Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. XXL__
    XXL__
    I don't think so.
  2. Jack E/NJ
    Jack E/NJ
    from NJ
    Agreed. Maybe they made a mistake?? And it doesn't run? Another gear in the train is a power-waster even if counter-rotating offers some kind of other advantage. It's a mystery.
    Deuces likes this.
  3. Dick Stevens
    Dick Stevens
    The extra small gear makes the cam rotation the same in relation to the head!
  4. seb fontana
    seb fontana
    from ct
    Easy to have a cam made, just $$.
    XXL__ likes this.
  5. Fordors
    Fordors
    I bet Harvey Crane was happy to grind one for Pete.
    Deuces likes this.
  6. j hansen
    j hansen
  7. j hansen
    j hansen
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Puzzle solved.
    From the above macsgarage story:
    "Note the additional gear on the left bank, allowing a right-hand camshaft to be used on both cylinder heads."
    Chain driven cams required a unique cam for each bank to be ground beacuse
    "on one bank the cam rotates toward the intake follower, and away from the follower on the opposite bank. This in turn necessitated a unique camshaft for each bank, one a mirror of the other, so the opening and closing ramps would be properly located."
    Cutlas Fan, egads, loudbang and 2 others like this.
  9. j hansen
    j hansen
    Maybe not so unusual,,,,,but.
    JDMJNKY, Deuces, rusty valley and 3 others like this.
  10. noboD
    noboD
    Thank you, that got my heart pumping.
    Deuces and j hansen like this.
  11. Cutlas Fan
    Cutlas Fan
    Flyer has it right, I think.
  12. Jack E/NJ
    Jack E/NJ
    from NJ
    Prolly woulda been better to eliminate 7 gears and a cam with a set of push rods. Coulda code named it a CKO instead of a Cammer. 8^)
    Deuces and motoklas like this.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Chrysler engineers thought so.
    Deuces likes this.
  14. motoklas
    motoklas
    from Bern, CH
    Hello there!
    The set of pushrods is lighter and cheaper, but they wanted what was become a modern and unavoidable system for sporting and racing engines - overhead camshafts!
    Chains, gears, belts or king-axle, maybe horizontal pushrods, or pair of mini crankshafts (levers), or... for transmission between crankshaft and camshaft (s) - a lot of choices...
    [​IMG] [​IMG]
    However, maybe I am the only one questioning myself: should one small gear (right from the big central gear) besides turning the direction of camshafts revolutions - at the same time change the ratio of the entire right side of the gears? Making revolution of camshaft twice slower at right than on the left (considering left-right sides as on the photo)... All other gears are installed in a symmetrical position, giving an aspect ratio of 1/2 revolutions of camshaft (s) consider to the revolutions of crankshaft? Probably that I could be wrong about such solo-thinking?
    Ciao, Zoran
    (enthusiastic dilettante)
    The37Kid, Deuces and Jack E/NJ like this.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>The set of pushrods is lighter and cheaper, but they wanted >>>overhead camshafts! >>>
    True dat Zoran. But they apparently jerry-rigged a push rod block. Prolly done in haste to try to save money --- to play catch-up --- and of course to avoid also being AKA --- an xler knock off. 8^)
  16. Dick Stevens
    Dick Stevens
    The small gear is simply an idler so it doesn't change the ratio as it reverses the rotation of the camshaft so they can use the same camshaft for both banks.
    Deuces, motoklas and down-the-road like this.
  17. motoklas
    motoklas
    from Bern, CH
    YEEEES!
    Deuces likes this.
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    Never seen that one before. What is it's history and parentage?
    Fordors likes this.
  19. Fordors
    Fordors
    A Ford FE was the basis for his Top Gas dragster engine. He was a tool maker with a well equipped shop at home.
    alanp561, Jet96 and Deuces like this.
  20. 64 DODGE 440
    64 DODGE 440
    from so cal
    Dang impressive home built.
    seb fontana and Deuces like this.
  21. Everything I have on file for Jim Gonsalves...8.05 @ 187 in 1974.
    Jet96, KiWinUS, Deuces and 5 others like this.
  22. And of course Jim Green's Cammer.
    Jet96, KiWinUS, seb fontana and 6 others like this.
  23. j hansen
    j hansen
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  25. j hansen
    j hansen
    Found this on the Interweb,,
    LAROKE, Jet96, Thor1 and 7 others like this.
  26. Andy
    Andy
    Curtiss OX-5. Used in the Curtiss Jenny’s JN-4.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Interesting tripple.
    Where is the third exhaust port / pipe? Probably Tee'd into the other two exhausts??
  28. Jack E/NJ
    Jack E/NJ
    from NJ
    Early designs were allegedly twins supercharged by the 3rd cylinder.
    down-the-road likes this.
  29. AmishMike
    AmishMike
    ^^^. DKW 2 stroke GP bike. Interesting that drawing does not show true expansion chamber exhaust - the thing that made 2 strokes scream. Know a guy has one heavily modified from racing in the 60
