Projects Thames Resurrection
Discussion in 'The Hokey Ass Message Board' started by GlassThamesDoug, Nov 1, 2022.
  1. 1940Willys
    1940Willys
    Great to see you back on it!
    GlassThamesDoug likes this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Doug. It has fooled a lot of people. You should do that on your build for the look of trips and the bottom end tractability of a two barrel. You may need to add some sheet aluminum skirting around the botttom of yours to complete the look.
    catdad49 likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Here's a pic of the other side with the bogus secondary progressive linkage. Note the carbs are turned around backwards to clear the front mounted Ford distributor.
    brEad and GlassThamesDoug like this.
  4. GlassThamesDoug
    GlassThamesDoug
    Finally warm without rain... (weld outside) .... shock mounts done. This should work to prevent excess axle drop. 20230208_133910.jpg 20230208_133950.jpg 20230208_155746.jpg 20230208_164606.jpg
    mad mikey, brEad, Tickety Boo and 4 others like this.
  5. AHotRod
    AHotRod
    Keep going !
  6. GlassThamesDoug
    GlassThamesDoug
    Front end updates done. 2x shorter steering arm bolts to eliminate spacers.
    20230211_133603.jpg 20230211_133551.jpg 20230211_132917.jpg 20230211_132905.jpg
  7. GlassThamesDoug
    GlassThamesDoug
    Picked up a street clutch kit at Summit. Was 1/2 price. Saw Summit Brand for $70.
    FYI: they had a new McLeod GM RST dual disc with 26 spline discs in scratch and dent demo area for $400.
  8. j walking
    j walking
    cool! will watch this! Building a Henry J myself and worried about wobbles.
  9. GlassThamesDoug
    GlassThamesDoug
    Your ch***is with parallel springs looks nice. Caster is first thing to verify.. There was a Nova running at 2022 Blue Suede Cruise this year that had the front wheel wobble real bad. First time seeing it happening. I know inside the car, it feels like your front wheels are square.
    427 sleeper likes this.
  10. GlassThamesDoug
    GlassThamesDoug
    Engine in Tomorrow if everything goes right.
  11. GlassThamesDoug
    GlassThamesDoug
    Guy building Henry Js & Austins attended Good Guys last year Columbus.
  12. GlassThamesDoug
    GlassThamesDoug
    How is car going...
  13. jimdillon
    jimdillon
    Looking good Doug.
  14. GlassThamesDoug
    GlassThamesDoug
    Been Working on wagon too, lowered suspension, trying to pick up 10ths, without any more eng power. Caltracs going on. Last race, I was going backwards, not sure if it was bias ply fronts, or fuel I bought at Wisconsin Truck Stop.
  15. jimdillon
    jimdillon
    What about the Vette?
  16. GlassThamesDoug
    GlassThamesDoug
    My buddies 62.... sitting collecting dust. Track ready, but his health "neck surgery" is real tough..
  17. GlassThamesDoug
    GlassThamesDoug
    Trans cleaned up nice. Gasoline is still a good cleaner. Close, tomorrow it's in.
    McLeod Bell housing.
  18. 427 sleeper
    427 sleeper
    I can hear the 9,000 RPM launches from here... :D:cool:
  19. GlassThamesDoug
    GlassThamesDoug
    That was last time, Alum Rod 292... I took tach out, couldn't watch it. Did nice wheelies, that's about it, this is more torque, probably 6500 RPM. Might put 4-ish gear in it.
  20. GlassThamesDoug
    GlassThamesDoug
    mad mikey, catdad49 and 427 sleeper like this.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice. But I think I'd be alittle bit worried about those stove bolts in the front motor mounts failing in a flip. At the very least I'd add a big washer or even better, replace with grade 8 bolts.
    mad mikey and GlassThamesDoug like this.
  22. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Looking Good.
    Imagine if we can ever get all of ours and yours finished and at the same location just one more time. Lol
  23. GlassThamesDoug
    GlassThamesDoug
    Hit the track, making p***es..
  24. GlassThamesDoug
    GlassThamesDoug
    Will do.... I have some nice 1/2 in grade 8 hardware.
  25. GlassThamesDoug
    GlassThamesDoug
    Shopping for tight exhaust manifolds for this street version. Leave the headers in rafters for a while.
  26. GlassThamesDoug
    GlassThamesDoug
    Been working on 56 wagon .... no Thames Updates.
  27. SS327
    SS327
    Doug, thanks for the carbs! You need to get this going. It’s a sharp little truck!
  28. GlassThamesDoug
    GlassThamesDoug
    Your BB will like them carbs, always looking for Early Weiand Hi Ram. Canfield Ohio swap meet is coming up, good stuff shows up.
  29. GlassThamesDoug
    GlassThamesDoug
    Back from TFN's. Rested, Put 66 Muncie Trans back in Thames today.
  30. GlassThamesDoug
    GlassThamesDoug
    Shifter installed for alignment. X member installed. Check driveline angle next.
