Projects Just A Big Model (T)
Discussion in 'Traditional Hot Rods' started by BigJoeArt, Oct 4, 2022.
  1. attitudor
    attitudor
    from Finland
    It took me two hours to go through the whole thread. What’s your name on Instagram? Would be nice to follow the build there as well. This project reminds me alot the @IronTrap Garage’s ”Free T” build on YouTube.
    BigJoeArt likes this.
  2. Tim
    Tim
    from KCMO
    Wagtag_rodshopandfab
    BigJoeArt and attitudor like this.
  3. BigJoeArt
    BigJoeArt
    Thanks for the kind words! Tim is correct on my Instagram in his above post, i havent posted near as detailed on there, but once I start driving it, there will be much more content on there.
    last night was rather boring, got the body installed again, started to finish trim to weld the body on and then smoked a harbor freight grinder that I use for my cutoff wheel.
    so I went down and borrowed dads grinder and by that time I needed to go upstairs.
    side note, that orange grinder is a chicago electric grinder dad got off harbor freight probably 15 years ago? still works the charm. I had to tighten the lugs on the cord a few months ago and clean it.
    brEad, drdave, Tim and 2 others like this.
  4. BigJoeArt
    BigJoeArt
    what a day.
    I work as a construction inspector for the state of Missouri, and right now one of our active projects is a bridge near my house.
    today it was about 16° on the jobsite and the contractor placed 9 girders. i had to be there to witness them being placed in the correct location.
    this meant I had to be up on the cap when they placed them.
    needless to say being exposed to the wind over a freezing river, is really cold.
    once I got home and defrosted, had dinner, and helped put the baby girl to bed, it was already 8pm.
    tacked the body to the rear bulkhead flange, then added some braces from that to the tubing structure. also extended the subrail pieces.
    mark it out and cut.
    bend and weld. this is part of the structure to hold the turtle deck on, and also make the filler panel from the framerail to the 'deck.
    I got everything welded in on the p***enger side except the big curved piece.
    sleep and begin again tomorrow!
    drdave, Sancho and pprather like this.
  5. attitudor
    attitudor
    from Finland
    Looking good. Great progress. I’m sure you are familiar with this car but here’s one photo just for the motivation. It really has the same good vibes and proportions that you have in your car.
  6. BigJoeArt
    BigJoeArt
    I would be wrong if I did not give credit to Russ for building a beautiful car that definitely swayed me to the thought of purple.
    Mine will not be as nice as Russ' T but with any luck I hope to drive it just as much as he does his.
  7. BigJoeArt
    BigJoeArt
    What a day!
    Finally feel like I got somewhere today, even if I feel like I got hit by a truck.
    started where I left off last night, finishing the bracing for the rear corners, and adding some round rod pieces to weld to.
    I continued to make filler pieces to weld into place, until there were no more holes.
    outside I formed a piece of metal to the braces I installed last night.
    and while I did that, Mike and Dad worked on sandblasting parts of the turtledeck.
    once I had the drivers side mostly together, I needed to turn the car around. and if its gonna be outside, I might as well take pictures!
    you can see the unfinished p***enger side in the above photo.
    so once we got it spun around, I tacked together the p***enger side.
    and thats where it sits tonight.
    starting to see the vision I had from the begining come to life.
    now I need to deal with the ill fitting turtledeck. o_Oo_O
  8. BigJoeArt
    BigJoeArt
    The past few days I have been sick, but I'm still trudging through ***embling this silly motor.
    I did some more mockup, and got the heater hoses and switch valve installed.
    I also got my clutch z bar braced, it didnt like how much I bent it.
    (P.S. burning grease smells terrible.)
    @Austin kays made fun of my rubber hose breather hose on my neat and shiny motor, so I was forced to upgrade.
    bent this nice aluminum hardline. overkill? have you met me?
    then after finding out my new harmonic balancer was the wrong one, I had to s****e all the old paint off the old one.
    yesterday it was nice outside, so frequent breaks were made.
    Here's another dumb moment. I over torqued my Stewart Warner sending unit, cause I used a deep well on a 1/2 drive wrench.
    About the time it seemed it was getting tight, it snapped off. turns out it had been tight.
    so then I had to UN-install it. tried an extractor, and a couple other methods, with no luck.
    then I had an idea, I took a square file and filed a square into the hole, then drove a 1/4 drive extension into it, with two adapters to get back up to the wrench that got me into this mess.
    the best part is, it worked!
    Ispent the rest of the day ****oning things up and installing the front dress.
    I fought getting the crank pulley spaced right, and finally cut the bottom out of an old double pulley I had, in order to space it out the requisite 1/8" now it lines up with the world, and after 3 trips to the parts store I think I will have the right belt. we'll find out when it comes in today. the low mount alternator doesnt give much adjustment, so it has to be pretty spot on.
    I also painted my bellhousing and spacer, so it would disappear behind the motor.
    hopefully today I get it installed to the trans and in the ch***is.
  9. Tim
    Tim
    from KCMO
    If you really want to go over board you can put a flare on the ends of the tube and thread one end into/onto the breather via fitting and then a br*** barbed/****** fitting on the other end so there’s barely any rubber and a nice transition to the carb side. Intake side? If it’s going to the Intske you could probably just hard line it 100%
    sorry your sick, our whole house has had whatever this is for a week. Everyone’s taking turns
  10. BigJoeArt
    BigJoeArt
    As if I'm not there already. I flared the ends of the aluminum line, which should keep the hose on nicely.
    I do not wish to go any further down that rabbit hole, I wish to drive it!
  11. Tim
    Tim
    from KCMO
    Chicken
    Outback and drdave like this.
  12. BigJoeArt
    BigJoeArt
    Another not-so-productive night.
    started by getting the floormat cut and placed, cause there's no way to install it once the motor/trans is installed.
    More good supervision from the shop manager.
    had a couple people ask about the heater valve I installed, I found it on amazon of all places.
    installed some cl***y valve covers, stuck in the couple of freeze plugs I couldn't get to on the stand, and got it ready to install, then found out that I had the wrong clutch.
    it will be here Friday.
    so I installed and torqued the flywheel, installed and checked the starter, and got everything else ready to go. I also got some bolts to install the trans.
    I need to move stuff around today and work more on the body.
    brEad, guthriesmith, Outback and 3 others like this.
  13. Tim
    Tim
    from KCMO
    Looking good. What did you use for floor mat? Did you glue it down?
  14. BigJoeArt
    BigJoeArt
    I did not glue it down, its pretty thick, should lay down nicely once it gets warm a couple times.
    its a floor protector rubber mat for a shortbed pickup that a buddy gave me. "rough country" brand. its about 1/2" thick.
  15. BigJoeArt
    BigJoeArt
  16. Tim
    Tim
    from KCMO
    Gettin closer
  17. BigJoeArt
    BigJoeArt
    Shadow Creek, drdave, Sancho and 3 others like this.
  18. Tim
    Tim
    from KCMO
    How fine, they cried, now with you inside
    Strapped in there safe and sound
    I thought, my-o-my, how the sparks will fly
    If that thing ever hit the ground
    Slim was so pleased when I had eased
    Into his trap of death
    He had slammed the door but I said no more
    And I thought I'd breathed my last breath
    We was out in the sticks down Highway Six
    And the crowd was just about right
    The speed was too, so out I flew
    Like a stick of rollin' dynamite
    Looking good dude! Light that ****er off! You’re gonna sleep for a month when this is done lol.
    Watch your alternator gap some of the not so good engine mount rubbers squish pretty bad after a few miles. Can’t wait to see the master of sparks moving down the road!
    drdave, Sancho and Outback like this.
  19. BigJoeArt
    BigJoeArt
    oh man guys. Its good!
    first and foremost.
    IT FIRED UP!
    and it sounds very ****y.
    now lets get into some pictures.
    before @Austin kays showed up, I got the rad installed, and bolted my clutch z bar on. I also ground some metal so the steering box adjuster cleared the bellhousing.
    once Austin got here, we stuck on the headers, installed the plugs and wires, and threw together a fuel system and a makeshift wiring setup.
    then we ran into timing issues, and thought the lifters weren't working right,
    and once we were here it was much easier to find the problems.
    but we did! once I figure out videos, I'll post one!
    in the meantime, the shop manager had the best spot in the house.
    once we lit it off and woke the neighborhood, we decided we had to see it with the body on.
    Im beyond stoked, and I have a new breath of fresh air in me to get it done.
    LONE STAR ROUNDUP HERE WE COME.
  20. Austin kays
    Austin kays
  21. Tim
    Tim
    from KCMO
    Hell yeah! I checked my phone about 45 times waiting for that video!
    what ended up being the issue that you had the covers/intake off?
    BigJoeArt and Primered Forever like this.
  22. Austin kays
    Austin kays
    Set my preload on the wrong side of the stroke, rolled it over and re set it and she lit right off,
  23. Tim
    Tim
    from KCMO
    So are you driving around the block yet or what????
  24. BigJoeArt
    BigJoeArt
    Heights of victory, depths of defeat.
    or how to build a car 347.5 times.
    I installed the clutch pedal and linkage, and it wont let the clutch disk disengage.
    I have a couple theories about what happened, but ill reserve judgment till we pull it apart and see. its a 4 clyinder s10 trans, so the input shaft needs changed a bit to install on a sbc.
    so it will have to all come back apart one more time.
    in preparation I drained all the water.
    and then started to figure out the patch for under the door, I'm making it oversize so it covers more ugly metal.
    and if you've followed along this far, you know I like taking photos of my car.
    brEad, Shadow Creek, Paul and 4 others like this.
  25. Tim
    Tim
    from KCMO
    That ****s.
    Can you pull the trans threw the interior with the motor still in the car?
    I’ve considered mid mounts in the A for just this reason
    drdave likes this.
  26. BigJoeArt
    BigJoeArt
    haha I wish, its way too tight for that. I gotta dis***emble the whole thing.
    on the bright side it gets quicker everytime.
    drdave, Tim and Sancho like this.
  27. Tim
    Tim
    from KCMO
    Bummer, hopefully the fix is obvious and quick! I want to see this cruising!
  28. BigJoeArt
    BigJoeArt
    Dad was busy last night, so I couldn't get the motor pulled out.
    Instead I worked on the patch panels that I started last night.
    Paper:
    Metal:
    The patching is done on this side, now I just gotta finish welding it.
    hopefully tonight I get the motor pulled out.
  29. Tim
    Tim
    from KCMO
    Progress is progress! Now the tamales won’t roll
    Out the gap under the door!
    Headed to the garage now :)
    BigJoeArt and drdave like this.
  30. I had to extend the splines on my T-5 to get enough room for it to release when I built my Chevy. Looks and sounds great!
    Austin kays, BigJoeArt and Tim like this.
