Technical Speedway smooth aluminum windshield posts for '26/'27 roadster?
Discussion in 'Traditional Hot Rods' started by ShortyLaVen, Feb 19, 2023.
  1. ShortyLaVen
    ShortyLaVen
    Does anyone run a set if these aluminum smoothie windshield posts on their T roadster? Or have pictures of a car with them? I'm trying to figure out a windshield for my current project and have a set of these, but with no mounting holes drilled in them yet I don't have a good way of mocking them up.
  2. rudestude
    rudestude
    If you look up your parts on the speedway online catalog they have tech and installation pages that will probably give the info your looking for.
  3. ShortyLaVen
    ShortyLaVen
    I understand how to mount them. I'm looking for photos of them on a car, and general opinions of them. Mostly I'm unsure how I'll like them compared to stock style stanchions with separate windshield frame.
  4. They look like some ****era/Mr Gasket knock offs from the 90s BUT with a little tweaking they could be made to look nice. I took some stock posts and mounted the gl*** the same way. Bottom rubber is a T piece as well. The glue has not been cleaned up here.
    Gofannon likes this.
  5. ShortyLaVen
    ShortyLaVen
    That looks really nice! I think my biggest qualm with them is just as you stated: they look a little modern/cheap... so far I've only seen one car that they look pretty darn good on, but I can't really figure out what they did to them to make them work so well. Maybe part of it us just the style of car you usually see them on... 1927_ford_roadster_20220816_110058-20606.jpg
  6. rudestude
    rudestude
    Ok, I guess that depends on how traditional you want your car to be , they say 90's in my opinion, for mock up purposes, no drilling,try a two side adhesive tape .
    alanp561 likes this.
  7. I think by sofenting the edges and the tops you could do a lot to make em look less fabricated. But, if you notice, where I boxed mine they are still a sharp edge. You could graft on a pivot and top pin carved out of aluminum to look more stock like mine.
  8. KevKo
    KevKo
    from Motown
    I am pretty sure Pete Chapouris used them (or very similar) on the dark green T roadster he built many years ago. Good enough for Pete…
  9. tim troutman
    tim troutman
    my car had aluminum post when I got it was able to buy a stock type post & frame cut the post off & just ran the bottom windshield had it cut to match the curve of the cowl.. pictures are bad quality just photos of old photos predigital 20230219_192220[1].jpg 20230219_192232[1].jpg to me it looked so much better than the aluminum post with no frame
  10. Just Jones
    Just Jones
    I have a pair Id sell ya. They came on a roadster I bought a few months back but as I wont be running a windshield I wont need them. Let me know if your want them.
  11. 42merc
    42merc
    IT'S been two years. I'll bet he has it figured out.
    G_Don, Just Gary and Budget36 like this.
  12. A Boner
    A Boner
    Or still pondering
    Just Gary likes this.
