Technical 57 Chevy truck vibration
Discussion in 'The Hokey Ass Message Board' started by Jbro1988, Feb 18, 2023.
  1. Jbro1988
    Jbro1988
    I recently picked up a 57 Chevy with a 235. Sometimes I get a really bad vibration throughout the truck when releasing the clutch. I noticed the front engine mount bushings were pretty much deteriorated so I replaced them and also put a new clutch return spring because the last one was some long rigged up spring. These haven’t fixed the issue. Is it possible it’s a clutch adjustment or does it sound like I should just replace the clutch all together? Thanks!
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Do you get under any other cir***stances like WOT in first gear? Also if you slip the clutch on a hill start.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you're talking about ," clutch chatter" then yes , replace the clutch , pressure plate , throw out bearing ,pilot bushing ,& flywheel ( or have it resurfaced by someone who has the equipment to Blanchard grind )
    Jbro1988 likes this.
  4. squirrel
    there are usually two different causes of vibration like that, which is called clutch chatter. One is that the engine/bellhousing mounts are loose, and when the clutch starts to engage, it throttle gets moved a little, then this starts a big oscillation of the whole engine in the frame. The spring cushion in the center of the clutch disc plays into this type of oscillation. In this case, looking at what is moving around as you engage the clutch might point you to what need to be fixed, and replacing the clutch disc itself may or may not help. I had a 59 Chevy truck with the six that would do this, I never did figure out how to fix it, aside from changing my driving habits.This truck had all new mounts, and new clutch.
    The other cause is the clutch "grabbing", because the surface isn't smooth, which is sometimes caused by oil on the disc, or burned spots on the pressure plate and flywheel. In this case, replacing the clutch and surfacing the flywheel is necessary.
  5. Jbro1988
    Jbro1988
    I knew there was a term I was looking for. Clutch chatter it is. Thanks
  6. Check the drive shaft carrier bearing may be bad.
    bobss396 likes this.
  7. TF has a 1 piece shaft.
    To the OP, it sounds like it's clutch time with a quality resurface of the flywheel like other said.
  8. Ok I thought it was one of the larger trucks with the two piece drive shaft w/carrier bearing.
