Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. TA DAD
    TA DAD
    from NC
    Making some progress with my hood install. I have the hood pin ( SBC head bolt ) roughed in on the p***enger side, now on to the drivers side. IMG_0884.JPG
  2. mad mikey
    mad mikey
    Took a few pictures, scoop on , painted white. Brings out my white block and white detailed valve covers. I am satisfied with it. It is a very old fibergl*** scoop and took a lot of work to bring it back to where it is . Not perfect, but good enough for this old drag car, matches my imperfect old girl just fine, LOL. WIN_20230212_13_28_42_Pro.jpg WIN_20230212_13_29_16_Pro.jpg WIN_20230212_13_30_09_Pro.jpg
  3. Stock Racer
    Stock Racer
    Cleaning caked on, 60 year old gear lube ****s. Being able to do it outside in Northern Ohio in February because it's 50 degrees and sunny doesn't ****.
  4. RICH B
    RICH B
    Finally found time to weld up, blast, paint, and install the offset tailpipes on our '47. Had to shorten the pencil tips and now they don't stick into the bumper guards. Made a new cover for the fuel sender as I lost or maybe never had one. Just need to blast and paint it.
    IMG20230215164912.jpg IMG20230215165002.jpg IMG20230215165045.jpg IMG20230215175944.jpg
  5. swade41
    swade41
    from Buffalo,NY
    I traded a 1/4 cord of old firewood that I wasn't using for a 4-71 that I probably won't use either lol
    But it'll be nice to look at
  6. WhyW8
    WhyW8
    from Sun City
    Installed the cab onto the frame. Screwed on some Moons
  7. milwscruffy
    milwscruffy
  8. mad mikey
    mad mikey
    Damn! I hate you!:D Just kidding.
    swade41 likes this.
  9. 1biggun
    1biggun
    I installed a 400 pound hoist up in the rafters to lift the body up and down about 300 times. This will make building this a lot easier .
    Pulled the 283 out that's full of rust and water . Cut the ****py mounts out that were bowing the frame rails outward and got a crossmember type mount that can handel some real HP and stiffen the ch***is up ready to install about a 1/2" further back so the water pump is not almost hitting the new NOS thicker 27 T Walker radiator that I just scored .
    That and tripped over extension cords , air hoses , shop heaters and the stray cat .
    Some how my plans went from a 120 HP chevy 4 to about a 600 HP 413 SBC that's slated for the altered project but can get tested and tuned in this in the mean time .
  10. 1biggun
    1biggun
    Damn been looking for one of them for my 471 manifold .
    Nice score
    mad mikey and swade41 like this.
  11. fastcar1953
    fastcar1953
    I would trade several cords of wood for 8-71.
    mad mikey, guthriesmith and swade41 like this.
  12. swade41
    swade41
    from Buffalo,NY
    He said he had a plate he machined to move the 8-71 forward on a sbc so he could get the mag in, he used to race a dragster for several years.
    mad mikey likes this.
  13. swade41
    swade41
    from Buffalo,NY
    Today I swapped a bunch of rims around checking clearances before deciding on ordering the 4 inch tub or the 2 3/4 tub from Dan Carpenter, I chose the 2 3/4.
    15x8.5 Ansens
    20230216_140042.jpg 20230216_135619.jpg Screenshot_20230217_011202_Gallery.jpg
    15x10 Appliance slots, which I really like but are right on the fender lip
    Screenshot_20230216_182919_Gallery.jpg 20230216_141110.jpg 20210602_152305.jpg 20210602_152234.jpg 20210602_153226.jpg
    And then a rim with 5.5 inches of backspace
    And the tub I ordered
  14. Rusty Heaps
    Rusty Heaps
    I spent three days on the interior of my ‘46 Chevy coupe. I pulled the mouse nest interior. S****ing and painting floors in preparation for new sound deadener and carpet, painting lower dashboard, and heater box. I also removed the p***enger quarter window for replacement and vacuumed the mouse nest out of the drain trough, then cleaned and painted the track and blasted nearly an entire rattle can down into the trough. I’ll do the other one next. 916D5242-8743-4DD0-9C18-CCD25DD6EEFA.jpeg 52CC30DC-7E01-49FC-8EC8-D0261A3A6D86.jpeg 20D91688-F347-45A1-AC4D-36C4517FCC62.jpeg 5431E782-9767-4970-A950-472BDCD9B941.jpeg
  15. WhyW8
    WhyW8
    from Sun City
    Placed the bed, mockup to check for gas tank fitment.
    [​IMG] [​IMG]
    210superair, 40two, LAROKE and 8 others like this.
  16. Jkmar73
    Jkmar73
    from Tulare, CA
    C211BCB9-EA91-4E3E-81A9-C2493AA05991.jpeg Been working on wiring the model a. Got the headlight circuit powered up.
    Almostdone, 40two, charleyw and 5 others like this.
  17. swade41
    swade41
    from Buffalo,NY
    More bulkhead templates today, trying a two piece design this go around, so far so good.
  18. 1940Willys
    1940Willys
    Look'n good
  19. Zax
    Zax
    IMG_1797.jpg IMG_1798.jpg Took an old, crusty Model A brake cross shaft and made a front frame spreader for my highboy.
  20. Zax
    Zax
    IMG_1803.jpg IMG_1804.jpg Finished. Couldn't decide which pic I liked best so I attached both
  21. fastcar1953
    fastcar1953
    Took a part my big block to find it had been rebuilt and has a cast crank. Looks good and still stock bore. IMG_20230218_154457.jpg IMG_20230218_154317.jpg IMG_20230218_143830.jpg
  22. gene-koning
    gene-koning
    OK, perspective on this one please.
    My 49 truck is my winter ride. I live in the northwest corner of IL, we get snow, and they salt the roads.
    We got between 6" and 11" of snow last Thursday, depending on where you lived, and how much got blown away from, or to, you.
    The truck is covered with salt, and the snow has been melting since Sat. Its getting washed tomorrow, the roads are finally getting dry. Nothing planned for today, so why not a road trip? Lets say, around 100 miles?
    I even took a few pictures with my wife's cell phone, and was able to get them onto my computer. (That is a pretty big deal around here.)
    The first 2 are from what is suppose to be the 2nd highest point in northern IL, I'm taking their word on it.
    The 3rd one is the road ahead a few miles later. I thought I had a couple more, but couldn't find them on the 300+ pictures she has on her phone.
    The 4th is some guy's yard art. We were pulled over off the road, with no other traffic, but some guy still about crashed into us, so we thought better of taking any more pictures.
    Anyway, it as good just to get out of the house and out of town on this nice sunny 50 degree (but windy) day. Thought I'd share a little.
  23. vtwhead
    vtwhead
    Nice pics! Being from VT I must ask, what did you do with your mountains?:)
    '28phonebooth likes this.
  24. gene-koning
    gene-koning
    We let the glaciers from time long past squished most of them flat!:D
    If you are referring to my Avtar pic, that pic was taken on our trip through the Rocky Mountain National Park in CO on May 29, 2016 (the 2nd day after the mountain p*** was opened for the summer). The point the picture was taken is near the top visitor center, 11,000 feet above sea level. The coupe (which is now red and white) was on a 2800 mile round trip. The car had been driven over 90,000 miles since 2012.
    As far as IL, we have "hills" up here in the north west corner. The closer you get to the Mississippi River, the north 1/2 of the state is hilly, the southern 1/2 is flat. The eastern side of the state is flat as well. IL is 600 miles long and 120 miles wide. When you get towards the central IL, they barely even have hills, you see the road vanish into the horizon without even seeing a break or a bump in the road surface. If you're in the middle of IL and don't like the scenery, drive 100 miles in any direction, and everything will be different.
    TrailerTrashToo and vtwhead like this.
  25. jimmy six
    jimmy six
    Fixed the oil leak on my YBlock (yeah right). After fighting one from the external oil pump area determined it was high pressure back feeding the outside tubing seal. Lowered the pressure by adding a spacer washer to the external nut. 3 days and not even evidence of a drip forming. At 78 I don’t relish being under a car but don’t trust anyone to fix its problems. Now on to the clock and laying under the dash…….again.
  26. swade41
    swade41
    from Buffalo,NY
    My templates worked out good, just need a fch off the edges to get the aluminum to relax, but it's a nice tight fit. I'll bend a couple aluminum straps for the middle support and some outside edge "L" brackets to attach the panels to.
    20230219_154051.jpg 20230219_184138.jpg 20230221_171308.jpg 20230222_155011.jpg 20230222_154952.jpg 20230222_160153.jpg 20230222_160206.jpg 20230222_160521.jpg 20230222_160452.jpg 20230222_160407.jpg
    rod1, Almostdone, charleyw and 7 others like this.
  27. TA DAD
    TA DAD
    from NC
    I am still chipping away at my hood install, I sure don't want it flying up smacking the roof. I had to do a little metal reshaping to clear the bracing. I do get tired of welding rust though ! IMG_0901.JPG IMG_0899.JPG
    LAROKE, Stock Racer, charleyw and 3 others like this.
  28. jetnow1
    jetnow1
    from CT
    Was making steady progress thru last Oct, but got side tracked when my brother pulled me out of retirement to repair/paint/do floors etc on a house he bought. That kept me buzy November and December. did not help that
    my pickup got hit head on by someone who fell asleep at a red light. January I had covid, could not do my exercises
    and thru out a disc in my back. Going for a shot in the back tomorrow, hoping to get some relief so I can get back to it.
    swade41 and Stock Racer like this.
  29. 4speed411
    4speed411
    Got the '32 heave axle all mounted, had to taper the front rotor outer to clear the center caps of the wheels, motor mounts welded up, now to fab a tray mount. PXL_20230223_222214700.jpg
    LAROKE, vtwhead, swade41 and 3 others like this.
  30. N2hotrods
    N2hotrods
    40F6C920-39A6-488F-A9C1-773AF7D40FBD.jpeg D388C485-869F-49DB-BDBB-70DF8F5A54FD.jpeg F42ABBE4-E0A8-4942-AF21-2F0F1A0EE6C3.jpeg I worked on the heads for the 31 roadster today.
