  1. straykatkustoms
    straykatkustoms
  2. straykatkustoms
    straykatkustoms
  3. straykatkustoms
    straykatkustoms
  4. straykatkustoms
    straykatkustoms
  5. straykatkustoms
    straykatkustoms
  6. straykatkustoms
    straykatkustoms
  7. straykatkustoms
    straykatkustoms
    One of the koolest kustom accessory that I've seen in a while....
  8. AChopped1950ford
    AChopped1950ford
    What did they use to extend the hood on the Hirohata merc, was it a cadillac upper grille bar ?
    OG lil E likes this.
  9. AChopped1950ford
    AChopped1950ford
    Was this what they used
    OG lil E and chryslerfan55 like this.
  10. lucky
    lucky
    Likely a combination of tubing, sheet metal, and lead. If someone knows for certain, please chime on in.
  11. Sky Six
    Sky Six
    from Arizona
  12. Sky Six
    Sky Six
    from Arizona
  13. Sky Six
    Sky Six
    from Arizona
  14. Sky Six
    Sky Six
    from Arizona
  15. Sky Six
    Sky Six
    from Arizona
    Lot of pictures but the car is deserving of them all. 3225994877_7608eb0e2e_c.jpg 3225994861_797b1011b2_c.jpg 3225994859_710af90a07_c.jpg
  16. Sky Six
    Sky Six
    from Arizona
  17. Sky Six
    Sky Six
    from Arizona
  18. footbrake
    footbrake
  19. j hansen
    j hansen
  20. straykatkustoms
    straykatkustoms
  21. straykatkustoms
    straykatkustoms
  22. straykatkustoms
    straykatkustoms
  23. straykatkustoms
    straykatkustoms
  24. straykatkustoms
    straykatkustoms
  25. straykatkustoms
    straykatkustoms
  26. straykatkustoms
    straykatkustoms
  27. 59FORD
    59FORD
  28. drdave
    drdave
    The Hirohata uses a 51 Merc grille shell, which sticks out further than a 49/50 to match up to the big emblem/chrome bar on the front of the hood on a '51. Both the hood lip and top of the grille shell were flared/extended, then the top of the grille shell was cut loose and welded to the hood, thus extending the bottom of the hood into the grille opening. The Caddy looks like as @lucky says tubing and sheet metal.
    Here's a couple pics from @Kustomkid's Merc when he did the Hirohata hood to his that I've saved to give you an idea...
  29. straykatkustoms
    straykatkustoms
    Thanks Dave
