Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. swade41
    swade41
    from Buffalo,NY
    Chiseled my way through the ice to the garage and took that fch off, fitting good now, tomorrow I'll start working on the support brackets
  2. bjinx
    bjinx
    Pulled the motor last evening
    Was taking a break took a pic
    mad mikey, alanp561, LAROKE and 4 others like this.
  3. TA DAD
    TA DAD
    from NC
    Sorry no photos, I got the Studebaker to the track for a second attempt as the first was halted by ignition troubles. Overall it was a great day, my rear suspension works great . I made three p***es at this 1/8 mile track and ran a 8.11 , 8.06 , and a 8.03 . It has been thirty five years since I last did this so 7's are within reach with more seat time.
    Chucky, 65type1, Stock Racer and 4 others like this.
  4. j hansen
    j hansen
  5. TA DAD
    TA DAD
    from NC
    I was by myself, my BIL showed up to help me in the water. It might show up on Youtube. Trust me it gets a lot of attention. Kinda slow though, I was really hoping for a 7 off the trailer. But that is how we drive it on the street so not to shabby for a low budget build. Now for some slicks and a 5.13 !
    j hansen likes this.
  6. 65type1
    65type1
    Rear turning indicators finalized
    104CC57F-D4DD-4917-AFD2-72AE33B80F8E.jpeg 5342E223-53CF-4686-BC71-38F641333F92.jpeg
    TA DAD, Chicster, Tim and 15 others like this.
  7. choptop40
    choptop40
    got the garage emptied from a lot of renovation repair debris...can see the Desoto now...lol...feels amazin to be back in the game after 3 years 0BE0EDCC-1307-4E7B-BDA7-4338E7A83EE7.jpeg 7C8FF3F2-6F7B-40E5-8555-472A152473C3.jpeg
    TA DAD, skooch, dehartcarl and 6 others like this.
  8. lake_harley
    lake_harley
    Aren't you concerned about knocking out a turn signal from a badly thrown piece of firewood while you're loading your truck? :eek::D
    But seriously, nice touch!
    Lynn
    TA DAD, mad mikey and alanp561 like this.
  9. 65type1
    65type1
    It’s all in the planning… firewood gets thrown in from the side ;)
  10. jimmy six
    jimmy six
    Took out the AC panel (only takes 10 minutes) so I could lay under the dash reach up and remove the clock. (20 minutes if you remember the right tools)
    Been working for 10 years, bugged me when it quit. I was going to upgrade to Quartz but told by 2 clock guys the new ones now are junk. The shop doing the repair told me to either add an on/off switch or disconnect the battery if you only use the car on weekends. I’m going with a switch. ABE27818-AE5E-4FFE-BCB0-FD08E1E00D66.jpeg
    TA DAD, Hamtown Al, Lil 32 and 4 others like this.
  11. Rocky
    Rocky
    Classified Editor
    First warm day. Took the 34 out, filled it up with gas and hammered unmercifully through the gears a few times.
    TA DAD, Hamtown Al, swade41 and 6 others like this.
  12. nochop
    nochop
    from norcal
    Brake line shenanigans 29CD398A-609D-4E60-ACB0-7A92F7E4A38C.jpeg 1F0328AD-06F0-4E8A-81F8-5709DEB76522.jpeg C783986D-6F26-469F-AFE8-3025B7578496.jpeg FBB7F73A-ECD4-41A9-993E-C1FA603271F5.jpeg
    Measured up for a new exhaust from the header flanges right to the rear. Going in to get done Thursday.
    TA DAD, mad mikey, 40two and 4 others like this.
  14. shorrock
    shorrock
    20230228_164032.jpg Yesterday I put the crank back into the block and put one piston and the cam in to check the cam timing. I have ground the cam a little to get a bit more lift and valve acceleration. Turned out that the original timing is right where I want it. Inlet is 0,366" lift with correct clearance, exhaust is 0,358" lift. Inlet has 0,02" more lift on overlap TDC so this seems about right. Today I installed the washers on the guides to get a bit more spring pressure and put all the valves back into the block. Next stop is install of the pistons. View attachment 5663689 20230228_164106.jpg 20230301_210443.jpg 20230131_205753.jpg
    TA DAD, LAROKE, 26 T Ford RPU and 4 others like this.
  15. alanp561
    alanp561
    Almostdone and mad mikey like this.
  16. alanp561
    alanp561
    All I got done was shipping the '27 T roadster to some guy up in Yankeeland. Soon as I get done with these cataract surgeries, I can concentrate on the A RPU. 20230228_141243.jpg
  17. Illustrious Hector
    Illustrious Hector
    During the recent -27 C plunge, I built a column mount bracket and installed my old vacuum gauge 20230228_104905.jpg
  18. nochop
    nochop
    from norcal
    Thanks. It allows me to use the ratchet tee handle e brake my dad installed in the 50’s
    alanp561 and mad mikey like this.
  19. jimmy six
    jimmy six
    10 days and not a drop of oil evident on the tube line or oil pump. I may have finally got that one.
    TA DAD likes this.
  20. 26hotrod
    26hotrod
    from landis n c
    <<< DROVE IT!!!! It was 68degrees, pushed out the windshield and listened to the mufflers/engine. It was a great day............
    Hamtown Al, Almostdone and alanp561 like this.
  21. Shitbox
    Shitbox
    from Chico
    Moved my ****box 45 miles north. Got half of my shop unpacked and set the *** end loosely on the frame so I can get the other half unpacked. It’s something I guess.
    I
    f anyone has the windshield gl*** for a 31 Chevy they could trace out for me please shoot me a message. Mine didn’t survive the trip.
  22. RICH B
    RICH B
    Managed to get the windshield garnish and mirror on without wrecking them. Found I have to redo the A pillar trim I made yesterday, figures. Seems like I spent a lot of time yesterday and today without getting very far.
    Hamtown Al, LAROKE, TA DAD and 3 others like this.
  23. lake_harley
    lake_harley
    Initial ***embly is almost complete. Just a few things to finish up on the minimal body work and other very minor items. Then it'll be time to see if it'll move under its own power. It's been in the works for about 16 months now, ground up, and I'm looking forward to seeing it move!
    Lynn
    IMG_20230303_163014818.jpg IMG_20230303_162902353.jpg IMG_20230303_162654545.jpg
    alchemy, LAROKE, alanp561 and 9 others like this.
  24. Sky Six
    Sky Six
    from Arizona
  25. TA DAD
    TA DAD
    from NC
    I finally got all the welding done on my hood ! I modified a pair of welding clamps to make the job easier. IMG_0906.JPG IMG_0907.JPG
  26. j hansen
    j hansen
    ^^^^^^Must be the longest extension I've seen in my life:D:eek:^^^^
    osage orange and X-cpe like this.
  27. 57 HEAP
    57 HEAP
    I have always liked the look of a '57 Buick grille in a Chevy, but didn't like the idea of chopping up the splash pan on my finished car.
    So with the help of 57Trucker, a scan and dfx. file was made of the original grille. Then the original grille shape and mounting points were merged with the Buick vertical slots and cut from 300 series stainless steel.
    The view above shows the grille with the protective covering on the polished side. The view below is without the covering.
    Slight modification to the hoodlatch/grille bar support.
    Hamtown Al, 57Trucker, koppy and 10 others like this.
  28. TA DAD
    TA DAD
    from NC
    A first for me also, I clamped a piece of copper on the underside to keep from burning through. I have learned a new skil set witht his old truck, WELDING RUST !
    alanp561 and j hansen like this.
  29. dana barlow
    dana barlow
    from Miami Fla.
    I need someone too kick me in the ***,too finish my "Y" engine rebuild. I don't know why I can't seem too !
    alanp561 likes this.
  30. j hansen
    j hansen
