Hot Rods Dressing a SBC to look more Traditional
Discussion in 'The Hokey Ass Message Board' started by Jive-Bomber, Feb 15, 2023.
  1. DDDenny
  2. Fogger
    Fogger
    I own two running cars with '57 283 engines, it's easy to spot the ones that are faked up with phony road draft tubes, small crank dampers and plugged cylinder head bolt holes. I personally don't understand the reason to try to p*** off a late model for an early engine. I will admit to using a alternator instead of a generator though. That's a '64 Vette 461 intake manifold with an adapter for the WCFB. Roto-Faze dual point distributor and a 097 solid lifter cam. It's been a great combination.
    WC145, GlassThamesDoug, cvstl and 9 others like this.
  3. badshifter
    badshifter
  4. AHotRod
    AHotRod
    I'd say this is a good example:
    lostone, A Boner, Fordor Ron and 11 others like this.
  5. Deuces
    Deuces
  6. Deuces
    Deuces
    Bob Lowry likes this.
  7. AHotRod
    AHotRod
    ... and this look would also be correct for the era you asked for.
  8. Kerrynzl
    Kerrynzl
    I hope it's in a car by now........ According to my computer , I stole that photo off the net on Friday, ‎11 ‎May ‎2018, ‏‎7:46:17 pm
    I was looking for ideas to get rid of the draft tube on Mimi's 57 [I managed to get the parts off a 65 impala]
  9. DDDenny
    Kerry
    Go ahead laugh, now, that engine was built in the mid/late 80's, still on the stand.
  10. Rusty Heaps
    Rusty Heaps
    Maybe this ‘74 model 350? I know, change the carburetor and breather, Q-jet, and swap out the alternator for a generator. AB10DE24-90E0-47E9-BDF0-B7896FA79CBB.jpeg
    WC145 and Deuces like this.
  11. badshifter
    badshifter
    That’s my 29 Model A closed cab pickup! The reason it looks period correct is because it is. There are no catalog or repop parts on it. The engine has 40000 miles on it out of a 56 Chevy.
    WC145, Rolleiflex, Deadbird and 6 others like this.
  12. LOU WELLS
    LOU WELLS
    from IDAHO
    You Will Need A H.A.M.B. Tag.. 21248487_1892237281100544_3801638008269377160_o.jpg
    Speed~On, Just Gary, Stu and 2 others like this.
  13. Splitbudaba
    Splitbudaba
    Here's my crazy attempt. New crate motor,thumpr cam, head work including grinding the front of each head, fill holes with cut off bolts and high temp epoxy. Then cut a piece of steel to match the camel bump shape and epoxy them on. Smooth them out and put them back on and paint. So far so good. The 62' valve covers help to sell the look. 168185ED-3547-403D-8C68-9DE706DE38F7.jpeg 4462766-80e1e5020c5365980c005271ac5067d1.jpg 3AFBCE21-7792-48FE-9769-8F79C1BEF840 (1).jpeg 50BD1D3C-F57C-49E3-8C92-76B2F23B8783.jpeg
    winr, rbrewer, stroker28 and 9 others like this.
  14. HOTRODPRIMER
    HOTRODPRIMER
  15. You can sill buy the filter from your local parts store, and it's a bigger filter than the spin on!
  16. sunbeam
    sunbeam
    the acc bolt cylinder heads are a dead give away
    Deuces and 26 T Ford RPU like this.
  17. Let’s see the Healey!….er roadster??!!!
  18. 05snopro440
    05snopro440
    The ***le of the thread was making it look "more traditional". That certainly has traditional vibes with modern things that a large majority probably won't notice or care about.
    High test 63, Irish Mike and MCjim like this.
  19. Dave G in Gansevoort
    from Upstate NY
    20220529_212658.jpg Traditional? The Hilborns and magneto were 60s vintage. The block was 75 over the counter 4 bolt main 4 inch bore. The heads were 492 angle plug heads ported by Mondello approximately 72. Looked like a sprint car engine anywhere from the early 60's to the late 70s.
  20. hrm2k
    hrm2k
    My 283 at the machine shop. Going into a 1917 RPU 12AA8CB0-AF6D-472A-9801-B4A8FD6209CF.jpeg
  21. Easy. Solid valve covers (stock "Chevrolet" or old aluminum), intake (stock or old aluminum) with a oil tube in the front (need to drill/tap intake behind carb for a pcv), points style distributor, short water pump and rams horn exhaust manifolds. If you want to get fancy then a 4 blade metal fan.
  22. 26 T Ford RPU
    26 T Ford RPU
    If the large majority won't notice and don't care that leaves the small minority that will notice and who will care.........so who are we trying to fool, yourself? JW
    2OLD2FAST, A Boner and '28phonebooth like this.
  23. I posted a breakdown here years ago but if you look at the early 60s Hot Rod Annuals the majority (by a small amount) of hot rods were still using cast manifolds. I don't have my notes handy but it started to shift towards all headers in the 63ish time frame?
    hrm2k and 26 T Ford RPU like this.
  24. Koz
    Koz
    Throwing this in the fray...... Built for my Vicky but went into a buddies '27. The second pic is it's replacement. [​IMG] PXL_20230128_224118554 - Copy.jpg
  25. Those breathers gotta go. They scream 1992
    PotvinV8 and hrm2k like this.
  26. 05snopro440
    05snopro440
    If it keeps you up at night that your engine isn't "traditional enough", you have the freedom to spend time and money to make it more traditional.
    The original question was making a SBC look more traditional, not making it 100% look like it was from 1955. Which it never will because the subject engine doesn't have the rear vent behind he manifold, has the later balancer, etc.
    IMO the engine HRP posted nailed the "more traditional" side of things given the ***ignment. Sure, you can go further, but with relative ease it looks way better than most 350's. It also leaves some ways to improve in the future if someone wants to gradually do that over time.
    Hilarious that badshifter was critical of the 700R4 tv cable (and several other things) not being traditional, and his profile pic is of a bagged square body Chev on large black wheels.
  27. Koz
    Koz
    I apologize for the hijack but does anyone actually know how bad it would be to use an early balancer on a later engine? I've seen it done more than once but have no idea of the lack of vibration dampening would be on a street driven car.
  28. DDDenny
    Your "early" and "late" timeframes need to be more defined.
    If for instance, early, you mean, 1955 to 1969(ish) the timing marks would be in the same location inline with the crankshaft keyway, these would all take various timing tabs that are spot welded to the timing cover, later engines had the timing mark to crank key offset approx. 8 degrees and had various timing tabs that bolted on with the cover bolts, both the balancers' diameter and width were also relevant. As for the early balancer, depending on the exact year and application, some did not even use a vibration damper.
    To most, the subtle differences don't matter aesthetically, but when trying to replicate an exact early period correct look, these later components stand out like a mink coat on a pig.
    Of course, if you are capable, the engine timing can be set with most any combination of components.
    Toms Dogs and 26 T Ford RPU like this.
  29. dan c
    dan c
    thank god nobody suggested "flathead-look" valve covers. YUK!
  30. Koz
    Koz
    I would be more concerned about vibration dampening than timing marks since a cam change along with dozens of other things make the factory timing marks pretty much a moot point anyway. I brought this up as it was mentioned in this thread about swapping out a damper for the early one. I've done this before with no apparent ill effects only because I'm accustomed to piecing together Chevys out of whatever guys have which seems to include a lot of early dampers. I have one on my Vicky only because I had it and I'd actually rather use good factory parts than an offshore part, even the cheap ones are about $80.00.
