Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Plan B 283 adapter.
    Picked up 10 years ago for $50 at a swap. Didn’t need it. But wanted it just in case one day.
    This flatty in the parts 51 looks decent so far
    And a decent alternative bumper if I need it.
    and a clean merc carb. Not stuck.
    mvee33, williebill, Ford52PU and 12 others like this.
  2. 51504bat
    51504bat
    Make sure you get the U shaped spacers that go between the frame and the water pump. The Merc pumps on the engine you show are narrow belts that are like wide belt truck pumps but the mounting tabs are different heights which is why you need the U shaped spacers. If the engine is toast the pumps are worth something - no one repops them. And the 1/2 bell is used when installing an earlier trans to an 8ba.
  3. I’ll hang on to all of it. And my other merc engine has the narrow belts. Pumps still turn. Should be buildable.
    block looked much better than I thought it would. It’s been sitting for at least 40 years. Cracked? Don’t know. Has 8cm heads and should have the merc crank
    I pulled a flatty out of a 48 f5. It also had the 1/2 bell
  4. 51504bat
    51504bat
    The Merc 1/2 bell is stamped steel. Should have a 10 inch clutch. The 1/2 bell out of the f5 is cast and an 11 inch clutch will fit until like the Merc 1/2 bell which maxes out at 10 inch.
  5. Doctor Detroit
    Doctor Detroit
    Really cool build thread. Nice job.
    winduptoy and anthony myrick like this.
  6. Scrounging/cleaning in the shop I got a message from @Jakob H. He inquired about the bumper guards, the smaller ones for a 51. Yesterday, I decided that I’d run the bumper I pulled from the parts car. The more I looked at it, the better I liked it over the large bumper guards.
    0DE54845-8D3E-4DF5-9D27-4FFB77011A65.jpeg 082031C2-20E2-4C8A-887D-903DB84ECE73.jpeg
    If any you guys have a standard set of 51 bumper guards in driver quality, send him a PM.
    Thanks.
    Cleaning up the trans, gears look good. Super clean inside. Scrounged up the flywheel.
  7. It occurs to me that you, @anthony myrick , have been bitten by the custom bug ( y’all got it bad, don’t ya?)
  8. Been saving up for a while.
    I’ve had a merc since the mid 90s. Rough. Never started on it. I had a couple local guys that messes with them call me to pick up their left overs. A 51 and 49 parts cars.
    Finally started using the pieces.
    And finally bought one I dont have to totally rebuild
    Outback, Okie Pete, bchctybob and 4 others like this.
  9. guthriesmith
    guthriesmith
    This is the wise thing to do instead of the big project I am starting on. My only saving grace is that I have a couple others that I can play with while building this one.
  10. Another possible dumb move. Bought this 3 deuce intake years ago. Early small port.
    BEDE9C73-AE41-4CEE-B721-8FAC327A0881.jpeg 4E460C40-2E1A-4CFC-92FD-103408B7BFAF.jpeg
    we started welding it to enlarge the ports to add gasket room to work with the larger port heads.
    Wouldn’t take much to finish.
    Good or bad idea?
    Okie Pete, bchctybob and guthriesmith like this.
  11. guthriesmith
    guthriesmith
    For the cool factor, good idea. For a daily, I would just run a single four since 3 carburetors can be a pain at times.
    ffr1222k, Okie Pete, Algoma56 and 2 others like this.
  12. Ive got an early cb intake and a 4 jet carb.
    I’d like to run the 3 deuce.
    Finish working the intake ports and gasket match.
    I’ve got 3 or 4 ford 3 bolt carbs.
    I’d need a couple more 2 jets to use them.
    A friend of mine runs 3 Rochesters on a 348. Runs well. He worked with the 2 end carbs with valve compound on the ****erflys. They seal up very good. Using a progressive linkage.
  13. guthriesmith
    guthriesmith
    Me too and that is what I would run on something like that with a hood that will likely always stay shut. :D
  14. 57 Fargo
    57 Fargo
  15. 38Chevy454
    38Chevy454
    You *could* run the three carb intake on just the center carb, with non-functional dummy carbs on the ends. You would not be the first person that has done this. Especially for a SBC with the stock trans, the reduced power of one carb will still be more than the flathead had.
  16. We ain’t looking to out run anyone.
    Just cruise.
    I don’t mind getting p***ed
    Outback, Okie Pete, bchctybob and 3 others like this.
  17. A Boner
    A Boner
    Three Two barrel manifold with one working carb = cool looks (if you don’t look too close), and great fuel economy. An added bonus ******* off the ****’s, that take life too seriously!
  18. desotot
    desotot
    So,, just where the heck is this twilight zone. yer killing me.:)
    Okie Pete and anthony myrick like this.
  19. Somewherein Alabama
  20. Budget36
    Budget36
    ^^^^^ close to that “Sweet home”? ;)
    anthony myrick likes this.
  21. desotot
    desotot
    Too far for me to drive and buy some pieces, good song though.:)
    chryslerfan55 and anthony myrick like this.
  22. bchctybob
    bchctybob
    Welding the manifold is fine. Run what you have.
    You can do what I did, run the 3x2 setup on the center carb at first and later, when you feel like it, start working on making the end carbs work right. I found extra carburetors and worked on them while driving the car.
    Multiple carburetors rule, even with a full hood.
  23. Did some interior cleaning
    6D2E5F8F-6A23-45C3-9917-75A58A1C2130.jpeg 593F8AB2-909E-48CC-9311-F8B493005F1B.jpeg
    this week we have 9th graders that think they want to take our cl***es spend a cl*** period with us.
    Turned em loose with buffers.
    2000-3000 buff- polish.
    B7866A30-48B5-4688-9A61-5390FD3614A0.jpeg 75667FC3-CDE2-4483-A54D-3088059433FC.jpeg 8ED65930-F201-4597-93CB-5AD4B576C5BE.jpeg
    first time to do this for these 9th graders.
  24. I like that gunmetal gray paint ,looks good with red upholstery!
  25. bchctybob
    bchctybob
    Your Merc paint cleaned up way better than the paint on my Stude pickup has so far. Looks good! Seats look good too. That's shaping up to be one snazzy old car.
  26. ? Tag on the flathead.
    looks clean behind the fenders. Small easy piece needed at the bottom
    C934B2CD-46FE-4335-A256-0515731093E5.jpeg E61505C4-078F-4AEB-B83B-AFFC1433D007.jpeg
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    That is probably a rebuilder's tag on your engine.
  28. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Pay extra attention to the water p***ages in the block. They can have heavy corrosion deposits in them from years of people running water in them during the warm weather back before anti-freeze became common. Guys rebuild them and chase their tails with overheating problems when it turned out to be clog block p***ages. Just something to keep in mind. Good luck with the project! Larry
    what success looks like
  30. ClarkH
    ClarkH
    Congratulations! Man, I know the feeling. I kept the broken stud in my toolbox as a reminder.
    Outback, Okie Pete and anthony myrick like this.
