Hot Rods Flathead exhaust
Discussion in 'The Hokey Ass Message Board' started by RB35, Feb 20, 2023.
  1. RB35
    RB35
    Working on a new build, going to have a 276" flathead, L-100 cam, 4 bbl and center dump headers from Speedway. The headers have a 2 1/2" outlet which seems large for a flathead. Should I use their 2 1/2" pipe kit or reduce to 2" ? This will be more cruiser than hot rod, build thread to come soon for a Victoria length/style woody with '29 from the a pillar forward on an A frame.
    Looking for info that will help me out.
    Thank you,
    RB35
  2. 42merc
    42merc
    2 inch exhaust is plenty for a 276 flathead.
  3. tubman
    tubman
    A lot of folks like the sound of a flathead through two 1 3/4" straight pipes.
  4. krylon32
    krylon32
    from Nebraska
    I have used those headers a couple times and they sell a 2.5 down to 2.0 reducer with a flange to match the header. I then used a really short 90 made from a 2 inch donut to head back.
    Packrat likes this.
  5. Bandit Billy
    Bandit Billy
    I used 1.75" pipes on my flathead because that was the size of the 8BA connecting rods I used as pipe hangers.
    Dance with brung ya.
  6. rusty valley
    rusty valley
    Cast Iron Fentons, 1 3/4 pipe, no mufflers on my avatar. Sounds like a Chris Craft idling.
  7. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I worked for a Texas Harley Davidson dealership for 18 years. Back in the 90’s,2000’s and maybe later, an awful lot of Harley owners rid themselves of their stock exhaust —-meaning “donate” the old exhaust in favor of a whole new system. Most of the mufflers we are talking about came on Sportsters and medium size Harleys ——not on baggers and full dressers. They were bullet shaped, had the same size input and output and were chrome plated gl*** packs with a tack welded baffle inside. I would take a piece of pipe and a few sharp hits later,the baffle was removed. You could see from one end to the other(no obstruction) clearly and had perforated holes to “muffle” the sound. I have used them on three diff vehicles with gr8 results. Good sounding,chrome plated gl*** packs ,and all I had to do was fit them up. Had about a 1 7/8 diameter od on both ends and maybe 4 in diameter—-either end could be used for intake or exhaust—-they looked the same from both ends, and the best part they were always FREE!!!! 58490E81-5C42-4223-B4D4-D8E039918243.jpeg
  8. Pete1
    Pete1
    from Wa.
    My current engine is considerably bigger at 321 ci. The lead pipes is 2 1/8 and the flange outlet is 4 1/2.
    Don't skimp on size for exhaust pipe. With flatheads, bigger is ALWAYS better. I have used this same size header on 276 ci engines.
  9. Fortunateson
    Fortunateson
    What are you doing on the HAMB when that buck is waiting for you for a fill up? LOL
    Hillbilly Werewolf and Budget36 like this.
  10. da34guy
    da34guy
    This 1 had a killer 304 H&H built flatty in it, 2 1/4 straight pipes all the way out the back (no muffs)
    Was quiet inside, but out back it would rattle the wax outta yer ears when ya got on it Vicky finished 1.jpg
  11. RB35
    RB35
    Thanks a lot guys. I'm going to neck it down a bit and my friend gave me a set of Harley mufflers, so got to make them fit too.
