Hot Rods DENNIS FRINGS 29 -- GRAND NATIONAL SHOW bound
Discussion in 'The Hokey Ass Message Board' started by Frames, May 8, 2022.
  1. Frames
    Frames
    My 29 unfinished has found a new home. A gentleman from GA has purchased it as-is. He has contracted a street rod shop to finish it and enter it in the AMBR contest. This is what I always wanted. A man that can afford it and a shop that has the capability to finish it to flawless perfection. The shop has many awards. I too have 7 Goodguys Southeast Nationals prestige awards with 4 hot rods. My cars are not perfect. I don't have that kind of time. I had not discussed color with them. I was going to paint it a little darker than the Joe Nitti Royal Tritan purple. The frame looks almost black in this picture but it is purple. The photo shopped color is too light. I had an early 50's hot rod in mind when I designed it. 1956 to be exact hence the 1956 Mercury wheel covers PS; I knew if I found a buyer with the $ the Hilborn would be converted to hidden EFI. That's the 1st thing on the agenda. Oops. When they picked up the car. The rod shop owner asked " will a 4 barrel carb fit under the hood?" img504.jpg p1010044_0015_0082.jpg img091 - Copy - Copy.jpg
  2. alchemy
    alchemy
    We’ll look for it in January.
    dana barlow and Just Gary like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    What a great start,they are getting.
    :cool:
    alanp561, oliver westlund and clem like this.
  4. raaf
    raaf
    I like the style of your builds. Looking forward to seeing it on the other side.
  5. Frames
    Frames
  6. Frames
    Frames
    2023-11-06 08.00.57-1.jpg 2023-11-06 08.00.57-2.jpg The first 2 days it was sold I was really down in the dumps. Sellers remorse. I was willing to buy it back for $5,000.00 more than I sold it for. I did not need the money. Then a very close friend who knows the rod builder convinced me the rod builder could get the job done. I will be campaigning so this will always be the Dennis Frings 29. That is all I want out of this deal. PS; Being a race car builder I used blue-red Aeroquip fittings that I had in stock. I agree they should be changed to black. HAMB police. I beat you to it.
  7. raaf
    raaf
    Dennis - do you have any more photos of the car or build?
  8. Max Gearhead
    Max Gearhead
    from Wisconsin
  9. Frames
    Frames
    1956 build? Soon the HAMB police will call me on the 1960 Cadillac steering wheel. 2003-12-31 23.00.00-20.jpg 2003-12-31 23.00.00-24.jpg
    I sent a PM to RAAF stating I would do the build thread over in the near future.
    alfin32, alanp561, catdad49 and 6 others like this.
  10. hotrodjack33
    hotrodjack33
    Kudos on a spectacular build...and, for the sake of the car, letting it go so it can reach it's full potential. That my friend, took real heart.
    chryslerfan55 and 41 GMC K-18 like this.
  11. goldmountain
    goldmountain
    Hope they build it to your concept without messing it up.
  12. You are a strange duck.
  13. 26hotrod
    26hotrod
    from landis n c
    I have seen several of his builds over the years. His attention to detail is off the chart..........
    oliver westlund likes this.
  14. Frames
    Frames
    I sold this hot rod as-is but have been contracted to finish the doors. I will get at it next week. I have been busy building flathead engines. 5 in in the last 2 months including two 1/2" **** stroker engines. 2022-05-21 09.20.45-3.jpg
    hfh, alanp561, chryslerfan55 and 3 others like this.
  15. Frames
    Frames
  16. Frames
    Frames
    I started work on the doors. Installing a 90 degree sheet metal lip to wrap the aluminum door skins around. The front one is very time consuming what with having to shrink both sides. Going to tach weld it every 4 inches and adjust the shim thickness where needed 2022-05-23 22.22.12-3 - Copy.jpg 2022-05-23 22.22.12-4.jpg leaving 1/8" of coach reveal exposed.
  17. Frames
    Frames
  18. Frames
    Frames
    THANK YOU. We can only hope. When I did a thread " AMBR potential contender" MANY positive replies. But two faceless critics. One said get rid of the wide tires [ 7.5" ] and the other said use stock W/S posts. Stock with all the hiccups???? Another critic said the car has no chance with the CHEAP tachometer. Well if that is the case with the cheap peep mirrors and the cheapest accelerator pedal we will most likely get stopped at the CA border.
  19. Frames
    Frames
  20. Frames
    Frames
    Might just start the build thread this afternoon. Most rods I build I start with an accurate blue print. The 29 I also did a concept drawing using 2022-06-02 17.40.21-1.jpg 2022-06-02 17.40.21-2.jpg a copy machine and a scissors. I like to stress the color picture is NOT an artists rendering. Robert Mc Carter added the doors, hood and color to a photo of the actual car via photo-shop.
  21. Frames
    Frames
  22. Frames
    Frames
    I will be doing more build threads in the future. Today the car was picked up by the rod shop and the new owner. I said I would sit low. 6'2" me sitting on 3" foam. Once the car is painted the vertical 29 coach reveal will become much more subtle. Of course you all knew that . 2022-07-27 10.38.40-2.jpg 2022-07-27 10.38.40-3.jpg
  23. Lemme guess, the fur ball in the second photo is your project inspector, right?
    uncleandy 65 and alanp561 like this.
  24. milwscruffy
    milwscruffy
    Happy 87th Birthday Dennis !!!
  25. Frames
    Frames
    The first thing they were going to do was have the Hilborn converted to E F I. But when they picked the car up the rod shop owner asked " Will a 4 barrel carb fit under the hood? " Can't be running out of money already?
    dana barlow likes this.
  26. airsix
    airsix
    Those lines are gorgeous.
    hfh likes this.
  27. Frames
    Frames
    When they picked up the car the shop owner asked " Will a 4 barrel carb fit under the hood? Can't be running out of money already.
    hotrodjack33 likes this.
  28. Frames
    Frames
    I can only hope and pray. The Joe Nitti 1951 32 got a lot of ink for the Royal Triton purple. TV show Counting Cars painted their 50 Chevy ramp truck purple. Coddington painted the infamous Cadzilla purple.
  29. Frames
    Frames
    THANK YOU! Glad you noticed. The 3/4 " pie cut section out of the 1/4 panels was extremly important. I did that just above the lower reveal.
  30. Frames
    Frames
    Cheap parts. Ya it's all about mega bucks at A M B R.
