Hot Rods Need Chevy 6 wisdom
Discussion in 'The Hokey Ass Message Board' started by Racemaster33, Mar 2, 2023.
  1. Racemaster33
    Racemaster33
    from Middle TN
    I’ve got an old ELLIS in-line 6 Chevy intake manifold with no casting numbers, part numbers or numbers at all for that matter.
    I’m searching for the wisdom of the in-line 6 guys & gals to help me identify it. I’m guessing the distance between ports will be the only way to identify it. I don’t currently have any I6 engines to match to so.
    The guy I got it from said it was Chevy but I forgot what engine size (long ago). Measuring with a tape measure ports are 1 1/2” and appear to be 8 1/2” apart center to center
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Pictures and measurements would help
    AHotRod likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not so much the span, it’s the diameter of the runner to head having to match up.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    are you certain it is for a Chevy? could be for a GMC....
  6. Racemaster33
    Racemaster33
    from Middle TN
    The port size measures 1 1/2” and they are 8 1/2” apart
  7. Racemaster33
    Racemaster33
    from Middle TN
    I have a series 2 GMC one with a part number (so I know it’s GMC) and it’s WAY bigger than this one
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just sold the 235 we had here so I have nothing to measure spread. But at 1 1/2” put’s it to be later 235 because early 235 shared the smaller ports as a 216.
    gimpyshotrods and Racemaster33 like this.
  9. Racemaster33
    Racemaster33
    from Middle TN
    Thanks for the info, it’s a start at least. I’m hoping someone has an intake or head they can measure so I know for sure what I have.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I have a 216 manifold, I will go dig it out
    gimpyshotrods likes this.
  11. Racemaster33
    Racemaster33
    from Middle TN
    You ROCK!
  12. Racemaster33
    Racemaster33
    from Middle TN
    I think you may have nailed it sir. I found comments on another site that said the 216 and early 235’s had 1 1/4” ports and the later version 235 had 1 1/2” ports.
    I’ll know for sure when Moriarity measures his 216 intake
  13. Late 216, 235, and 261s port "spread" are the same I am running an Edelbrock 216 intake (I had the intake manifold ports machined) on my 261.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok the port spacing is 8.5 inches and the port size is 1.4 inches where the gasket ring goes in. I think they call this 1 3/8 ports. Yours must be a 235
    38512D5D-8EE3-408F-BD8C-C04C2691592E.jpeg DF4CE12B-CDEA-489D-9722-0BA549BFD20E.jpeg DBDC7B9C-3AD6-46D6-BC9E-2B207DFF3A95.jpeg 356888E5-C760-4805-A9B3-D80502D4F93E.jpeg 5249F334-8F68-4624-BE3F-37B0DF6F804A.jpeg 792919DE-7323-4365-A00B-DCC8FB0CB5D2.jpeg 42D2C2D5-578F-4D83-8131-BF0439EABBA3.jpeg
  15. Racemaster33
    Racemaster33
    from Middle TN
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup you’re right I just measured 1.250 75BD9C7A-2110-44CD-803D-5480D3FAFB20.jpeg
    Johnny Gee and Racemaster33 like this.
  17. IIRC some manifold suppliers had stepped bushings that adapted the later manifolds to the early 216" manifolds.
    Moriarity likes this.
  18. jimmy six
    jimmy six
    In all my years of running GM 6 cylinders starting in 1961 only my first one used the rings. As I ported and tapered intake and heads I found I couldn’t use them so I didn't. A large port intake on a smaller port heat that I tapered to the manifold size gave me the best street drivability torque by making the intake runner a venturi.
    Food for thought!
    rod1 and Johnny Gee like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ The ring for me are to ensure proper alignment. I’ve assembled a few with out ring with no issue. Just took my time.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I need to add though, they do offer a fair amount of support so as not to be able to slide down ward especially when running in stock form with exhaust manifold attached.
  21. RDR
    RDR
    Plus, these are clamped to the head and not through bolted...
