Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. alanp561
    alanp561
    Bones, where in the hell do you find someone to develop and print that old Kodak Brownie box camera film these days, huh? ;)
  2. Boneyard51
    Boneyard51
    I have to look long and hard! Lol :rolleyes:
    Bones
    chryslerfan55 and Budget36 like this.
  3. Dick Stevens
    Dick Stevens
    My problem is usually I don't think of taking a picture until I have it apart
  4. Front and rear pic.
    91F50948-D498-400F-AC13-B5DDE9686961.jpeg 45FAAA40-60F4-4A36-A367-4CB814CA1E50.jpeg
    both the left side.
    Do***enting a build, reference pics. looking up info and parts.
    These phones are cool.
    Hold down springs we’re missing on one of the rear shoes.
    Plan to clean up backing plates and paint em. ***emble them off the car.
    Just picked up the front springs. Hope to have brakes on as soon as parts come in.
    The front seal 8m-1109 doesn’t seem to have any other application except Mercury/Lincoln.
    National number is 6429
    Shoebox central is sending some.
    Spring kits coming from Kanter.
    The rest was sourced locally.
  5. Aerostar springs and homemade blocks.
    FF7E9438-B975-48E7-8091-9BEC27A530C6.jpeg 93B5C4F6-7B4A-4880-A603-A24F6706EF42.jpeg F1F823C9-5652-4E29-BB7E-5AD7A51A10CE.jpeg
  6. guthriesmith
    guthriesmith
  7. It’s better. Or a good starting point.
    I can live with that while I cruise and modify
    winduptoy and guthriesmith like this.
  8. 2 inch block.
    I’ll let it settle some.
    A spring spacer and 3 inch blocks might be tried eventually.
    winduptoy and chryslerfan55 like this.
  9. Dan Hay
    Dan Hay
    I think it'll need the 3" block because KUSTOM. Got skirts?
  10. guthriesmith
    guthriesmith
    The front will likely settle some over time. I think mine likely did about an inch or so with Moog Aerostar springs. And, I am also considering 3" blocks to replace my current 2" but only because I don't have to haul four kids in the back anymore since they are driving...
    And, seems like you had one good skirt?
  11. Got one skirt. P***enger side.
    Just DMd a HAMBer that has a drivers skirt in the cl***ifieds
    winduptoy, Cosmo49, Papas32 and 2 others like this.
  12. v8flat44
    v8flat44
    I love this thing. In the 60s a buddy had a 51 4 door with O/D trans, mild cam & headers. In 1st it could keep up with or beat some 265 & 283 chevs. I always wanted one just like the old "Mad Bat". For what it was, it was bad & cool. You might just like the flatty. GR8 project!
  13. BamaMav
    BamaMav
    from Berry, AL
    As bad as some of the roads are in Walker County, 2" is probably as low as I'd go. Any lower and you might be bulldozing new holes! :eek::D:D:D
    guthriesmith and anthony myrick like this.
  14. That Mercury looks bigger since you lowered it. It is looking great. Taking pictures is a great idea, when we dis***emble something like a cylinder head at work, with all of the fittings and small parts, we take pictures and send them to each other if someone else has to re***emble it.
  15. My bus is lower in front. It’s s****es occasionally.
    Ya just have to learn to drive low
    winduptoy, Jrs50, Boneyard51 and 2 others like this.
  16. Squablow
    Squablow
    Sits nice. Put a few miles on those coils, they'll settle out a bit more. My '52 Ford has 3" blocks in the rear and these same springs and it sits level.
    winduptoy and anthony myrick like this.
    gotta few stuck intake valves.
    Soaking
    Pulled plugs and shot some sea foam creep on the valves and in the intake ports
  18. 51504bat
    51504bat
    I'm a 50/50 mix of ATF and acetone guy but this isn't your first rodeo. So use Seafoam or whatever works best for you. Looking forward it seeing/hearing it run the first time.
  19. Almost did that but the spray can stuff can reach places better.
    Engine turns freely. Will pull heads if necessary.
    Hope the spring kits show up soon
  21. Intake valves just needed some lubricant.
    3 exhaust valves aren’t cooperating, 2 will move but not close.
    One lifter is stuck.
    Soaking
  22. s55mercury66
    s55mercury66
    from SW Wyoming
    Sometimes the varnish that seems to expand with disuse can be tough to get cleaned up. You might try shooting some carb cleaner at the sticky ones, let that kind of soak its way through, then use some of your favorite concoction again. We had a Plymouth flathead that fought us on the same front for a couple weeks before we tried acetone on them.
  23. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Congrats Ant Nee, following along closely. The pics of the kids piled in the Merc are priceless. Thanks for doing what you do, in the cl***room and here on the HAMB. Much respect. Don't recall a thread where I wanted to hit like on most every post. I bet if you did a mess of L and XL shirts, you could make some foldin' money for the project fund.
  24. No folding $$$ for me.
    I fund my own stuff but we do raise $$$ to send students to compe***ion and do small jobs to help fund the shop. I’ve got a small but decent budget to keep the practice/instruction going. We had around 50 large refrigerant tanks that we made Halloween Jack-o-lanterns out of. Sold em and put that $$$ back in the program.
    I fund my projects thru swapping/trading metal work for parts and pieces. Plus my wife has a better job than I have, financially speaking. :)
    I’m a pro level scrounger. Plus Ive been saving up parts for years to build one of these.
    so far the drop is less than $100. Shoes, wheel cyls, master cyl, hoses, seals and shocks have come in around $300. The car came with fresh drums.
    the suspension is tight and we will probably just clean, grease, and install new dust covers.
    If the flatty runs, I’ll use it. If not Ive got backups.
  25. Shoebox Central for the win with the front seals. Ordered Tuesday. Gottem Thursday 9EB0F7A1-FF7F-46CD-904C-D7F46020F855.jpeg
    getting backing plates ready to ***emble
    Just a clean up and prime. Not over thinking this one.
  26. The dual MC won’t work with the headers on the flatty.
    We’ll still mess with the flatty for the next week.
    I think I’ve got everything I need to do the 283.
    Gotta crawl under one of my parts cars to check out the trans. Using the older style flatty trans equals no clutch mods.
    Moondog13, Outback, winduptoy and 7 others like this.
  27. bobss396
    bobss396
    I sourced all my '59 brake parts from Rock Auto, used the old manual star wheels over. The backing plates just needed a wire brushing. Anything else rusty on the car went into the citric acid bath.
    Okie Pete and anthony myrick like this.
  28. guthriesmith
    guthriesmith
    Shoebox Central is good to work with. Since they are local, I have gone to a couple open houses down there and know the owners. Good folks. :)
  29. What in the deliverance hillbilly **** is going on here
    628421FE-8996-4AA8-9105-957A8DA5D8B0.jpeg FA4F9BF7-D46C-499A-9D17-64A8168723EA.jpeg 4133AF01-BCEB-41F6-B48C-B12DE0CEB570.jpeg
    harvesting the good off this beater.
    Has the earlier style trans. All linkage is complete. This would work if I plan to swap the engine.
    Engine is complete.
    Could use the stock manifolds if I wanted to use the dual pot master cyl
    Had a 2 door garnish molding. Well I be
