Hot Rods BENNETTS ‘Pacific-Indian Special’ ‘29 Roadster on ‘32 rails
Discussion in 'The Hokey Ass Message Board' started by jordabennett, Jun 5, 2022.
  1. Made a wood buck (expected it to burn) next time I’ll make a steel one but roughly got the section made for the rear kick up area that I replaced. It will be hot riveted in and pickup part of the crossmember aswell. Holding to make it simple and look like it should be there.
    BAF140AE-3151-4380-BEB1-D8ABA1311039.jpeg 2E0859A1-F1DB-4FE2-B2E3-DE10A9A64DFA.jpeg
    66F6C35F-1E2B-4955-A3F1-8739C55468C6.jpeg 2EAE8D4B-3940-4119-B319-A58E9F261DC9.jpeg 13F1797B-DD50-4D59-859D-3D9AD8396307.jpeg
    Deutscher, 39custom, brEad and 12 others like this.
  2. Wasn’t happy with the first inner plate for the frame rail so I fabricated a new die using more steel and less wood, gave it a crack and it looks a lot better already. Bit more to go then I can rivet these in. Sure was close to just welding them in!
    BD7740C6-E16F-471F-9330-0E01A1623063.jpeg 9FD79447-1062-4EAC-91E1-E6ECBC2848AA.jpeg 105CBB75-091E-472B-B4A5-512AEBE4461E.jpeg A54B310F-B1AA-4372-9EAB-6C4E0AD882DA.jpeg 78D5B7D7-427C-48F2-BCE6-64FA04955492.jpeg AA22EC63-A8B4-4A40-BDFA-0F1016CA32E5.jpeg EACD5112-18FD-443E-8AC8-18E35CFE49DF.jpeg
  3. WhyW8
    WhyW8
    from Sun City
    Looks great!, much better fit up
    Stogy likes this.
  4. Well got them cleaned primed and bolted it, tried 4 top rivets on one side with my new buck and seemed to work really well. More pictures tomorrow.
    B6FC59C3-F698-4D27-A18A-B08A22172F45.jpeg 5DDBBBA6-DBAB-4324-86EE-FBC4B7105E69.jpeg 6F82855C-5FB7-4C0C-9EFF-1A33068389B0.jpeg 48F7F206-9544-4943-864A-4342641073A8.jpeg CCA4E5E9-87FE-4EB1-932D-5F0C7DFF45DE.jpeg 321BA683-8D0E-43D3-BF65-79A4FBD1B9E1.jpeg 0EC771EA-9AB6-4D03-93C0-08AC1A1817B8.jpeg
  5. Got the boxing plates riveted into place, having a heavy buck and three blokes to help it went very well and they pulled tight and even.
    Ch***is is ready to come out of the jig and start to get the rear end, motor and trans mocked up.
    7E7500AE-DCD5-4236-895B-7CB99935B4D6.jpeg 0C194A07-5547-4A0E-8B30-030059EC6BC9.jpeg
  6. Tim
    Tim
    from KCMO
    Looks fantastic can’t wait to get caught up on the videos!
    Stogy, lurker mick and jordabennett like this.
  7. Super sano and thorough fab work!
    Stogy and jordabennett like this.
  8. Hitchhiker
    Hitchhiker
    Great work Jordan! Giving me lots of great ideas. You videos make it look simple! Thanks for all the great content.
  9. Thanks mate! Definitely was a process but happy how it’s turned out
    Stogy and Hitchhiker like this.
  10. 31Apickup
    31Apickup
    Nice job on those inner boxing plates!
    Stogy likes this.
  11. Rolled it out side, had a look, still needs the rear frame horns cut so the body sits better, sneak peak with 32 grill. Huddy seems to like it! 293EB9AC-9985-4ED5-A58C-9F3343FD06C1.jpeg E91E4405-CA90-4604-B59E-F5AC7EE30F58.jpeg 2C3107A1-054D-4C55-8B4A-8F8B08CE5321.jpeg B4B01DDC-BD9E-438F-BF0B-829EE84E59F9.jpeg
  12. Frames on stands, motor and trans are in mock up in order to get the 36 rear end fitted. I will be modifying the leaf spring to fit and shortening the torque tube. BDA6D413-0813-49CB-A839-DC25A18ECB31.jpeg CD82C9D7-6410-494E-9958-388AF8886CE5.jpeg 5D7F579E-7245-48FF-BBB1-ED0681841054.jpeg BFB14B17-D643-4F14-8633-6FB4DB69DE5F.jpeg E963A53B-C063-4A9C-94D3-016147BF84D0.jpeg
  13. Was thinking about running a set of twin pulley pumps, there would have to be some modifications but like the look anyone familiar with this?
    Also pulled a head off and realized it’s factory relieved? 6B87C280-C147-4F55-94C8-D01409407778.jpeg 4EC92C26-515F-41AF-9E55-2CB318854AEB.jpeg 87874DFC-CE78-4A6C-849D-3E1F68ECD1B2.jpeg 0399290F-FE04-43DF-80B2-81B5AFD67E8E.jpeg 4C84FE2B-B5EB-435E-8316-2788C63231A7.jpeg CB26343B-1A16-47AF-A93E-A9D7B25AD1F7.jpeg 67AC2340-3806-4D6D-BAC3-95FA39261698.jpeg DD7642AE-E89E-4C40-B482-D4EDE11A8222.jpeg
  14. Okie Pete
    Okie Pete
    Amazing build . Thank You for sharing Your project
    Stogy likes this.
  15. Tim
    Tim
    from KCMO
    Looking good!
    Stogy likes this.
  16. ‘36 leaf spring relieved for the crossmember. Torque tube shortened and fitted, next is radious rods and drive shaft. Baking plates drums etc.
    19BEE8EC-E988-4A33-91CB-B8F4EB32AD1C.jpeg 4F3C5AF0-6453-42C1-BF69-94D9E0740BC3.jpeg BD126068-B4C2-400D-A201-4153868E2BBD.jpeg 382E5D9E-0531-45B6-AEF3-6E08145B80CE.jpeg
  17. Dedsoto
    Dedsoto
    from Australia
    Watched the vid yesterday, didn't you get a spring spreader with all that stuff from Brendan?
    Looking good!
    Stogy likes this.
  18. Probably the one thing he kept hahah
    Stogy and mgermca like this.
  19. Managed to get the drive shaft shortened and relocated the radius rod mount and shortened the rods to suit. Will it all work? Who knows haha 9E3704E0-A646-4E1E-ACFB-680CE945DC8D.jpeg A9E2491D-D412-429C-9FEB-D97125162296.jpeg 75399F86-DF71-4473-AB07-FC5878A77F2F.jpeg 7C70F7CF-49F8-4C05-8F74-0A76847EBF31.jpeg 6DBF85E4-479D-4645-A76D-64565AEEE4A2.jpeg CB454B0C-38F8-4A3D-934C-8221732857F5.jpeg AB0A7823-522E-4BE4-A3C2-48B1A8C5AA5B.jpeg
  20. Nice job as usual mate.
    Stogy likes this.
  21. Rear end is under and body on for mock up.
    Below I don’t have a 32 stock front wish bone or a nice 33/34. What I have to use is a 36 front bone and a model a rear ball. I’ve started cutting them and plan to make a slug the will go inside both and extend 40mm to get me to the desired stock 32 length. Will this work? No idea- I will try and see! EDC66047-59EF-4A92-A001-821034889A4B.jpeg 007F8AC9-10EA-4AC7-9216-D082A6918A65.jpeg C8AB4386-9145-49E9-B98C-50DDD5826FD8.jpeg F90244AA-209E-49AC-ABB1-35E4E9106747.jpeg 9117432E-EE50-4E32-BCB1-5AFFE06268AD.jpeg EEF50473-76A8-4F2B-B17C-2653280C3FB0.jpeg DB03A8B2-3FD6-44E2-AECD-17AF0890BAC2.jpeg CCDE8580-8968-40E3-8679-79F2D27A9193.jpeg E8CE5446-F20B-4523-8865-E8FE723AFFC8.jpeg FF77AF72-C347-4EA6-B379-E4734DD4D56F.jpeg D89AEE80-0FA1-4F7A-B832-9D2014C653D4.jpeg
    Deutscher, Stogy, brEad and 4 others like this.
  22. alchemy
    alchemy
    The downward arch of the A yoke will give you more clearance to the oil pan than a 32 could.
    Stogy, jordabennett and The37Kid like this.
  23. The37Kid
    The37Kid
    Wonder if all the angles are the same of differ with an early Model A wishbone? I don't have a later on to compare this one to. DSCF7709.JPG Bob
    Stogy likes this.
  24. I think the model a has a curve or downward arche more than a 32? Hope this will help for clearance
    Stogy likes this.
  25. I managed to get the spacers made and welded in. The 36 wish bone with the rear model a mount sits exactly the length of a stock 32. Only issue is the ball fits loose under the k frame, is there another piece im missing or does it just sit with in the crossmember and bottom plate? I have two different size rubbers but I believe the bigger one is for later model?
    9E9E943F-83AB-4FE6-8863-9974712C68EA.jpeg 628C5D2E-1AA0-46B5-A602-3FB61FC2C679.jpeg 9C9B50BC-A21D-4641-BF66-CF2B91E3E016.jpeg 01E87C70-0249-47C2-B850-DB4DD51D5B75.jpeg 41F6AB9F-E253-4548-8BA4-E0C260452B52.jpeg 8FA6C230-D5E8-4D46-9D1D-3C03DF23319B.jpeg 00F5F671-A9EA-45DF-9B8B-B4ADD57400D1.jpeg A1778E9B-F81B-443F-AB1C-821AEFC34228.jpeg 2A02C78E-4FA5-4F00-904C-F8D2B76E5A6A.jpeg 83E4F6E1-367D-4867-B1D4-28F85DD81B8B.jpeg
  26. alchemy
    alchemy
    The 32 rubber doesn’t fit the A ball?
  27. The smaller rubber (32 one fits loose. When it’s mounted under with the lower cup plate below the bolts bottom out and there’s still slop. If that makes sense using rubber (left) below 69DCCF1C-F87B-4C63-B05C-0A57C8505FD3.jpeg 581544F1-E1C0-49FF-8735-4AC8235DE78C.jpeg
    ct1932ford and rat bastad like this.
  28. dirt car
    dirt car
    from nebraska
    The rubber ball mount with the grooves is the same as what was on my stepped 46 bones, what ball worked for you ?
  29. Nice job on the bones!
