1949, 1950, 1951 Mercury Pictures
Discussion in 'Traditional Customs' started by Boones, Jul 3, 2007.
  1. straykatkustoms
    straykatkustoms
    I was wrong, not chrome tape but still kool layout. Check out the fades and blends.
    A198A53C-1209-4FED-A8BF-C78AD31E08A6.jpeg B03B5403-B11B-4954-ABBA-BC6E0AB36244.jpeg
    Dangerousdan, enloe, Sancho and 12 others like this.
  2. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    54delray likes this.
  3. Bullet Nose
    Bullet Nose
  4. straykatkustoms
    straykatkustoms
  5. straykatkustoms
    straykatkustoms
  6. straykatkustoms
    straykatkustoms
  7. Jalopy Joker
    Jalopy Joker
    '50 Monterey ad on facebook market place cl***ic cars for sale Reno - finished one by **** Dean 20230206_210936.jpg 20230206_214111.jpg
  8. straykatkustoms
    straykatkustoms
  9. straykatkustoms
    straykatkustoms
  10. straykatkustoms
    straykatkustoms
  11. straykatkustoms
    straykatkustoms
  12. straykatkustoms
    straykatkustoms
  13. straykatkustoms
    straykatkustoms
  14. AChopped1950ford
    AChopped1950ford
    Did they use a Cadillac upper grille bar to extend the hood on the Hirohata merc ?
  15. 54delray
    54delray
    from Fremont NE
    I'm pretty sure the Hirohata hood lip was hand formed. That Caddy has quite a pronounce peak to the center, too much for a Merc hood, in my opinion.
    I had a shop mimic the Hirohata hood lip when I was heavy into my project '51 Merc. Once the stock pot metal emblem is removed, the upper grill surround sticks out farther than the front of the hood. I had the shop cut the upper grill cavity loose, pull it a just a little more forward and weld to the hood. Then they filled the top with two curved metal strips that meet in the middle. Once that shape was settled, they hand built the area on the fender between the hood and the extended/frenched headlights to match.
    Kinda wish I still had the car. I sold it as an unfinished project.
    drdave, lucky, 1pickup and 13 others like this.
  16. straykatkustoms
    straykatkustoms
    I don't know but I'll try to check it out. You are brought up a kool idea, kool kustom tick that should work.
    OG lil E, Sancho and AChopped1950ford like this.
  17. K13
    K13
    Everything I have ever read about it says it was hand formed sheet metal. Including the description of it in the Barris Custom Techniques books.
    drdave, OG lil E, Sancho and 3 others like this.
  18. AChopped1950ford
    AChopped1950ford
    Thank you.
    OG lil E and 54delray like this.
  19. AChopped1950ford
    AChopped1950ford
    Thank you, I hope you find out how they did this , all the clones look the same , was it some thing simple or a grille bar from another car.
  20. AChopped1950ford
    AChopped1950ford
    Thank you
  21. goldenidolcustoms
    goldenidolcustoms
    from Pa.
    they used inch and a half exhaust tubing
    OG lil E, lurker mick and 54delray like this.
  22. straykatkustoms
    straykatkustoms
  23. Squablow
    Squablow
    Interesting use of Corvette tail lights on the '51 above. Works well.
    enloe, OG lil E and 54delray like this.
  24. Bullet Nose
    Bullet Nose
  25. straykatkustoms
    straykatkustoms
  26. 51 mercules
    51 mercules
