Technical 1935 ford coupe rear window trough repair
Discussion in 'Traditional Customs' started by Do it Over, Feb 14, 2023.
  1. Do it Over
    Do it Over
    from NYC, NY
    Since I got this project I've been sweating doing this repair. I worked it up to be some big complicated job. Turned out it was cake like many have said. I used machine screws and rivnuts to make it removable so I can drop out the rear window when needed.
    lewk, Fordors, RICH B and 2 others like this.
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Clever
    Could use B4 and after shots.
  3. Happydaze
    Happydaze
    Nicely done!
    You've obviously noted there is only one drain point and the trough angles downward slightly toward that drain for obvious reasons. However, slightly tongue I cheek, I'd suggest drains at both ends. I had my 36 parked on a fair incline, side to side, and unbeknown to me the drain side was uppermost. Following some heavy overnight rain when I jumped in and drove off, turning to head down the hill, there was a minor tidal wave of rainwater toward the drain which was overwhelmed with the excess water spilling over the trough and soaking everything in its path. Not a catastrophe as I had no interior, but I would have been pissed if I did have. Don't park on a hill in the rain!
    Chris
    Do it Over likes this.
  4. Do it Over
    Do it Over
    from NYC, NY
    There wasn't much of the before. Just some very rotted danglers
  5. RICH B
    RICH B
    Nice job. Don't forget to add the tabs for the package shelf like I did.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Thanks "Do it Over"
  7. tim troutman
    tim troutman
    really nice work very impressive doing the same job to day on my 32 using upac parts impressed with how well they fit 20230215_144040[1].jpg
    dlw1932 likes this.
  8. Do it Over
    Do it Over
    from NYC, NY
  9. Do it Over
    Do it Over
    from NYC, NY
    I agree. Originally I planned on draining from both sides. When I take it down to prime & seal it I'll add the additional drain :)
  10. TagMan
    TagMan
    I had sheet metal damage at the floor board/ running board area, where the drain hose from the rear window gutter attached over a small ****** fixed to the floor was loose, allowing the water to leak outside the ****** and onto the floor. When I made the repair, I made a larger size ******, allowing the drain hose to go inside the ******, to prevent recurrence of the leak.
  11. Do it Over
    Do it Over
    from NYC, NY
    Good idea. That's what I'm going to do. I want the hose to be below the body.
