Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. Mike Paul
    Mike Paul
    Anybody know the CC’s on an unsurfaced 1960 390 head? Need to know for ordering pistons. Thanks
  2. kadillackid
    kadillackid
    From literature I have taken off the internet the head combustion chamber is stated to be 67-70 cc,.... the volume with piston valve reliefs is stated as being approx 76cc. I can not personally confirm this, hopefully someone can add more precise info
    Roothawg likes this.
  3. Mike Paul
    Mike Paul
    Thanks, those are the same numbers I found. I’m going to do an actual CC check on my heads this week and I’ll post my findings
  4. Mike Paul
    Mike Paul
    Let’s talk timing chains. Anyone know of a double roller or equivalent for a 1950 331 or am I stuck with the stock style repops? Thanks
    jet996 likes this.
  5. Roothawg
    Roothawg
    I don't think there is for any of them until you get to the 472/500's.
    kadillackid likes this.
  6. Dogberg
    Dogberg
    Not that it makes any difference when you allready seem to have found one.
    The tiny bit is cut from the new gear shaft from a 331 model, needed it for a 390. thumbnail_IMG_1593.jpg
    cretin likes this.
  7. Dogberg
    Dogberg
  8. Roothawg
    Roothawg
  9. kadillackid and Roothawg like this.
  10. Dogberg
    Dogberg
  11. Mike Paul
    Mike Paul
    Looking for 390 timing chain cover if anyone has one for sale. Want to get rid of the 331 rope seal cover I have. I tried posting in the wanted section of the cl***ifieds with little luck so I figured I post it where all the Cadillac guys are. Thanks
    Roothawg, warbird1 and WTF really like this.
  12. warbird1
    warbird1
    There are a couple on Evil-bay now... $70-80 range.
  13. Mike Paul
    Mike Paul
    Thanks, saw those. thought I would try here first
  14. Roothawg
    Roothawg
  15. Mike Paul
    Mike Paul
    2E0E8A35-26F3-4B5C-837E-0BE9CFA1A0A2.png Another issue that I’ve noticed is rocker arm wear where it contacts the top of the valve stem. I have a couple sets and most of them are worn like the photo I posted. What’s the solution? Find enough unworn ones? Can they be resurfaced?
    jet996 likes this.
  16. Roothawg
    Roothawg
    warbird1, gonzo and lumpy 63 like this.
  17. lumpy 63
    lumpy 63
    Chris , the only thing I have left is a dampner a valley cover and an oil pump pick up .......
  18. lumpy 63
    lumpy 63
    My machine shop had a fixture to resurface rocker arms, but if they are really hammered they are probably junk.
  19. sheparj2
    sheparj2
    . I had mine rebuilt by rocker arms unlimited. $350 plus shipping. Came back looking brand new.
    warbird1 likes this.
  20. sheparj2
    sheparj2
    Is there anything incorrect about how I have my PCV set up? It seems everyone else does this fancier so I was wondering if how I have it is ok.
  21. wheeltramp brian
    wheeltramp brian
    That PCV setup looks good to me as long as you have the breather tube clear to Fresh Air
  22. sheparj2
    sheparj2
    Thank you. When you say "breather tube", you are talking about the oil filler neck? I haven't found a cap small enough to fit so its very open right now. :)
  23. cretin
    cretin
    I've seen talk about using a modern harmonic balancer on these Cadillac's, but haven't seen any info about it. So, who has some info about actually doing it? Do you use a SBC balancer? I haven't tried to check any dimensions yet, but I'm going to ***emble my engine soon, and I thought it was worth looking into.
  24. My belief is they used to cut the crank snout off, drill and thread then weld on the Chev sized snout.
  25. Roothawg
    Roothawg
    I am wondering this myself…
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    If you have the pvc that close to a breather it will not do its job of evacuating the crank case of fumes. The pvc will take the route of least resistance which is to **** fresh air thru the filler neck. What did you do with the port in the valley pan that the road draft tube usually goes to? That is where your pvc should be connected to so that fresh air enters the breather on the oil fill and is drawn thru the crankcase and the fumes removed by the pvc at the port where the road draft tube was. If you are wanting to leave the pvc on the filler tube you will have to get an oil cap that seals tightly and then figure out how to get the fresh air to come into the valley pan at the opening that the road draft tube was in.
    rod1 and guthriesmith like this.
  27. warbird1
    warbird1
    That's how Cadillac did them in '62... how I've done it on both of my Cads; seems to work fine.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    where was the fresh air drawn into the system?
  29. warbird1
    warbird1
    Through the filter media in the oil cap.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Am I not seeing his photos correctly? it looks like the inline pcv valve is connected to the oil filler tube?
