Features It All Came Together
Discussion in 'Traditional Hot Rods' started by Ryan, Feb 22, 2023.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
    Lepus, slim38, chevy57dude and 45 others like this.
  2. Sancho
    Sancho
    There isn't enough good to be said for friends/brothers.
    The photos?
    You know that feeling that washes over you when you look at something and just know it's "right"?
    Yeah, you captured that.
    chryslerfan55, Deuces, Baumi and 6 others like this.
  3. silent rick
    silent rick
  4. simplestone
    simplestone
    Great story and great photos! This is what it is all about.
    Deuces and winduptoy like this.
  5. krylon32
    krylon32
    from Nebraska
    Dam, that motor looks good!
    Deuces, dana barlow and winduptoy like this.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    A Big Cigar for You;)
    chryslerfan55 and Deuces like this.
  7. Ryan
    Ryan
    ADMINISTRATOR
    I just got to get it running good again. I think that fancy intake is causing me issues... Plugs look good, timing is fine, and carbs are jetted the same as before... but, if you hammer the throttle, it's spits and sputters endlessly. If you roll on the throttle slowly and deliberately, it hauls ***... I think it might even be faster than it was...
    Once I finish up another project I'm working on, I'll dive in and see if I can figure it out.
  8. winduptoy
    winduptoy
    Don't know how to get a cat whistle out of the key board...
    It's a looker!!
    How does it run now?
    Edit you were faster on the keyboard than me
  9. Rolleiflex
    Rolleiflex
    Hey @Ryan what is the focal length of the lens? I wouldn't have guessed a lens used for air reconnoissance would work for close ups.
    I love this shot, so crisp.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Trade your 'hammer' for a 'squeeze the trigger'
  11. engine138
    engine138
    from Commack NY
    Those pictures are amazing good luck with your new toy Boss
  12. Ryan
    Ryan
    ADMINISTRATOR
    It was made by the National Optical Company and essentially, it was a medium format camera with a drum mount. Typically, and from what I understand, on that drum were a 180mm, 300mm, and a 600mm. These were used on light bombers and fighters for "reconnoissance of convenience."
    If something was found on these negatives, they would go back in with a dedicated aircraft carrying the real deal - a Dallmeyer with 9" roll film and a 36" lens.
    Riku's lens is a 180mm NOC. My tripod was setup about 25' from the coupe when I took most of these shots. As you can imagine, these are some very long exposures. The shot with my arm ghosted in had an exposure of over a minute on some pretty fast film.
    I get the focal lengths... What boggles my mind is how slow these lenses are and it's not like they were shooting from a stable platform. Suddenly, all of those really grainy and blurry wwii gun films start to make sense!
  13. 57 Fargo
    57 Fargo
    Those pictures are ****ing art. So is the flatly for that matter. So rad.
  14. Dan Hay
    Dan Hay
    @Ryan is there any coolant running through that intake? Maybe it's not warm enough. Also, winter blend fuels have been giving me issues on a high compression OT engine.
    I don't know about Strombergs but maybe it needs bigger squirters
    If the new intake is less restrictive than the old, it might need more fuel to compensate... just some random thoughts.
    chryslerfan55 and Tim like this.
  15. Ryan
    Ryan
    ADMINISTRATOR
    For those curious, this is a typical 36" general purpose reconnaissance lens:
    Okie Pete, KKrod, 2Blue2 and 13 others like this.
  16. Max Gearhead
    Max Gearhead
    from Wisconsin
  17. Ryan
    Ryan
    ADMINISTRATOR
    No... It's blocked off and it was 50-degrees out for my test drive. Keith said it was doing it all the way to my shop from his which is about 35 miles or so... Plenty of time for things to warm up. Regardless, I don't really dig the look of water lines going to the intake...
    I'm right in the middle of figuring another car out, but as soon as I'm done I'll get on it. It might be that these Canadian heads added compression and she just needs bigger jets in the carbs.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Might need more accelerator pump shot with the larger intake manifold volume... are the pump rods on the summer or winter ball on the throttle arm? when I put a crossram (huge manifold volume) on my drag boat I had to put 50cc pumps on the holleys. It acted just as yours does prior to that... 1 minute fix if that is all it is....
    *****in photos man.... that is pure art, How much are ya gonna miss Keith when you move to Hawaii????
    chryslerfan55, rod1, Sancho and 2 others like this.
  19. Ryan
    Ryan
    ADMINISTRATOR
    They are on summer right now... I should give winter a shot - that gives more fuel initially, right?
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    I believe that is true. If nothing else it costs nothing and only takes 1 minute to try it
    dana barlow and JalopyJimbo like this.
  21. Ryan
    Ryan
    ADMINISTRATOR
    I'll give it a go after work for ****s and giggles. To be honest, I have never messed with that setting in all my years of farting around with these carbs.
  22. seadog
    seadog
    Thanks for the explanation on the lens. You are indeed a lucky man!
  23. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    Make those into posters and I'd be owning a couple!
    Outback and Deuces like this.
  24. jnaki
    jnaki
    Hello,
    You have some pretty outstanding friends and ***ociates. Kudos !!! Those Tri-X photos bring back a lot of memories in the dark room, on location with my black shadow film changing bag, and in the dark room rolling them onto the stainless steel reels that fit in a variety of stainless steel processing cans. That was the fun part of being a photographer and someone who loves to piddle around in a dark room.
    People always thought I was always crazy with both hands sticking inside of a black bag hanging on both arms. My hands were usually finding the opening ****on and taking out the used film. Then loading a new cannister of 35mm film from Plus-X for interior shots and sunny days or the Tri-X for darkened garage spaces without a flash. The grains are always there and could be taken out or adjusted in the dark room processing on prints.
    You are fortunate to have those friends in good places.
    Jnaki
    I still have my old Asahi Pentax 35mm film camera plus a gaggle of lenses. But, they are nice and clean inside of a drawer and the last time out was to show my granddaughter the old trusty camera. I gave her a brand new Canon AE-2 film camera, lenses and accessories, as well as a new backpack for travel and storage. I bought them prior to the digital age and they sat unused until I gave them away. She is doing some film photography, film editing and could possibly be accepted to several colleges for the fall semester 2023.
    Also, nice black and white photos.
    My favorite... crystal clear and highly detailed.
    Outback, 2Blue2, alanp561 and 2 others like this.
  25. Tim
    Tim
    from KCMO
    Wow those are amazing. That would be enough for a guy to think about a new printed journal…
    Outback, Deuces and J.Ukrop like this.
  26. flatheadpete
    flatheadpete
    from Burton, MI
    Man...you know how I feel about Flatheads. And this one? Sheesh. That's pretty.
    dana barlow likes this.
  27. NoSurf
    NoSurf
    Sweet.
    Let's race.
    Tim likes this.
  28. Ryan
    Ryan
    ADMINISTRATOR
    Couldn't help myself and took it to lunch. I warmed it up with the accelerator pump rods still set on summer. While doing so, I noticed condensation on the intake and it was cold to the touch. So, I shut her down and set the pump rods to winter. It definitely helped with the spitting and sputtering, but it didn't go away completely. I'd guess a 50% improvement. I also noticed there was no more condensation on the intake and it warmish to the touch.
    Tardel thinks this intake is a bad match to my cam... And I know he's probably right, but I think it's fun to test and try to make **** like this work.
    2Blue2, Jalopy Joker, rod1 and 5 others like this.
  29. Danekejt
    Danekejt
    from Pa
    all i can muster is, WOW!!!
  30. lilCowboy
    lilCowboy
    beautiful pictures and subject matter
