chevy II 153 four cylinder
Discussion in 'The Hokey Ass Message Board' started by junior 1957, Oct 21, 2012.
  1. A Boner
    A Boner
    I was thinking a little older looking, but I’ll read up on the Weber’s.
  2. dreracecar
    dreracecar
    from so-cal
    Harlen/Sharp 1.75 ratio, But you need a valve cover spacer(or tall aftermarket VC) and knock the corners off the outboard rockers to keep them from rubbing upload_2023-2-20_8-8-55.jpeg
  3. dreracecar
    dreracecar
    from so-cal
    Volkswagon Webber intakes
    Tim, banjeaux bob and Blues4U like this.
  4. Blues4U
    Blues4U
    from So Cal
    Great looking truck!
    A Boner likes this.
  5. Six Ball
    Six Ball
    from Nevada
    I haven gotten to the point to measure for pushrods yet. I'e only been putting this engine together for about 10 years. :rolleyes: But when I had the cam ground I had 1.70 big block roller rockers and have cam specks using them as well a 1.75s. When it is together I'll measure for both before order pushrods. Does anyone know for sure if pushrod guide plates are needed?
  6. dreracecar
    dreracecar
    from so-cal
    I opened mine up and using guide plates only for the fact that I have not put this combo together before and dont want to get caught later on needing to open the PR guide holes
    Six Ball likes this.
  7. A Boner
    A Boner
    Thanks, buddy and I built it in the mid 80’s! He built a 29 Tudor (his has a SBC), we built them side by side in his shop. He still has his too.
    D4AEE73F-1C23-4CE7-B69F-F0E1E66D11E0.png 99BA5A03-814A-4358-8F70-053D7C83DD4B.png
    Tim, X-cpe, Six Ball and 2 others like this.
  8. hotrodbob
    hotrodbob
    upload_2023-2-20_22-0-15.jpeg Chevy II 151 in my 29 Ford upload_2023-2-20_22-0-15.jpeg 1929 Ford Woody 19.jpg
  9. hotrodbob
    hotrodbob
    Clifford. I just got an adapter from them to mount a Holley/Webber type two barrel carb on it. The Chevy V8 carb is just too big. Runs way too rich and mounted like it is, it stalls when turning.
    A Boner, alphabet soup and Six Ball like this.
  10. Six Ball
    Six Ball
    from Nevada
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Didn't GM run a qjet on one of there ,4 cylinder engines ?
    I believe ford had a " progressive " 2 - barrel for the pinto 4 cyl , as well ?
  12. DDDenny
    The 66 Pontiac OHV 6 cylinder engine had a Quadrajet carb.
    2OLD2FAST likes this.
  13. The Tempest 4 could be bought with a small 4GC, but they were 194 and 1/2 cubic inch ;-)
    2OLD2FAST and Six Ball like this.
  14. hotrodbob
    hotrodbob
    Yep, but the carb was mounted facing forward like on a V8 so it worked better. The Poncho motor had more horse power too. The engine was offered in three horsepower ratings: 115hp, with 8.6:1 compression and a two-barrel carburetor; 140hp, with 10.25:1 compression and a two-barrel; and 166hp, with 10.25:1 compression and a four-barrel.
    The 153 was rated at 90 HP. I'm not sure what mods were or were not done to this engine. I'm going to switch to the Webber two barrel. Smaller venturis, mounts facing the right way and very tunable. I have a progressive version (Pinto/Vega) and the performance model that is not progressive. They are both 230CFM. The Rochester is 285 to 450cfm. Not sure which one I have on there now, but plugs show to be very rich. Thanks for your input.
  15. dreracecar
    dreracecar
    from so-cal
    Morning project
    Since the engine will be fuel injected, and was going to make a fuel pump cover plate anyway, Decided to make it my oil fill also
    ottoman, Tim, banjeaux bob and 4 others like this.
  16. Six Ball
    Six Ball
    from Nevada
    You could sell those!
    Tim likes this.
  17. Beanscoot
    Beanscoot
    What thread is on the oil filler neck?
  18. Nick Landon
    Nick Landon
    Well, I hate to say this, but I gave up. I found one of the welded up head stud holes had a Ccrack from there to a water jacket hole. I was able to get my 166ci Sesco Chevy back that I traded to get one of my grandfathers old super modifieds. The chevy II racing parts I am selling to someone who is building a vintage midget. The Sesco Chevy original came with my midget and after my step father p***ed it became available. I promise not to hijack this thread, but here's is what I have to work with.
    Nick Landon
    Feather Ruffler Engineering
    Landon Racing
  19. dreracecar
    dreracecar
    from so-cal
    AN -12
    Tim likes this.
  20. dreracecar
    dreracecar
    from so-cal
    Machined up the new timing cover that I will mount the 4/71 blower to. Need to make a 2" spacer because of the length of the drive coupler
    upload_2023-3-3_8-13-45.jpeg upload_2023-3-3_8-14-6.jpeg upload_2023-3-3_8-14-26.jpeg upload_2023-3-3_8-15-45.jpeg
  21. X-cpe
    X-cpe
    Six Ball and 2OLD2FAST like this.
  22. Tim
    Tim
    from KCMO
    4-71 I like what I’m hearing!
  23. Six Ball
    Six Ball
    from Nevada
    Impressive work. Makes me wish I had skills. I want to see the videos to this thing running!
  24. Six Ball
    Six Ball
    from Nevada
    Two of the critical skills are to be able to tell when your plan is no longer a good one and being able to see the best path forward.
    Nick Landon and X-cpe like this.
  25. Kinda like "a good run is better than a bad stand". Gene.
  26. dreracecar
    dreracecar
    from so-cal
    The difference between an amateur and a professional---The Professional knows when to give up and start over again because there is no saving it
  27. dreracecar
    dreracecar
    from so-cal
    More chips today, same part, as it goes between the blower and the timing cover upload_2023-3-3_17-13-17.jpeg upload_2023-3-3_17-13-32.jpeg upload_2023-3-3_17-13-51.jpeg upload_2023-3-3_17-14-8.jpeg
  28. Nick Landon
    Nick Landon
    I hate to do it, but I need to finish the car up. It's been a sad running joke with the amount of problems I've ran into and delays of progress. The Sesco has all the engineering done, I just need to repair it and put it back together. That you everyone for all the advice.
    Nick Landon
    ottoman, jimmy six and Six Ball like this.
  29. dreracecar
    dreracecar
    from so-cal
