Projects 1955 Chevrolet
Discussion in 'The Hokey Ass Message Board' started by JCH, Aug 1, 2022.
  1. PeggySue
    PeggySue
    Looking good, what alternator mount did you use? I have the mount on the exhaust manifold on my 327. Want to go to different exhaust manifold but don't have the drilled holes in the head for bracket.
  2. JCH
    JCH
    from Upstate NY
  3. JCH
    JCH
    from Upstate NY
    I also got her running
  4. DDDenny
    And..................?
  5. JCH
    JCH
    from Upstate NY
    It sounds and responds very good!
  6. Jigger
    Jigger
    Beautiful work @JCH That's car is the full package!
  7. Jacksmith
    Jacksmith
    from Aridzona
    Have you been able to go for a spin?
  8. JCH
    JCH
    from Upstate NY
    Not yet still have to bleed brakes and install front gl***. Complete interior..
    rod1 likes this.
  9. JCH
    JCH
    from Upstate NY
    Slowly checking those tasks off. Back window and trim installed today! 0A1E728F-D771-4AC6-86F2-FB461C7D828B.jpeg
    Stogy, 1pickup, scotty t and 10 others like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pic for you. simply select full image when posting... looks good!!
  11. JCH
    JCH
    from Upstate NY
    Thank you
    Stogy and Moriarity like this.
  12. JCH
    JCH
    from Upstate NY
    All the gl*** is installed now. Rug and sill plates installed. Just waiting on my interior. Im having custom seat covers and door panels made. While I'm waiting just checking off the small tasks. Almost ready for the road!
  13. JCH
    JCH
    from Upstate NY
    Stogy, scotty t, Deuces and 5 others like this.
  14. JCH
    JCH
    from Upstate NY
    Moving the 55 ti the other garage bay.
  15. manyolcars
    manyolcars
    I love 55s and yours looks great!
    Moriarty said "select full image when posting"
    Toms Dogs and 54delray like this.
  16. DERPR30
    DERPR30
    from HARVEY LA
    S W E E T I LUV IT
  17. The lace job on the roof is choice and the intake with four carbs is cool!
    mario711 likes this.
  18. JCH
    JCH
    from Upstate NY
    IMG_7891.jpeg IMG_7893.jpeg IMG_7891.jpeg IMG_7893.jpeg IMG_7888.jpeg IMG_7893.jpeg
    Stogy, 1pickup, 40FORDPU and 16 others like this.
  19. JCH
    JCH
    from Upstate NY
  20. JCH
    JCH
    from Upstate NY
    Ok this is going to be a long post. Finally register the 55. Starts great idles great runs great for the first 10 miles engine temperature is running around 180. The problem is once the engine compartment gets hot the car falls on its face. So i know it was vapor locking and boiling the fuel on first carb. I put 1/4” isolators between carb flange and intake. I thought this would solve the problem. It did not. I did replace my pressure regulator and noticed I had 2-3 psig on fuel log gauge and now when its hot its zero? Its so hot under the enigine bay im thinking the fuel it getting to hot snd evaporating. I went 10 miles and used 1/4 tank of gas. No leaks I looked. Any suggestions?
  21. Daniel Dudley
    Daniel Dudley
    I can't see your radiator fan. Is it shrouded? Does it spin all the time?
  22. JCH
    JCH
    from Upstate NY
    it is shrouded. Engine temp is reading 180-200. Problem is hot air hits carbs. Thats why I made the deflector in picture. Its a mechanical fan.
  23. tomcat11
    tomcat11
    You might have to relocate your fuel filter, regulator and lines away from the cylinder head. Your interior is super sharp and goes really well with the rest of the car. Awesome build!
    54delray likes this.
  24. JCH
    JCH
    from Upstate NY
    American Flag!
    Stogy, loudbang and gotta56forme like this.
  25. gotta56forme
    gotta56forme
    from Seattle
    Great looking car!
    In the above profile photo, what is the shiny rectangle at the front of the fender, below the Chevrolet script?
    Gotta56forme/Scott
  26. 427 sleeper
    427 sleeper
    Try putting a cool can in the system and see if that helps, that could guide you to a permanent fix. ;)
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    What fuel pump are you running? Those round dial regulators are known to cause problems.
    Stogy, 54delray and 427 sleeper like this.
  28. JCH
    JCH
    from Upstate NY
    Just a stock sbc mechanical pump. I put a new regulator on it today. When i first started it i was reading 2-3 psig i have it set for 2. Now its reading zero? Everything i read and watch says no more than 2.5 psig on holley 94 carbs. Just odd when it gets hot it shuts down. My guess is the fuel is so hot its either evaporating or still boiling over. All the carbs are so hot you cant touch them. Same with the aluminum valve covers. Car was running at 180-200 on a 90 degree day according to mechanical temp gauge that is in the top of intake.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    Sounds like vapor lock, put a bag of ice on the fuel pump and see if it will start. I still have heard nothing but bad things about those round dial regulators
    Outback, footbrake, 54delray and 2 others like this.
  30. JCH
    JCH
    from Upstate NY
    Ok everyone 2 months and alot has happened with this 4x2 carb set up. Relocated the fuel regulator to the p***enger side inner fender. When the car is just started the fuel pressure is 1.5 psig. As the engine bay heats up to drops to zero. I think this is due to the rubber hose heating up and expanding. As for the car flooding out. It was the power valves leaking. Talked to a multi carb guy and he recommended removing the primary power valves He machines the power valves to make them flat so they seal. The seconday carbs already had plugs. After I replaced them and rejetted on his knowlege. I was actually able to drive the car without it flooding out. But it had this weird hick up when driving. So i decided to remove secondary linkage and just start with primary carbs. While idling on primaries with no fuel or linkage on secondaries I put my hand over rear carb and boom it ****ed it in. Same with front carb just not as bad. The base cross shaft was worn and ****ing air. Replaced all 4 bases this solved that problem. Now cold to warm car sounds and starts fine. Took it for a ride rolled into second carbs and it took tge fuel but after it started to back fire through the exhaust. Im wondering if im still getting to much fuel. Im going to remove secondary linkage and fuel to those 2 carbs and try to run it on the primary carbs and see if its drivesble. Currently have 50 jets in all four carbs. Its just a 327 with hardly any cam. Trying to get an idea where I should be jet wise. Any advice is appreciated!
    Outback likes this.
