exhaust that exits straight out the back. Both of them with it turned down exhaust tips make a drone noise that is constant when on the highway and they kick up a lot of dust anytime I'm backing up. So eventually, I plan to change the two that turn down to exit straight out the back.
    For the overall sound, the two that are turned down actually have quieter mufflers but both sound louder because the sounds echoes off of the ground.
    I personally prefer the exhaust to exit straight out the back.
    rusty1 and Shake n Bake like this.
  15. Shake n Bake
    Shake n Bake
    from TN
    Yes my thoughts exactly.
    I have one turned down under the car and it’s very annoying if your stoped on a gravel road. I need it run out the back before it back on the road.
