Technical Lincoln 16" by 5.5" wheels
Discussion in 'Traditional Hot Rods' started by 3w Hank, Mar 1, 2023.
  1. 3w Hank
    3w Hank
    I bought as I think a Lincoln 16 by 5.5 wheels here on HAMB ( se pic, black )
    It has 3 clips as my Ford front 16 by 4 for hubcaps.
    But as I heard the Lincoln should has the clips in the hub cap (?)
    I will use Ford hub caps so I need a wheel with clips ( my guess )
    But seller had only 1 wheel ( told to be a Lincoln ) so I found another one but it was my misstake but got a very nice wheel with clips but it's 16" but only 5" wide.
    First question.
    How was the Lincoln wheels ( 5.5" ) on clips, as I like to know history.
    -So on a traditional late style 40's 32 5W coupe, is 5" Ok or should I try to find another 'Lincoln' 5.5" vs the 'cool factor'.
    If anyone read this and has 2 nice 16 by 5.5 with clips please contact me.
  2. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Maybe the picture is throwing me off, but that black wheel looks like a 15" Pickup wheel
  3. alchemy
    alchemy
    Ford and Merc wheels had nubs, Lincoln had clips. I've never put Ford caps on a Lincoln wheel, but I think some guys do.
    I usta have a 16x5.5" Ford wheel once. First and last I've ever seen.
  4. Hitchhiker
    Hitchhiker
    I've had a bunch of 5 and 5.5 wheels. I seek them out an make pairs. I think I have 1 5 inch and 1 5.5 inch right now. To bad you're so far. I'd be interested in a trade. I don't think the width matters much. Anything 5 inches and up is pretty desirable.
  5. 3w Hank
    3w Hank
    Yepp, the black wheel is 15" !
  6. Bluestreak-PA
    Bluestreak-PA
    from Erie, PA
    Late 1938-1940 Lincoln wheels are 16" x 4" wide with 5 clips
    1941 Lincoln wheels are 16" x 5" wide with 5 clips
    1942-1948 Lincoln wheels are 15" x 5" wide with 5 clips
    1941 Lincoln 16x5 wheels with 5 hubcap clips:
    Compared to 1940 Ford 16x4 wheels with four nubs for hubcap:
    1946 Ford hubcaps mounted on both the Ford and Lincoln wheels shown above:
    40two, Big Al and rusty valley like this.
  7. rusty valley
    rusty valley
    Merc wheels had clips too, no?
  8. 3w Hank
    3w Hank
    Good info so Lincoln had no 5.5" wide.
    What Ford ( model/year ) wheels with knobs was 5" wide ?
  9. rusty valley
    rusty valley
    pickups thru 66
  10. 3w Hank
    3w Hank
    16” not 15”.
    See pic of my rears 16” by 5”, must been 40’s my guess
    In my rear’s it has a mark ; Kesey Hayes.
    I’ll just NEED 1 one more !
  11. 3w Hank
    3w Hank
    Bluestreak-PA.
    See my Ford 40 front wheels, its 16 by 4 but lugnut area is not the same design as you show.
    Your fronts lug nut area look like my Kesey Hayes 16 by 5.
    ( Maybe Ford send them out so design was not the same ?
