Technical Cragar Blower Drive Tensioner ID Help
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Feb 16, 2023.
  1. CTaulbert
    CTaulbert
    from Detroit
    I'm hoping someone on here can confirm the details of the gilmer tensioner in this original Cragar ad. I'm working on a car that's missing it, and I'm coming up dry locating one to put back on it.
    It appears that it's just flat plate, so I may be able to replicate it ***uming I can get some more clear photos of what the whole things looks like. I'm also ***uming that it may have a spring that provides constant tension on the idler pulley. It appears to share the front cover bolts for mounting.
    If you happen to have one, please drop in some photos/measurements/anything that can help!
    Tim and kadillackid like this.
  2. gimpyshotrods
    gimpyshotrods
    I am not sure how long these were produced before Cragar started casting their own front cover, that had the tensioner boss in it.
    This one is for an original GMC/Detroit Diesel front cover.
    It is a cool piece for sure. I hope that you find one.
    One thing to keep in mind, if the destination is a street vehicle, this is a drag race piece.
    This puts the blower drive belt right through where the water pump would be on a street vehicle.
    kadillackid, winduptoy and CTaulbert like this.
  3. CTaulbert
    CTaulbert
    from Detroit
    This car won't see much actual use once it's done - and it ran an electric water pump in 1961!
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    1967 Moon catalog
    62D458AB-FB39-4C3D-9010-9AE40BD54232.jpeg D16E0EA8-34D6-4FCD-9A4F-6C0C9FFC724A.jpeg 377EC030-CB65-4250-AE08-724C24F0B708.jpeg 4B856D63-78B8-4BA4-AE6A-9E4F9F813DD1.jpeg
    lewk, rod1, kadillackid and 2 others like this.
  5. alchemy
    alchemy
    "You don't know what I got"
    Tim and CTaulbert like this.
  6. gimpyshotrods
    gimpyshotrods
    As my dad called it "Little Doo Scoop."
    I am pretty sure it had a different tensioner, though.
    CTaulbert likes this.
  7. dreracecar
    dreracecar
    from so-cal
    Since it looks to be plate instead of cast aluminum, would not be that difficult to machine/duplicate. Even easier if you could borrow one to get the dimensions from. 1960's aluminum looks the same as 2023
    kadillackid and CTaulbert like this.
  8. IIRC, that particular Cragar set up had a spring tensioner on the idler bracket. IIRC it was a rotary spring.
    kadillackid, Bob Lowry and CTaulbert like this.
  9. CTaulbert
    CTaulbert
    from Detroit
    I've been trying to figure out if they packaged a rotary spring, or if it had a push or pull spring? There isn't a gap between the parts, so I'm thinking a push or pull spring?
    Also, I'm thinking that bolt above the pivot might be where the spring attaches? CT_01.jpg
    kadillackid and winduptoy like this.
  10. Fordors
    Fordors
    Cory, I don’t think that early tensioner was spring loaded, when I bought my Dyer drive kit in 1975 I was told to adjust the idler pulley to give 1/2” of slack when I pushed on the drive side of the belt. Too loose was no good and too tight might snap the crank snout.
    Those old Cragar drives that used v-belts needed the spring tensioner because the belts slip and can jump up and down. The Gilmer belts are positive drive, you adjust the idler to give the proper slack on the belt.
  11. swade41
    swade41
    from Buffalo,NY
  12. CTaulbert
    CTaulbert
    from Detroit
    If that's all that is needed, it will be a very easy part to replicate!
    Tim, kadillackid and winduptoy like this.
  13. hemihotrod66
    hemihotrod66
    Looks like the same idea that Weiand uses...
  14. rod1
    rod1
    Please show us Cory! Inquiring minds..
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Look what I found... I thought I had seen one before. Let me know and I can take it off and trace it for you. Looks like chrome plated steel and there is no spring
    9682B91B-BC66-4251-9501-F57B61FC8ABF.jpeg 131AF9A1-76D9-48D9-9752-D6509DC65ED1.jpeg D1BD549B-6D39-443F-B78E-4CD9FA7B6005.jpeg A80C353B-982E-4681-8422-10B44AA4A858.jpeg
    lewk, Tim, kadillackid and 7 others like this.
  16. tomcat11
    tomcat11
  17. CTaulbert
    CTaulbert
    from Detroit
    Tim, kadillackid and Moriarity like this.
  18. I have had several for hemis. None had a tension spring. They had a plate with the slot to slid the idler for tension. If you check your tension when the engine is hot, you will be able to see that you don't have it too tight. Most of the stuff on the HAMB is steel heads and block so the expansion rate is minimal as compared to alum.
    kadillackid likes this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    Will be in the mail next week
    lewk, 40LUV, Tim and 6 others like this.
  20. kadillackid
    kadillackid
    Legend.....Power of the HAMB :rolleyes:
