Technical Radiator hoses 33 car w/52 motor
Discussion in 'The Hokey Ass Message Board' started by MGK, Mar 3, 2023.
  1. MGK
    MGK
    from Ohio
    Hello,
    I have a 33 5 window with a 52 RT motor. Running a stock 33 radiator. As far as I can tell, no one makes a hose kit for this setup. Trying to identify hoses that will work for top, bottom should be much easier to find. Any help is much appreciated.
    Chris
  2. AVater
    AVater
    ***uming you have truck water pumps: I used ‘50 Mercury hoses down below. They are the correct diameter and have a gentle curve in them. Length can be cut. Up top, I used Gates adapters to upsize the thermostat housing output nozzles to the size of hoses needed for the earlier radiator. Don’t mean to be vague, don’t remember exact diameters.
    MGK likes this.
  3. millersgarage
    millersgarage
    I used 45 degree bends and a straight stainless piece for the uppers. Lowers i used aluminum offset parts for a 32 ford lower, and 2 straights
    MGK likes this.
  4. millersgarage
    millersgarage
    Sorry, forgot the photo
    Desoto291Hemi likes this.
  5. ssffnomad
    ssffnomad
  6. MGK
    MGK
    from Ohio
    Thank you. Can you provide any more info on the 45s like part# or where purchased from. Setup looks nice and clean. Wish somebody made 1 piece upper hose. Thanks.
  7. MGK
    MGK
    from Ohio
  8. MGK
    MGK
    from Ohio
    Looking up the 50 Merc lowers now. Thank you.
    AVater likes this.
  9. millersgarage
    millersgarage
    MGK likes this.
  10. nochop
    nochop
    from norcal
    MGK likes this.
