Technical GM Posi Additive shelf life?
Discussion in 'The Hokey Ass Message Board' started by squirrel, Feb 20, 2023.
  1. squirrel
    I came across 2/3 of a case of this stuff....seems to have settled...when I shake it for a while, there still seem to be some things floating around in there.
    Rumor is they used to make this with Sperm Whale oil. But that ended in the early 70s.
    The box has a date code ending in L8. From the shipping label printing, it's possible it's 1978, but not like to be 1968, since it was printed with a dot matrix printer, which hadn't quite been invented yet. And the history of the other stuff where I got it indicates that 78 is pretty likely, and 1988 is also. No whale oil by then, though?
    Anyways, I wonder if anyone would be brave enough to use this still? or is it just art now?
  2. scrappybunch
    scrappybunch
    from nj
    Here at the dealer, GM had those bottles well into the 90's even 2000's.
    We used to get wholesale parts from Lustine in the late 90's too.
    I would use that fluid, no problem.
    When I started at dealers in '77 the sperm stuff was pretty much outlawed.
    chevy57dude, mad mikey and squirrel like this.
  3. squirrel
    Thanks. That helps!
    I found a picture of a later bottle that looks pretty much the same, but has the Goodwrench logo...which GM started using for service, and on some parts, in the late 70s.
  4. onetrickpony
    onetrickpony
    from Texas
    The "Important, rotate stock" warning would concern me. That indicates a finite shelf life. It may be just due to settling and appearance purposes but if you decide to try it, replace the oil at the first sign of any odd noises, clutch chatter, etc.
  5. 1971BB427
    1971BB427
    from Oregon
    As rarely as I need a bottle, and considering what a posi rear differential costs, I'd just buy a new bottle when I need it.
  6. tomcat11
    tomcat11
    Maybe the "rotate stock" was part of a GM inventory tax write off scheme:eek: I'd probably shake it up and use it. Especially if it was just a fluid change on an old posi.
  7. goldmountain
    goldmountain
    It rotates when you use it. Does that count?
  8. Bandit Billy
    Bandit Billy
  9. lippy
    lippy
    from Ks
    I would rotate it alright. In the differential. :D
    Bob Lowry and NoelC like this.
  10. NoelC
    NoelC
    I'd use it.
  11. lippy
    lippy
    from Ks
    Too new for me to use. :)
    squirrel and Driver50x like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Would cryopreservation have helped? :)
  13. 327Eric
    327Eric
    If your worried, use a paint mixer, or similar ********y device to mix any settled particulates. Even zip tying it to electric hair clippers for an hour or two would be enough for my peace of mind
  14. lippy
    lippy
    from Ks
    On the whales?
    XXL__ and tomcat11 like this.
  15. lippy
    lippy
    from Ks
    I don't care for all this ********, sperm talk on this additive thread lets keep it clean fellas. :D
  16. RmK57
    RmK57
    I’ve had this bottle for as long as I can remember. The C3 part number is still barely legible. It opened it, took a whiff and it smells bad, really bad. Would I use it? Probably, anything that smalls this bad has got to work.
    VANDENPLAS, jaracer, Cosmo49 and 3 others like this.
  17. 57 Fargo
    57 Fargo
    I wouldn’t hesitate to use it.
    VANDENPLAS and Desoto291Hemi like this.
  18. tomcat11
    tomcat11
    Yours must have the Whale sperm:D
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’s a breed, not to be confused with breeding.
    VANDENPLAS likes this.
  20. uncleandy 65
    uncleandy 65
    Use it , It's not like a loaf of bread on the store shelf.
  21. Slopok
    Slopok
    Heck, I wonder if anyone would be brave enough to get the Whale Sperm??? :eek:
  22. indyjps
    indyjps
    I'd say smell it and see if it's gone bad :D it smells Fn horrible no matter what.
    If it's still fluid and hasn't separated, I'd run it.
  23. '29 Gizmo
    '29 Gizmo
    from UK
    MD = manufacture date maybe so 1981
    Two things that degrade stored oil are oxygen and sunlight. If its kept sealed and in the dark it significantly extends shelf life.
  24. Jim ,
    Do you think the L8 might be a lot number ?
    And the date code was 5 8 2,,,,,2 being the year ? ,,,,,maybe 92 ?
    Who knows ,,,,,the bottles still look good,,,,as well as the oil inside,,,,good color .
    Tommy
  25. Pav8427
    Pav8427
    Use 2 bottles.
    Then for sure both tires will spin.
  26. Atwater Mike
    Atwater Mike
    Recall gay killer sperm whales biting the ends off submarines to **** out all the Seamen!
    Just heard it...
    alanp561, MMM1693, VANDENPLAS and 2 others like this.
  27. tomcat11
    tomcat11
    Well at least they can swim!
  28. 38Chevy454
    38Chevy454
    This ^^^^^
    I think the stuff is fine, just remix to get the stuff that settled out, back into solution.
  29. Sporty45
    Sporty45
    If you don't want to use it, I'd be happy to buy a bottle off ya ;)
  30. Budget36
    Budget36
    Is it still available these days? I recall buying at the Chevy dealer a few times, then noticed some other maker/brand in the additive sections in AP stores, but recently looking for some gear oil I noticed some jugs labeled “limited slip additive” on them. I wasn’t looking for it, but just didn’t notice it either.
