Technical Marching forward 1-2-4-3, Banger time...
Discussion in 'Traditional Hot Rods' started by hotrodfil, Mar 1, 2023.
  1. Link to previous month: Feb 2023 Banger Meet Thread
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    ccain and 47chevycoupe like this.
  2. C0E7E67D-43C1-44BB-8CC1-B0FA19EA17E6.jpeg Been progressing my Burtz build over at my friend Craig’s workshop - RKE, that make the Rotoshim shocks.
    Took it home at the weekend and treated it to a dusting of paint.
    He’s been a bit busy himself.
    A friend of his who normally builds phenomenally quick drag bikes (he has a twin supercharged twin triumph engined bike in build at the moment) was let loose with his polishing mops…
    They’ve whittled some mains caps whilst they were at it and Craig is currently building tooling in readiness to line bore the block for shells. Guess I’ll queue up a pair of B blocks behind that one.
    Old Dawg, GuyW, 282doorUK and 17 others like this.
  3. Crazydaddyo
    Crazydaddyo
    I pulled the old lump. Now loading the cam in the Burtz. Won't be long.
    fur biscuit, Old Dawg, GuyW and 7 others like this.
  4. Are those Philidas nuts on the studs? I wished I'd gone that route instead of the supplied castle nuts but there were none in stock around here.
    winduptoy likes this.
  5. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Finally made a timing pointer and put a light on it, I am getting 8 to 10 degree advance out of this Mallory dizy... So total advance was 14 to 15... Just seems not enough to me.... Guess I need to send this thing out to get it recurved, I hate to do it cause I normally curve all my own distributors by charts and not a machine but This Mallory uses different springs than my MSD ones etc, and I cant find springs etc...
    So what are ya'll running for total timing on a warmed up motor?
  6. noboD
    noboD
    Hotrodfil, what material did they make the main caps from?
  7. denis4x4
    denis4x4
    from Colorado
    Sent Ryan info and photos for the beta testing of his HAMB Auction to include the Zipper.
  8. wheeltramp brian
    wheeltramp brian
    Man that polished crank looks great!
    hotrodfil likes this.
  9. Dave_D
    Dave_D
    from NY
    First time checking into the banger threads, I just picked up this T with a supposedly rebuilt engine and a bunch of other parts. In looking around quickly it seems that most talk is about A and B motors, does anyone do anything with T motors? I'm not sure what my plans are for this yet, build it up using the T frame, axles, motor, etc. Or I also have enough parts to build an A ch***is and just drop the body on that. Either way, it will be a while, I've already got a bunch of other projects that need finishing first. I probably shouldn't have bought it, but it was close to home and the price was right, so why not. I guess I could always flip it if I decide to not build it. Time will tell I suppose. IMG_20230221_171916221.jpg IMG_20230221_171919302_HDR.jpg IMG_20230221_171926744.jpg IMG_20230225_141446517.jpg IMG_20230225_141831583.jpg
    Old Dawg, G Baese, Jet96 and 7 others like this.
  10. Checking in, not much progress on my banger as of yet.
    Working on making some new parts though!
    stubbsrodandcustom likes this.
  11. By all accounts he used EN16T because he had some, but would have used EN3B if he'd had to buy it...
    Outback and winduptoy like this.
  12. Here!!
    just working on SOHC drive stuff.....
    J
  13. winduptoy
    winduptoy
    IMG_20230202_105806381.jpg Burtz block Cragar OHV back together and in the Vicky about 150 miles on it....
    Old Dawg, GuyW, bymanr and 15 others like this.
  14. Have you fitted an external filter? Any pictures of that side?
    This is the bolt I’ve had made to fit the side cam gear cover. 1/2” UNC, 5/8” hex with a 1/4” BSP female thread and an 8mm reamed hole down the centre to feed the oil gallery. F3E64343-4CD8-46DE-A205-B2FAFDE28DFE.jpeg
    Old Dawg, G Baese, Jet96 and 4 others like this.
  15. Savage Coupe
    Savage Coupe
    from Washington
    Checking in. I was considering a **** crank for my B motor but with all the posts of broken cranks it has me questioning that idea. Would I be better off having my B crank drilled?
    GuyW and Outback like this.
  16. Hitchhiker
    Hitchhiker
    Stupid question. Would putting a B cam in an A block with A lifters make things not work correctly?
    Outback likes this.
  17. Crazydaddyo
    Crazydaddyo
    Yes, externally, but I replaced the two rear main studs and the #2 & #4 main studs with Milidon studs and all of the nuts are ARP
  18. Crazydaddyo
    Crazydaddyo
    Probably.
    Savage Coupe and winduptoy like this.
  19. Crazydaddyo
    Crazydaddyo
    I have not finalized my filter system yet. My plan is to use the same bolt set up you have. I will be incorporating a **** oil filter bracket with the external pressure byp***. That is my next action item.
  20. Crazydaddyo
    Crazydaddyo
    I've done it. It is easier with adjustable lifters. You might also think about putting some spacers under the springs to increase the seat pressure.
    winduptoy and Hitchhiker like this.
  21. Hitchhiker
    Hitchhiker
    I do have adjustable lifters in it. This is an engine I bought "rebuilt" swapped the cam in, and never got to fire. Working my way backwards to try and figure out what is going on. I think I may pull it down and double check everything and re***emble. Then try and start it with a known good carb and distributor. I kinda think maybe I can't get it spinning fast enough to fire on 6 volt. But I'm not really sure or it would already be running.
    Old Dawg and winduptoy like this.
  22. Similar. I have a Mocal filter bracket that I’m figuring out where to hang. The pressure relief is built into the pump I’ll be testing for RKE. I’m fitting an early sump so I’ll be able to drop it out the bottom when the want to check it over. 45AA85D1-DF5A-4A6B-B599-188D00C4ECE2.jpeg
  23. noboD
    noboD
    Thanks. Dave D not that it maters but I like the look of a T better then an A. But I don't fit in a T.
    winduptoy and Outback like this.
  24. 4BangerDean
    4BangerDean
    Looks like you’ve got a nice collection of As. The truck is probably really nice with the 5 speed.
    Crazydaddyo and winduptoy like this.
  25. Good looking high rad body there Dave. Better than I started with.
    I've been piecing together another '24T roadster for a while. Trying to solve the problem of not fitting by dropping the centre X member I added to pick up the wishbone mount and give me some footroom.
    75CF78E8-B46A-4190-9527-C475F4E07898.jpeg 5F6A32D9-2A2D-4935-8235-8D792BA692F0.jpeg
  26. Outback
    Outback
    from NE Vic, Oz
    IMG_6151.jpg IMG_20230224_201132520.jpg Checking in here, nothing to report, though there are a growing number of bangers going together in town!
    GuyW, 4BangerDean, Old Dawg and 4 others like this.
  27. Crazydaddyo
    Crazydaddyo
    In case you haven't seen an adjustable cam gear and John Neilson's oil pump.
    GuyW, Old Dawg, burl and 5 others like this.
  28. 4BangerDean
    4BangerDean
    My engines have different oil fill tubes. One of them is 1 1/2” in diameter and needs a cap the other is about
    2 3/8” in diameter. Are they for different years?
    Should I buy a cap or a different fill tube and cap? C038B13A-037D-431C-B1BA-22FE4A28669F.jpeg F0BCB364-8357-4D9F-B5C2-5B686811F7EA.jpeg
    Old Dawg, winduptoy and Outback like this.
  29. 4BangerDean
    4BangerDean
    They look like very nice pieces. I ***ume the cam gear is used to degree the cam. Do you find the cams are right on? Do you advance the cam a bit?
  30. Crazydaddyo
    Crazydaddyo
    The smaller tube is Model A. The larger is Model B. I have found no advantages to either one.
