Technical Painting small Parts w/Spray Gun
Discussion in 'Traditional Hot Rods' started by HuskerNation, Feb 7, 2023.
  1. HuskerNation
    HuskerNation
    C5DA164B-CA8A-4B95-B1EB-7B32C77C063F.jpeg I’m getting tired of rattle cans to paint small parts, however they are so darn easy to use. Has anyone found an easy way to use proper automotive paint in a spray gun, not a huge gun but small enough to spray one or two small pieces?
    In the past I’ve used the go-to HF $10 spray gun with automotive single stage (with hardener, etc) paint with great success on larger items like gas tanks. Thanks
    Just Gary likes this.
  2. Just.dale
    Just.dale
    D21F7DAA-0E0E-49D5-8E7A-54CEBD15BB0F.jpeg I love this stuff for the smaller parts, I know it’s not what you asked but I find this sprays great and is very durable. Or you could get a jamb gun, great for small jobs too.
    Stock Racer and mad mikey like this.
  3. Either a touch up gun or have the automotive paint put into a spray can.
  4. 57JoeFoMoPar
    57JoeFoMoPar
    Sometimes I'll use a jamb gun from HF.
    pigIRON63, big john d and mikhett like this.
  5. Detail gun or an airbrush for really small parts.
  6. theHIGHLANDER
    theHIGHLANDER
    The only way to efficiently make up a load for a spray gun is get a bunch ready and do it all. Onesy-twosey with a gun is a pain in the ***. Did you mix enough? Too much? Can't keep paint with a hardener/catalyst more than a day, even stashed in the cold overnight. How much gets thrown away? If this sounds like "been there" then you're right. Otherwise the age old rattle can can't be beat. Best advice is get good quality stuff. I recently ****ged some Krylon called "Automotive Acrylic Enamel" that's a rich deep black and seems to dry just as fast as the good ol Krylon. Most gloss blacks are just real dark grey. Best I got for ya after too long in restoration to recall it all.
  7. HuskerNation
    HuskerNation
    Good advice all. Over the last few years I’ve gravitated towards the Duplicolor Engine Enamel (500F) rattle cans and so far they have been pretty good. I’ll have to check out the Krylon.
    I may pick up this little touch up spray gun.
    jimmy six and overspray like this.
  8. goldmountain
    goldmountain
    To get the correct ratios when mixing up small amounts of paint, get a digital kitchen scale to measure the ingredients. Put that in a zip lock bag so that you don't get it covered with paint.
    HSF, gimpyshotrods and Happydaze like this.
  9. COCONUTS
    COCONUTS
    I would put my time and effort in building a down-draft paint table for small parts. You will be surprise the difference it will make.
    Bandit Billy, NoelC and Tow Truck Tom like this.
  10. HuskerNation
    HuskerNation
    :( So painting in the wind outside isn’t optimal?
    Jet96, da34guy, clem and 11 others like this.
  11. Bandit Billy
    Bandit Billy
    During the restoration of a 69 pace car a few years back I built what I affectionately called the "red neck paint booth". I went to u-haul and purchased a wardrobe box (it has a rail at the top to hang clothes), I cut french doors in the front, added a LED light at the top, cut a hole at the bottom and used a shop vac for the down draft (fortunately it did not explode) . I would get a pile of parts that took the same color (semi flat black) mix it up with hardener and use a door jamb gun to paint the parts that were suspended from the rail by coat hangers.
    R A Wrench, Moselli, A Boner and 11 others like this.
  12. stanlow69
    stanlow69
    I go through over 50 cans a year. I lay the parts on cardboard outside. The parts aren`t so small. DSCF0027.JPG
  13. leon bee
    leon bee
    I had to buy the famous purple gun because I can't hold down that damn spraycan ****on more'n about a minute.
    V8-m, charleyw and SS327 like this.
  14. HF has a decent mini spray gun as well.
    pigIRON63, SS327 and Truckdoctor Andy like this.
  15. 1946caddy
    1946caddy
    from washington
    Blues4U, 2OLD2FAST and Budget36 like this.
  16. SS327
    SS327
    Spray can triggers ****! The touch up guns work great however!
  17. '29 Gizmo
    '29 Gizmo
    from UK
    Dip them. Small brackets are ideal for this. Just rotate them as you pull them out to alow the excess to run off
    indyjps and Moselli like this.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    Awfully wasteful if using a 2 part or catalyzed paint !
  19. AZ_Nick
    AZ_Nick
    I use the Preval system when I'm too lazy to clean the jamb gun.
  20. Bert Kollar
    Bert Kollar
    I have used A LOT OF RATTLE cans for small parts. I find the high heat paints and the ones with ceramic hold up much better
    jimmy six and -Brent- like this.
  21. 57 Fargo
    57 Fargo
    I just mix a small amount of regular paint and spray it, takes five minutes to clean the gun
    jimmy six, indyjps and -Brent- like this.
  22. Phil P
    Phil P
    To paint my back wheels I used the Kyrlon Implement paint in a spray can. Laid out very well filled the seems and no runs. Only downside is limited colors.
    Phil
    jimmy six likes this.
  23. warbird1
    warbird1
    I'll second that... used a lot of these when touching up or painting small aircraft panels. You still had to mix the paint; but clean-up was a lot quicker and easier than if you'd used a spray gun.
    y'sguy likes this.
  24. Whoamel
    Whoamel
    from So Cal
    I use an airbrush quite a bit for smaller stuff. Sometimes, even a detail gun is a bit too much.
  25. stanlow69
    stanlow69
    Turnipseed likes this.
  26. V8-m
    V8-m
    from Alaska
    You need something like this
  27. I use a touch-up gun for small parts, unless it's a spray bomb color(greys, blacks etc) I've had my touch up gun so long, it's the old style high pressure type.
  28. leon bee
    leon bee
    I do need one of those triggers. But that purple gun works pretty good. The worst spraycans I've bought for years was Rustoleum.
    V8-m likes this.
  29. willys36
    willys36
    I do it all the time. Get tiny (3oz?) paint mixing cups w/ graduations printed on them from the paint supplier and this HF purple gun.
    https://www.harborfreight.com/adjustable-detail-spray-gun-92126.html
    I've done several colors in a day this way. Mix 1/4 or 1/2 oz, spray it, dump the rest, take off the nozzle and clean everything with lacquer thinner & pipe cleaners. Only takes a couple minutes to clean. Ready for another color.
    Packrat and V8-m like this.
  30. Rustoleum....fast drying...Two things that never go together.
    evintho and willys36 like this.
