Hot Rods Small Block Chevy Mystery Motor
Discussion in 'The Hokey Ass Message Board' started by bulletpruf, Feb 16, 2023.
  1. bulletpruf
    bulletpruf
    Fellas - I got a small block Chevy in a parts deal recently; it's said to have had a performance build, but that's all I know. Figured y'all might want to tag along as I figure out exactly what I have.
    Here's the starting point.
    Plan is to go step-by-step and shoot a video for my YouTube channel. Figure I'll start with block casting number, front pad code, crank flange, and then proceed with dis***embly.
    How would you proceed?
    Thanks,
    Scott
  2. squirrel
    Numbers help. Proceed.
    but I'd pull the valve covers and intake and see what I see, before taking it apart.
    The casting number tells us it's a 350 block from the 70s, more or less. Most of those are 4 bolt truck smog motors, but they also usually get some different parts added when they get rebuilt/hot rodded.
  3. theHIGHLANDER
    theHIGHLANDER
    Jim beat me to it. To be fair I'd be cheating cuz I got one handy, same casting. I'ma guess there's an "010" on the side of the block too, yes? Lotsa urban legends abound about that.
  4. squirrel
    But in reality, having the 010 on the side of the block just means it's a later 70s casting, as Chevy started adding the last 3 of the casting number to the side of the block in the later 70s, most likely to make it easier to spot which block is which, on the line.
  5. brett4christ
    brett4christ
    Any stamped numbers on the front block pad in front of the p***enger head?
    bulletpruf and Deuces like this.
  6. bulletpruf
    bulletpruf
    Well, I just got it rolled outside and ready and things got interesting real quick. I suspect some of y'all know why...
    Deuces likes this.
  7. Dave G in Gansevoort
    from Upstate NY
    Well, it's in a Corvette frame, so that makes it a Corvette engine! But aren't they all?
  8. bulletpruf
    bulletpruf
    Here's the hint again...
    47chevycoupe likes this.
  9. bulletpruf
    bulletpruf
    010 on both sides of the block.
    Deuces likes this.
  10. Baumi
    Baumi
  11. Baumi
    Baumi
    ... but shouldn´t it have camel humps then?
  12. Deuces
    Deuces
    Looks like a cast iron crank... You can tell by the thin parting line on the flywheel flange...
    bulletpruf likes this.
  13. bulletpruf
    bulletpruf
  14. Deuces
    Deuces
    Is that a 400 sbc crank???...:confused:
    Duh, just answered my own question...
  15. 47chevycoupe
    47chevycoupe
    from Finland
    010 block casting is 4" bore
    Crank flange is 3.75 stroke
    Manual trans pilot bushing
    Can have stock short 400 rods and stock 350 pistons. I have built several that way.
    gimpyshotrods, bulletpruf and Deuces like this.
  16. bulletpruf
    bulletpruf
    Someone is paying attention!
    Deuces and theHIGHLANDER like this.
  17. bulletpruf
    bulletpruf
    Winner winner chicken dinner! I'll pull the pan shortly.
    gimpyshotrods and Deuces like this.
  18. squirrel
    1978 truck 350, built June 3rd, 1978. And it's a used engine, not rebuilt.
  19. lippy
    lippy
    from Ks
    I agree with Jim, TDS is 350 truck engine block. Lippy
    Deuces and bulletpruf like this.
  20. guthriesmith
    guthriesmith
    I just found this same surprise when pulling apart a mystery performance small block earlier this week. However , I didn’t think to check the crankshaft flange. I just measured the stroke since the heads were already off.
  21. bulletpruf
    bulletpruf
    It's had a Craigslist/rattle can rebuild.
    Deuces and squirrel like this.
  22. squirrel
    that's a 350 crank, isn't it? The 400 is more squared off.
  23. milwscruffy
    milwscruffy
    Flywheel and dampener would tell the story.
    bulletpruf and big duece like this.
  24. theHIGHLANDER
    theHIGHLANDER
    Looks like a 4 hundy to me, like someone tossed a 383 together some years back. Easy, relatively cheap back in the day. The venerable "010" block was desired for that cuz as was said above many were 4 bolt for light truck.
    Urban legends went from factory big bores to the 010 meant 10% more nickel like race blocks. There were a few more but those were top 2 around Motown.
  25. 1971BB427
    1971BB427
    from Oregon
    Wonder how they got the oil pan to seal with the edge seals on the wrong side for the dipstick?
    bulletpruf and hotrodA like this.
  26. Fordors
    Fordors
    I agree on it being a 400 crank, that extra little notch in the casting says that.
    TDS doesn’t show up in info I looked at but it’s safe to say the block did come out of a van or pickup. Those heads are 76cc smog chamber, stock they came with 1.94 In and 1.50 Ex valves and the ports flow decent for what they are. From what I can see it looks like that might be an aftermarket aluminum intake manifold.
    And as @theHIGHLANDER said the 010 high nickel BS is nothing more than urban legend.
    guthriesmith and bulletpruf like this.
  27. squirrel
    that gasket has a hole, you see the edge of the hole...there's material between the pan and block. They've figured out how to make "universal" gaskets that fit everything, but don't work quite right on anything.
  28. bulletpruf
    bulletpruf
    Yep, 400 crank. I was pleased as punch when I saw that about an hour ago. The notch is a giveaway, and it's also wider at the end where the notch is.
    Deuces likes this.
  29. squirrel
    I bet you'll be disappointed when it turns out it has a 3.48 stroke. Oh well. pull the heads and measure it, a tape measure has enough accuracy.
    bulletpruf, saltracer219 and Deuces like this.
  30. Deuces
    Deuces
    Desoto291Hemi and bulletpruf like this.
