Hot Rods Dressing a SBC to look more Traditional
Discussion in 'The Hokey Ass Message Board' started by Jive-Bomber, Feb 15, 2023.
  1. Jive-Bomber
    Jive-Bomber
    MODERATOR
    This will sound silly to most of you SBC aficionados, but I've never actually had a Chevy-powered hot rod or custom in my life. I just picked up a roadster with a 69-70 350 c.i. (2bbl) motor and I want it to look more late 50s/ early 60s style. What are some best 'bang-for-the-buck' bolt-on pieces I can purchase to make the motor feel more period correct? It's under a hood most the time, but just want to remove the OEM 70s feeling as much as possible.
    Thanks!
    ffr1222k and 1Nimrod like this.
  2. Taboo56Chevy
    Taboo56Chevy
    finned valve covers, just has to have a PCV/Breather cutouts for a simple bolt on. You can bolt a early cast iron 4bbl intake on and run a Carter carb, or a multi carb setup. Kind of have your choice of air cleaners depending on the setup. Ram horn exhaust manifolds and then a points distributor give it that vintage look. With ram horns you can then run the plug wires like a early corvette where they run down the back of the block and come up from the bottom.
    The motor in my 33 pickup is a 70 350 block. 250257773_7091109664236060_3036917920587044057_n.jpg
  3. lostone
    lostone
    from kansas
    There are numerous threads on this, there was another one just over a week ago.
    RodStRace, X38, 1Nimrod and 1 other person like this.
  4. pprather
    pprather
    A little bling in the right places distracts the eye from those tell tale non-early items.
    WC145, drdave, 72yenkonova and 6 others like this.
  5. DDDenny
    I always need to ask define "traditional".
    265/283, 327 etc.
    choptop4 and Deuces like this.
  6. DrJekyllMrHyde
    DrJekyllMrHyde
    Are headers early ‘60, style?
    When did they start to be common practice?
    I’d set for Corvette 2,5” ramhorns on my 327 in ‘40 Ford.
    pprather likes this.
  7. el Scotto
    el Scotto
    from Tracy, CA
    Depends what style you want. I'd consider an oil fill intake manifold a must as the oil fill was stock up to 1967, avoid an HEI distributor as they started in the 70's.
    Going for a low buck 50's look? Stamped steel script valve covers, painted four barrel intake, 55-59 Chevy or simple chrome air cleaner, ram's horns exhaust manifolds. Generator for bonus points.
    Going sixties styled? Finned aluminum valve covers, four barrel intake and simple chrome air cleaner, maybe ram's horns manifolds, maybe headers.
  8. Kerrynzl
    Kerrynzl
    @el Scotto
    And a short waterpump
    extra bonus for a gl*** bowl fuel filter, and plug leads routed under the ramshorns [with "banana shields"]
    UNCLECHET, 61Cruiser, WC145 and 15 others like this.
  9. 26 T Ford RPU
    26 T Ford RPU
    Ok, this is a 283 but you can use an early intake with the tube and retro fit a PCV system in the back of the manifold and plumb it into the carb (plenty of how to do on here) then you can run valve covers with no openings etc. If you are going to run an alternator it would look better to keep it off the top of the engine, make it not stand out. The main giveaway of a large journal is the balancer up front but that's really about it. JW
  10. aussie57wag
    aussie57wag
    from australia
    At the end of the day they are more common than Toyota corollas. And about as interesting. Just about e erysipelas budget minded modified car has one.
    The 265 and 283 was arguably one of the least powerful engines until the 327 the 327 is probably the best sbc.
    I have seen them look real good a traditional car when it looks like a stock engine freshly pulled from a nearly new 55 or 57 chev. Complete with factory air cleaner. Also the factory fuel injection is pretty cool too.
    Anything is generally common place from a catalogue. It takes a keen eye who knows what they are looking at to spot some rare original performance or dress up item that's not currently available.
  11. oliver westlund
    oliver westlund
    You know...an sbc IS A PERIOD CORRECT ENGINE. Many dont like that fact but it is... late 50's being the period. Shoot, i have a 57 vette 265 in the garage right now. Early corvette valve covers are aluminum and finned and cool btw. Sbc isnt my first engine of choice and if i was in your shoes i wpuld probably sell that 350 for great money and buy something actually period like my 265 and itd bolt right up...mostly. can get cloth wrapped plug wires from wired customs
    SPEC, MikeRose, 57JoeFoMoPar and 3 others like this.
  12. clem
    clem
    Anyone know if the one shown (speedway motors? ) is available in New Zealand ? Thanks !
    Edit : Sorry, I think I just did the hijack a thread thing ……..
  13. 55chevr
    55chevr
    The Corvette script GM valve covers were on every SBC in a hot rod.
  14. 1Nimrod
    1Nimrod
    Mid 60's Edelbrock,C4B,C3B or a C3BX. IMG_20190314_064351183.jpg 1NIMROD
  15. Just Gary
    Just Gary
    Piggy-backing on @Robert J. Palmer 's post. Just make it look like a 'vette engine.:cool:
    corvette 1959 01.JPG corvette 1959 02.JPG corvette 1963 327.jpg corvette dual quads.jpg corvette engine 01.jpg corvette transplant deuce.jpg
  16. Bob Lowry
    Bob Lowry
    One more...if you had money in the 60's, Corvette valve covers, if not, maybe chromed GM covers, if
    no money, nicely painted stock covers....
    WC145, AHotRod, Desoto291Hemi and 2 others like this.
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Get some magazines from the era you want to replicate. What they look like in there is what they looked like.
  18. el Scotto
    el Scotto
    from Tracy, CA
    I say this all the time. They're better than new car magazines and the stuff is an actual window to the time period.
  19. Deuces
    Deuces
    Knowing me, I'd probably make it look like a '69 302....:rolleyes:
    Here comes the **** storm.....:eek:
    Moedog07, TERPU, Brian Penrod and 5 others like this.
  20. Bandit Billy
    Bandit Billy
    This thread reminds me of Charlie Sheen's character from Two and half Men, he goes to the Dr regarding a rash on his gentlementalia, the Dr asked him if we was using hair dye on his *****. The answer was affirmative to which the Dr replied in an Indian accent (dot, not feathers) "We have an expression in our country, you can put a tuxedo on a goat, but it is still a goat".
  21. Blake 27
    Blake 27
  22. 05snopro440
    05snopro440
    Currently, with a MotorTrend+ streaming service subscription, they have every Hot Rod Magazine ever published available to read on the app. It's a great reference for what old hot rods looked like at various time periods in history.
    Deuces likes this.
  23. Pass The Torch
    Pass The Torch
    Any "Cal Custom" doo dad will be suffice. (Air cleaner, fuel pump block-off plate), and a "Say Why-And" intake for mine. In the pic is a Weiand water pump, which leaked shortly after I put the car on the road.
    WC145, mvee33, VANDENPLAS and 2 others like this.
  24. Kerrynzl
    Kerrynzl
    This isn't hijacking a thread.....but staying true to the topic
    Try Chuck's
    Weber specialties in Auck have a Malp***i unit [but crazy expensive]
    But if you want a vintage look...........hunt through Ag and Tractor supplies
    Deuces, Desoto291Hemi and Just Gary like this.
  25. clem
    clem
    @Kerrynzl
    Thanks, I will try Chucks.
    I had actually started looking at the tractor suppliers as being a farmer I remember the older tractors with similar gl*** filters.
    Clemens
    Desoto291Hemi likes this.
  26. 1biggun
    1biggun
    I saw a late model block were the guy drilled a hole through it below were the rear of the intake sits .
    He had a tapered pipe thread bushing in it and screw in PVC valve at a 90 into that .
    I recall it because I was looking at it to see if he had hidden nitrous lines there .
    I asked the guy about it and he said he wanted valve covers with no holes and a PVC valve still .
    He had a oil fill tube on the intake .
    Other than a short line going to the intake under the carb you could not tell he had a PVC valve .
    Was thinking of doing it so I can run my 57 2x4 Vette intake maybe with side ways Holly's ( been looking for correct vette carbs $$$$ and some old vette valve covers with breathers that unfortunately got installed years ago. Lot less oil blowing all over then .
    I have seen fake road draft tubes that were really hard to spot .
    The damper generally gives it away. I have see small dampness on a 350 but I would not do it .
    Not worth it to fake out maybe 3 guys at a show that might even know the difference.
    A old Mallory or tack drive vette distributer or old cast standard distributer . Rams horns if you want or period correct headers .
    I grew up when SBC was the go to replacement for a flat head and many other engines.
    A very early 60's car with SBC is about as traditional of period correct as you can get.
    Yes there to common and boring now but if I was building in 61 I'd have wanted a SBC. Still do.
    Deadbird, jim snow, Blues4U and 2 others like this.
  27. Kerrynzl
    Kerrynzl
    You can also use some small diameter tubing under the manifold and up inside the oil filler tube [with a hosetail sticking out of it]
    with a Breather cap you want the PCV to pull air away from the breather [hence the tubing]
    Some Corvettes had a cap instead of a breather on the filler tube and a PCV was connected to the oil filler.
    They usually vented in at the rear "Tomato Can", and vented out via the PCV filler tube
    WC145, vinfab, Deuces and 1 other person like this.
  28. badshifter
    badshifter
    The majority of what shouldn’t be done is accidentally? already covered in this thread. No blue plug wires on billet wire looms. No smooth/billet master cylinders. No late model alternators. No long SBC water pumps. No block hugger headers. No A/C compressors, especially Sanden 508s, no vinyl wiring with crimp connectors. No late worm drive hose clamps. AN fittings should have previously been on Aircraft. Exceptions to every rule, but basically, as mentioned, if you don’t see it in the pre-mid 60s magazines, it shouldn’t be there now, IF you are truly attempting to be legit “traditional”.
  29. Bob Lowry
    Bob Lowry
    Like this?
