Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. 43willys
    43willys
    I read though the entire thread, keep up the good work man it amazing how far this car has come
    Six Ball likes this.
  2. Jacksmith
    Jacksmith
    from Aridzona
    Yeah, you should change the ***le to "Not nearly as bad as it used to look!"
    Outback, SS327 and Six Ball like this.
  3. 1/2done
    1/2done
    from Ohio
    I've been working on the coupe off and on, getting close to being far enough along to pull the body and getting everything final welded and painted.
    Once that was done I started on the firewall, pedal box and seat location, floor panels and column mount. 20220828_200049.jpg
    The parts pile on my toolbox is shrinking quickly. I'm hoping to have it run, stop and steer before it gets cold.
  4. 1/2done
    1/2done
    from Ohio
    It's been a while.
    Fuel tank mount
    Pedal mount mocked
    Seat and column position finalized.
    I'm just about to pull the body and do all the welding on the bottom side.
    The entire bottom will get DP and Raptor Liner. I may do the inside floor the same way I intend to drive this car as long as there's not snow on the roads so sealing it up is a priority. It'll have a heater, Rain-X and be seam sealed so weather shouldn't matter. Plan is driving to Daytona for the Turkey Run.
    Chucky, pila38, ffr1222k and 6 others like this.
  5. Six Ball
    Six Ball
    from Nevada
    I am amazed at how much work you have done here. It is a shame so many early photos are gone. People won't know what has been accomplished. Looking Good!
    Jacksmith, 1/2done and TomT like this.
  6. 1/2done
    1/2done
    from Ohio
    I went through and fixed them since the whole Photo****up fiasco. They show for me, you can't see them?
    Six Ball and chryslerfan55 like this.
  7. Dick Stevens
    Dick Stevens
    No, when I click on them it shows as ERROR!
  8. pprather
    pprather
    The photo message is a HAMB error, "you don't have permission"
    @Moriarity , can you help OP grant permission to us to see photos in early part of this thread? Thanks.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    Pics all show for me
  10. pprather
    pprather
    chryslerfan55 and Dick Stevens like this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup @1/2done has the album set to private, meaning that nobody can see the pics. I can't change that. He needs to open the album then on the right side of the screen there will be "album permissions" he needs to click on "change permissions" and make the album public
  12. pprather
    pprather
    Thanks, Mark. That is the one info OP needs.
    Kroombit, Dick Stevens and Moriarity like this.
  13. 1/2done
    1/2done
    from Ohio
    How my dumb*** managed to do that is beyond me. Thanks for helping me straighen it out.
  14. pprather
    pprather
    After you went to the trouble to restore all those photos, I am glad to help get them viewable.
    1/2done and Moriarity like this.
  15. Six Ball
    Six Ball
    from Nevada
    Much better, Thanks! But now it got me started back through the whole thread.
    1/2done and pprather like this.
  16. geoford41
    geoford41
    from Delaware
    My buddy has a 40 coupe he bought from a guy that worked at Summit and it had shaved rain gutters, he hates the look but the car is "finished" an he does not want to strip it down to install gutters. I think the gutters really add to the cars look but maybe a finished edge like a 1932 ford DeLuxe coupe would be a compromse, since the factory way was a sandwich ofthe roof then rain gutter and lower sheet metal.
    chryslerfan55 and Six Ball like this.
  17. geoford41
    geoford41
    from Delaware
    # 3 my vote (I do like stock height) but Hollywood Hotrods 1" chop is "perfect" in my opinion
  18. Six Ball
    Six Ball
    from Nevada
    I lost my temper and smashed the rain gutter over the driver side window on my '38. I think that was the most time consuming dent I ever removed. I still lose my temper but now I just cuss. :rolleyes:
  19. 40CoupePete
    40CoupePete
    Just have to add to the concensus..AMAZING work here..
  20. neilswheels
    neilswheels
    from England
    Your avatar pic looks familiar
  21. 40CoupePete
    40CoupePete
    I pulled this from the interwebs, wishing for my own Coupe to have this at***ude when it hits the road. I figured someone here would recognize it
  22. Jacksmith
    Jacksmith
    from Aridzona
    Good goal!
  23. spudshaft
    spudshaft
    I’m still on board with this thread
    chryslerfan55, Outback and Six Ball like this.
  24. spudshaft
    spudshaft
  25. 1/2done
    1/2done
    from Ohio
    So it begins again.......
  26. Crusty Chevy
    Crusty Chevy
    Nice to see you back at it.
  27. 1/2done
    1/2done
    from Ohio
    Quick update: I started to lift the body off, but the roof wasn't happy. I figured out an alternative method, but it will have to wait till there's no rain.
  28. Six Ball
    Six Ball
    from Nevada
    Move to Nevada we don't have rain. :rolleyes:
  29. 1/2done
    1/2done
    from Ohio
    The weather cooperated today and I was able to separate the body from the frame.
    I ended up using the gantry with a flat hook ratchet strap on the front and the engine hoist with a chain and axle strap through the filler neck hole on the rear.
    I modified the body cart to fit the coupe body and tucked it away for the time being. You can see the 32 cab to the right, waiting patiently.
    The flash rust isn't as bad as it looks, it wipes off powdery with your hand. A scotchbrite and Ospho will clean it up quick.
    I may go out after the garage heats back up and do a little derusting tonight, but in reality I think I'm done for the day. Doing this **** alone at 63 and deformed from arthritis gets old quick, but if I wasn't doing it I think life would be boring and a bit pointless.
    SS327, Chucky, Crusty Chevy and 9 others like this.
  30. CoolHand
    CoolHand
    Alliance Vendor
    Just gotta go at it easy. Pick away a little at a time.
    Go about it like Afghans fight their wars: Don't do much at any one time, but never give up entirely either. :cool:
