Technical keeping bare metal from rusting
Discussion in 'Traditional Hot Rods' started by m.ralph, Feb 14, 2023.
  1. m.ralph
    m.ralph
    What is good to put on bare metal body to keep it from rusting. I used metal etch but I can still see rust starting to come thru.
  2. Phil P
    Phil P
    I wanted to be first to say it.:D paint
    Phil
  3. m.ralph
    m.ralph
    its not going to be painted.
  4. Phil P
    Phil P
    I was just pulling your leg. A lot of people talk about Gibbs oil.
    Phil
  5. m.ralph
    m.ralph
  6. deuce1932
    deuce1932
    from Australia
    "The Hamb is a forum not a library..."
    M.Ralph...Try Lanolin (from sheep wool)
    My FJ custom has been bare metal for 12 years with one light coat & I'm in a cold climate.
    Cheap & easily removed with laquer thinner if your not happy.
    210superair and elgringo71 like this.
  7. 49ratfink
    49ratfink
    keep it inside the house
  8. clem
    clem
  9. Deuces
    Deuces
    Ditto!....:rolleyes:
    dana barlow, bob b. and 210superair like this.
  10. -Brent-
    -Brent-
    Houston's average relative humidity is 90% so what works here in Utah won't likely be the best advice.
    I'd recommend talking to other Texans like @B*** or @MR. FORD whom have both run bare steel for years.
    My ***umption is that they use Gibb's but I'm not sure what else they do... like how often or where/how the cars are stored and whatnot.
    Budget36 likes this.
  11. '29 Gizmo
    '29 Gizmo
    from UK
    Best i found if its not clear coat you want is simple fully synthetic motor oil. That stuff creeps across the surface and is drawn into gaps and is extremely persistent. Apply with a rag or put a few drops on and work it in.
    Adriatic Machine likes this.
  12. dirt car
    dirt car
    from nebraska
    My experience with clear coat is spider trials of rust will eventually develop I presume from small scratches in the surface, not sure maybe some can explain what process takes place, I use the Gibbs product..
  13. 51504bat
    51504bat
    Gibbs oil
    gimpyshotrods likes this.
  14. Bad Bob
    Bad Bob
    from O.C. Baby
    I don't get the whole "bare metal" deal. Primer it, paint it, of ****, just spray clear on it. To me it's like leaving your fly open.
  15. krylon32
    krylon32
    from Nebraska
    Been using Gibbs for about 20 years worked great on the bare metal roadsters I built.
    rod1 likes this.
  16. theHIGHLANDER
    theHIGHLANDER
    Stainless...:rolleyes:
    slayer and CSPIDY like this.
  17. Dirk35
    Dirk35
    You live in Houston Texas. Paint it. Or move to Arizona, Nevada, or New Mexico.
    Chili Phil likes this.
  18. Dino 64
    Dino 64
    from Virginia
  19. A Boner
    A Boner
    Gibb’s, for the win!
    Dino 64 likes this.
  20. fabricator john
    fabricator john
    from venice fl.
    gibbs
    fabricator john
    miss you dad
  21. bob b.
    bob b.
    from peoria az.
    I say paint
    curbspeed likes this.
  22. Chili Phil
    Chili Phil
    Uhh you live in Houston? I suppose you could keep oiling it. The next caretaker will hate you when he tries to get paint to stick. Bare metal is a fad that will eventually end.
    curbspeed, slayer and Just Gary like this.
  23. dwollam
    dwollam
    Another for Gibbs.
    Dave
  24. A Boner
    A Boner
    Did anyone mention paint?
    curbspeed and Chili Phil like this.
  25. 65pacecar
    65pacecar
    from KY, AZ
    rod1 likes this.
  26. Rocky
    Rocky
    Classified Editor
    Gibbs worked for me. It's the only petroleum product my body man will allow in the shop. Wipes off with lacquer thinner. 34rear3_4ths2016.jpg [/ATTACH]
    lo c dan, 210superair and Budget36 like this.
  27. I use drain oil and kerosene (diesel fuel) on my ch***is to keep them from rusting.
    While I have screwed lots of cars together over the years that never actually got a finished paint job I have never owned a forever car, so I probably would not consider that whatever car I own will never get painted.
  28. 210superair
    210superair
    from Michigan
    That car is sick.....
  29. Beanscoot
    Beanscoot
    Aw c'mon, you're in Australia!
  30. dart4forte
    dart4forte
    from Mesa, AZ
    I like your ride
